Question about Kenwood SW36HT Subwoofer
Kenwood SW-36HT I have a Kenwood SW-36HT subwoofer. This is actually the second one I brought in 4 years. Each time after normal use the SB starts to make a tinging noise as if the speaker is blown. Is the speaker a piece of junk or can it be fixed. I refuse to buy another one because I might encounter the same problem. The SB is great while it's working but now the tinging noise is so bad I can't bear to turn the darn thing on. Please help.
  • 119 Answers
SOURCE: Speaker outputs blown on 4 channel amp
the outputs should be replaced in pairs, there are 2 to 4 pairs, but you sould only need 1 pair replaced. these transistors typically range between 10 to 30 cdn each + labour, look for 1 to 1.5h to replace & test the unit after repair. check your local repair shop for their rates. good luck
Posted on Nov 30, 2006
  • 14 Answers
SOURCE: Kenwood kdc-mp528 amp/speaker problem???
This is a common mistake. This problem indicates that you are using the solid blue wire from the head unit to the remote turn-on on the amp. This is a power antenna wire that only receives power when on FM radio. You need to replace this with the Blue & White wire from the head unit (power control wire) to your remote turn-on on your amp. This should solve your issue.
Posted on May 12, 2007
SOURCE: Speaker blown? How do I open it up to see? And how do I fix it?
Try without having the input plugged on the speaker ... to determine if the noise is coming from cable or receiver
Posted on Aug 16, 2007
SOURCE: Wiring Diagram
First, try looking here: http://www.crutchfield.com/learningcenter/car/amplifiers_movie.html If that helps, be sure to leave feedback or I don't get paid. Look all over the cruchfield page and you can find guides for every type of installation.
Posted on Oct 03, 2007
ArtyP44
  • 8 Answers
SOURCE: SW-36HT
the only way to get to the fuse:
you need to remove all the screws surrounding the amp on the back of the speaker. when removing the last screw be sure to hold the amp
in place because if you don't it will fall out towards you causing damage to you as well the screw hole.
disconnect the speaker connector. you need to press the latch on the side of the connector to release it from the base.
carefully remove the amp and lay it flat on a sturdy surface. don't lay it on something that can tear because the grill on the amp can damage cloth very easily.
If you look at the board closest to the edge you will see a fuse there as well as on the main board that is lying flat. check those fuses to see if they are burn marks on them. you should have 3 fuses to check. replace as needed with the correct ones. if you don't know which ones you need take them to an electronics store or auto store.
hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/arturo_82cd53a2264b6f81
Posted on Dec 01, 2008
I have Kenwood SW 900 . need to know its out put. Kept for long period
Do you mean the Kenwood SW-200 subwoofer or the SW-200 power meter? The subwoofer can use 50W RMS at 4 Ohms. It's rated at 60W. The power meter reads in two ranges: 20W and 200W.
Kenwood has the manual for the subwoofer on their support site. The direct link to the manual is http://kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/sw200.pdf .
I hope this helps. If you are looking at a different Kenwood product, please clarify which product you have. I can't find a SW 200 receiver from Kenwood.
Mar 08, 2016 | Kenwood Car Audio & Video
Kenwood sw-35ht Replace with a kicker sub
I suppose you could, but you are talking about a driver (speaker) that was not designed for that cabinet size and amplifier used in the Kenwood, There are differences in speaker design besides power rating and impedance.
Jun 10, 2014 | Kenwood SW-38HT Subwoofer
Kenwood SW-32HT Subwoofer Dropping sound Yamaha Reciever
Several possible answers. First - is that the Yamaha has a fault that is sending a signal with too much power on it. And the sub detects this and switches off.
Second - either the Receiver or Sub is switching off when no audio is present. A setting problem?
Third - the sub has a fault, possible overload, and goes to standby for safety.
Jul 01, 2017 | Audio Players & Recorders
How do I adjust my subwoofer bass level for my kenwood kdc-138 car tereo
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/ You can download the manual from Kenwoods site. While the unit is in Standby mode, press the B.Boost button for a second or two. You should now be in the Menu. Select SWPRE. Now chose SW from the (R*/SW) options. The output of your CD player is now a dedicated sub woofer output. I hope this is what you meant. There are many settings regarding the sub woofer and generally the sound in whole. Getting the manual is highly advisable. dreamsystems.
Feb 08, 2011 | Kenwood Car Audio & Video
How do i turn on the subwoofers through my kenwood radio model number KDC-MP142/CR it said to hold the AM- button for 2 seconds i did and it did not turn them on and it does not show subwoofer levels or...
According to the manual you need to hold down the source button to enter audio control mode.
Hold Source button
Press audio knob to enter control mode
Select audio item to adjust (scroll to what you need to adjust, then press the audio knob)
Adjust, turn on what you need
To exit hold audio knob for a second
Sep 21, 2010 | Kenwood Car Audio & Video
SW does not show up
Check the preset eq. some of them do not alow you to start subwoofers..
Apr 20, 2010 | Kenwood KDC-MPV8025 CD Player
No wiring harness
Hello goose720,
First, try the dealer where the Kenwood was purchased. They will normally replace missing items under warranty. Next would be Kenwood, tell them the wiring harness was missing and request that they send you a new one. If neither of those work, then you probably will have to purchase it. Here is the website for Kenwood parts.
Hope this helps.
Apr 28, 2009 | Car Audio & Video
SW-36HT
hope this helps.
Sep 22, 2008 | Kenwood SW36HT Subwoofer
I brought a second hand kenwood car stereo and i need a code to use it
You're in luck!
Click here, it will bring to a page authored by one of our best technicians (Robotek). He outlines the procedure for clearing the code on most Kenwood models.
If this gets you going, don't forget to give Robotek a rating (me as well).
Aug 10, 2008 | Kenwood Car Audio & Video
Sub-woofer output not working
"Sub-woofer output not working" problem, and notify you when a new solution is offered.
Press the setup key on the front of the receiver
Select the subw setting
Move the multicontrol knob until the sub woofer is on
Turn off the receiver and turn back on- the subwoofer should be on
The operator manual can be downloaded on the web site--- free
http://www.retrevo.com/support/Kenwood-VR-507-Receivers-manual/id/480ag219/t/2/
Sep 22, 2007 | Kenwood VR-507 Receiver
Kenwood SW36HT Subwoofer Logo
261 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
