Question about Kitchen Ranges
Whirlpool Electric Stovetop Repair Issue
I burnt on some aluminum onto my electric stovetop. I tried to remove it - removed 90% but wore through the finish on the stove top - the area that wore through is about 2 square inches. Is there anything I can do besides replacing the entire stovetop?
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Nothing you can do short of replacing top, which depending on age may be a cost prohibitve option
Posted on Nov 27, 2008
Maytag electric range model# MERH752CAS oven and stovetop stopped working.
Check the breakers. The range runs on 220v and one of the breakers may have tripped and it is running on 110v. Post back the results.
Feb 10, 2013 | Kitchen Ranges
What is an electric kettle? Is it different than stovetop one?
An electric kettle uses electricty and not the stovetop. Once the water has boiled, the kettle stops heating the water and you hear a noise signaling that the water is ready. I use one every day becuase I find that it boils faster than using a stovetop.
Jan 16, 2013 | Home
I had some aluminum foil to melt onto the stovetop and can't seem to get it off
go to ehow.com and just type in how to remove aluminum foil from your stove top. the solution is there . good luck!
Jan 04, 2011 | GE Spectra JBP78 Electric Kitchen Range
I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Jan 21, 2010 | Maytag MER5775Q Electric Kitchen Range
When i plug in my kenmore stovetop the other electrical outlets trip, i unplug it and reset the outlets and the outlet works but i can't use the stovetop unless i light the gas with a match now. what is my...
you, or your electrician has pulled power from one of the gfi outlets to power the electric sparker on the stovetop. If you can figure out which gfi that the power was pulled from, open up the box and find the wire that runs to the stove and remove it from the gfi outlet and connect it to the power before it goes to the gfi.
Dec 26, 2009 | Gb Electrical 1 30 Amp Ground Fault...
Plastic spoon melted on ceran stovetop. Used a
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Aug 24, 2009 | Whirlpool RCS3014 Electric Cooktop
Can't remove burnt milk from right burner on stovetop?
I'm happy to say burnt milk can be removed with a combination of cerama bryte and let sit for one hour and then lots o elbow grease hard rubbling with also applying Mr. Clean Magic Eraser. The Mr. Clean Magic Eraser works very well but you have to still rub alot to get it safely scratch-free removed.
Dec 13, 2008 | Jenn-Air JED8430 Electric Cooktop
no replacement only option or use as is shouldn't cause and problems
Nov 26, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Electric stovetop disconnection
Can you provide specific model number information ? That would help me to help you...
Sep 13, 2008 | Cooktops
RF315 Electric Range
It sounds like you need to replace your heat sensor located inside the rear left top of oven.Also you will need to pull range out and remove back panel to unplug senso good luck:)
May 20, 2008 | Whirlpool RF315 Dual Fuel (Electric and...
Kitchen Ranges Logo
146 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
