Windows XP fails to shutdown properly and hangs with blank blue screen.
SOURCE: DELL MASTER RESET?????
When booting up to Win XP you may get a error that reads "Unmountable Boot Volume". This is probably because your boot.ini file is messed up.
You should be able to restore your windows installation.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&l=en&s=gen&docid=35F157CB59994ED7E040A68F5B2813E3&journalid=4391620012FE791FE040A68F73281D77&Query=dW5tb3VudGFibGU=&SystemID=DIM_CEL_1100&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false
SOURCE: FATAL ERROR MESSAGE/DELL OPTIPLEX GX150 DESKTOP/WINDOWS XP PRO
Optiplex 150 I get a message error loading operating system
can somebody help out there?
SOURCE: Upgraded Dell Dimension 3100 memory to 2 Gigs - Windows XP fails
Did you add the two sticks with the 512 or remove the 512 and add the two 1gb sticks? Try booting the machine with ONLY the 1gb sticks in.
Your machine supports 1gb modules but they can't be higher than 533MHz. Check that the memory you purchased was either PC3200 (400MHz) or PC4200 (533MHz) and is 1.8v. If you post the part number off of one of the modules I can look it up for you.
SOURCE: blue screen when i install xp
Thats the blue dump error .so format the drives and reinstall the os
SOURCE: Windows xp computer not reading windows transfer cable
it might be the Network adapter causing problem, please check in device manger if the drivers are not showing yellow mark or red.
If any, then install the drivers from Dell Drivers & Downloads
