Question about Sony STR-DE585 Receiver
"Protect" feature increasingly activated.
My setup has been working fine for the past few years. About 6 months ago, the "protect" feature activated itself (shut off all audio coming from the reciever) at a particularly dynamic part of a DVD we were watching (Lord of the Rings, I think). I shut off the unit and turned it back on, and finished watching the movie wthout any problem. Now, the "protect" feature is becoming increasingly activated, and at levels that are less and less dynamic, to the point where I cannot truly take advantage of DVD audio tracks. The manual only briefly mentions the "protect" feature, and then only in reference to troubleshooting no speaker output when initially setting up the reciever. I have checked all connections and everything is good, plus nothing has changed (no components added or removed) since the problem started. Playing music does not seem to cause the same problem.
  • CTjaycee Nov 28, 2008
    I started having the same problem and it is a royal pain.
  • paulstead_61 Apr 13, 2009
    I have the same problem. Playing guitar hero through xbox. Smelt burning then Protect comes up. Does anyone know the fix?
    Novelist:
    Champion:
  • 219 Answers
You may have an output transistor gone bad and it is trying to run on one good transistor since they commonly are used in pairs (one positive and one negative). Time for a trip to the shop. Good luck.
Posted on Jan 23, 2007
SOURCE:
Vacuum turns itself off after 5 minutes of operating. The hose had a little matter in it, but wasn't clogged, and the filter indicator is green. It was cleaning the carpet just fine before it stopped, the...
The motor may have a thermal protect feature built in. Opens circuit when too hot. This is to protect motor and to prevent a fire. If you can check for lint build up around motor. Also, motor could be on it's way out.
Sep 28, 2013 | Hoover UH70120 WindTunnel TSeries Rewind...
Stereo speakers not working
Sounds like the factory deck went bad or you have blown speakers and causing the deck to go into protect mode. Check the speakers frist
Jun 04, 2009 | Car Audio & Video
Protect error on agv8500
Hi there. I have the same unit. A darn nice piece of hardware. A couple of months back I noticed my cooling fan making noise. A few days ago I got the "PROTECT" message and the unit wouldn't power up. I turned it off for three days and it started playing again. Now I'm pretty sure it went into protect mode because it overheated. I just tried finding a Teac replacement fan and didn't see one on the web. My solution will be to adapt a small computer-type fan onto it to keep things cool. It works too well to let it die! Good Luck, Gborchers. GROGSTER
Nov 15, 2008 | Teac Audio Players & Recorders
Onkyo ts595 goes into protect mode with volume increase
Hold the VCR/DVR button in and press the ON/OFF Standby button. The display should briefly read CLEAR and then the unit switches off. If that clears protect mode, you'll need to redo the Audyssey and configuration setup as these will have been cleared by the reset.
Sep 27, 2017 | Onkyo TX-DS575 Receiver
Protect error message
when the speaker wirer has a short circuit or touches the chases of the vehicle activates the protect function. so you need to get it serviced or do it your selves.Read the manual. http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Consumer/Manuals/kdv415u.pdf
Aug 11, 2008 | Car Audio & Video
Power issue
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Aug 25, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi WS-65807
OPTION MENU "MENU 8270" SERVICE MENU "MENU 8257" CONVERGENCE MENU "MENU 8259, 4 FINE, 5 COARSE, 6 MISC." Then you can also check by:This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB.
May 22, 2007 | Mitsubishi WS-65807 65" Rear Projection...
TV will not turn on
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT.
Apr 09, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Sony STR-DE585 Receiver Logo
345 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
