Question about Dishwashers
Disdwaser leaves spots on dishes
Just put in a new kenmore dishwasher. When dishwasher gos through cycle washing dishes the dishes come out with a film and spots on them.
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
The problem is hard water. go to www.dishwasherfilter.com and you will find an amazing product that is guaranteed and affordable.
Posted on Jun 24, 2009
    Sergeant:
  • 229 Answers
You simply need to use a product called Jetdry for a couple of weeks until all the traces of factory solvents etc. work out of the machine. Sometimes if you have a really high concentration of particulates in your water the problem will continue and that is what the Jetdry is for. It isn't the new dishwashers problem it is the local water. One permanent solution is to hook up a water purifier/softner in order to clean the water up. Jetdry is used in many areas and is perfectly safe. Good Luck this will help.
Posted on Nov 26, 2008
Kenmore Ultra Wash dishwasher leaves spots on ALL dishes, top and bottom. Changed detergent, same problem.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 24, 2011 | Kenmore Dishwashers
Cloudy white film on dishes after the cycle has completed.
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jul 10, 2010 | Kenmore 24 in. 16352 / 16354 / 16359...
Dishwasher leaving a white film on dishes after wash/dry cycle
Well, that usually happens if the water in the area has too much alkali metals, such as calcium and magnesium.
Try putting some salt together with the detergent before you start the cycle.
And if it still does, try washing the finished dishes again with clean water, i mean, without detergent...
Mar 18, 2010 | Kenmore 16764 Dishwasher
Dishes have a soap residue left on them after washing
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 12, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 17033 dishwasher will not clen dishes
USE JET DRY and clean the system every once in awhile by running it through a cycle with no dishes and use washer cleaner for that model.
Jan 07, 2010 | Kenmore 24 in. 17033 Built-in Dishwasher
I have a adb2200awb amana dishwasher which leaving glasses with a cloudy plus grid stuff on the glass and on the dishes. i use jet dry stuff plus the talbets with jet dry in them also i put them on a 2hr...
This is a classic sign of too much detergent. Are you only using one tablet? Too low of a washing temperature could also be your culprit. Dishwasher detergent needs to be washed with at least 120 degree water. Check to make sure your supply is hot (if it's plumbed to intersect with your faucet, just check faucet hot water supply temp). I'm not sure why you're running it on a two hour cycle, dishwashers can generally do the job in about 40 minutes. The grit is probably because there are food particles in your food trap. Make sure the food filter beneath the spray arm (if equipped) is clean and check the lowest areas for food scraps.
Jul 08, 2009 | Amana 24 in. ADB2200AW Built-In Dishwasher
Dishes not rinsing well,
I would check the bottom drain area. Sometimes food can stay down there and block the drain or get back around onto the next load.
Apr 06, 2009 | Kenmore Dishwashers
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
My dishes comes out still dirty
I put a bottle of CLR in the dishwasher and I did a wash without any dishes. Repeat if needed.
Aug 18, 2008 | Maytag 24 in. MDB5651A Built-in Dishwasher
Dishwashers Logo
126 people viewed this question
Top Dishwashers Experts
