Question about Cameras
Red light kept on blinking while the battery charging the battery
  • 2 more comments
  • Anonymous Dec 31, 2008
    While loading, the red led is suddenly blinking, indicating, it won't load.
    I did not solve the problem, but it does not always appear. Often, the battery will load normally, which would indicate, that it is not necessarily so faulty...
  • Anonymous Jan 21, 2009
    My charger also keeps on blinking and not charging. How do I get this fixed? I have only had the charger less than one year.
  • Anonymous Feb 17, 2009
    I have had the same problem. I've noticed that it does not happpen with all batteries. When I put in four and the red light blinks, removing some and starting the charging cycle agin will stop the 'blinks'. Putting the one that was removed, will again start the blinking. So it must be the problem with the battery.
    Or maybe something else??
  • Anonymous Apr 29, 2009
    I'm thinking it constantly blinks when the battery is not fully drained and needing recharging.
I had this problem and I solved it by taking Q-tips dipped in rubbing alcohol and cleaning the contact points of both battery and charger. My batteries are now charging again and no more blinking lights!
Posted on Jun 23, 2009
Remove batteries and throughly clean the terminals. Try again.
Posted on Feb 22, 2009
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
The charger red light kept blinking while im trying to charge the batteries. after charge the battery overnight, the battery went dead after i took a few photos. does the problem lies in battery or...
Welcome to FixYa.
Red light indicates that the battery is charging. The light will goes off to inform you the charging is complete. Possible that the battery was alreay damaged since you left it charging overnight. Charging time is approximately 5 hours only.
I suggest that you have to replace your battery with a new one.
Feel free to send us your suggestion or comments if this solution was helpful.
Thank you for using FixYa.
Apr 11, 2011 | Olympus Stylus 790SW Digital Camera
My phone is sony ericsson xperia x10 mini pro, i have kept it for charging after few minutes red color light is blinking and it is not turning on, i have tried removing battery, sim and memory card, but...
My phone is sony ericsson xperia x10 mini pro, i have kept it for charging after few minutes red color light is blinking and it is not turning on, i have tried removing battery, sim and memory card, but still th problem is same. please help me
Oct 03, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
My Casio Exilim EX-S880 wont charge. when i put on the charger the red light blinks but it is not charging.
I had this exact same problem. Here's a solution. I had to do it about 7 times and others on Amazon said they had to do it about 20 times. But it does work! My light is a solid red as we speak! Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Jul 16, 2009 | Casio Exilim EX-S880 Digital Camera
Bettary problem or adaptor problem?
ac/dc convertor board inside laptop faulty.
May 31, 2009 | Dell Inspiron 1300 Notebook
On the samsung p1000 digital camera charging is proving a problem. An orange light keeps blinking when the charger is connected and the camera remains uncharged and will not switch on
had the same problem! brand new camera, never had it switched on and it just kept blinking.
took battery and card out, put battery in then tried to charge. same orange light.
put card back in and took battery out for min and replaced, red light is on now!
hoping this has done it. will try camera in few hours!
Nov 21, 2008 | Cameras
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Cameras Logo
1,363 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
