Question about Pitney Bowes C180 Copier
Pitney Bowes C180 copier: what does a U16 code mean?
    Problem Solver:
  • 18 Answers
Develepor unit failure. Did you by any chance remove the Develepor unit? or did you come close to the wire connector located behind the toner bottle if so reconnect it. NOTE ! Before checking any connector make sure the power is off and not plugged into the wall outlet ....Good Luck
Posted on Nov 27, 2008
Instruction manual for pitney bowes copier AD20
I have this manual on my computer. If you send an email to LBrown18062@hotmail.com I will send the manual to you right away. Please put PITNEY 9920 as the subject line. I hope that this will help you out. Lawrence Brown
Oct 21, 2011 | Pitney Bowes C180 Copier
Pitney bowes c 180 copier red wrench error
The red wrench is a maintenance indicator. Your Pitney Bowes C180 is made by Panasonic and is a model FP7718. I was going to type up the maintenance reset procedure but I will just give you a link to a page that has step by step instructions. Here it is:
http://www.copytechnet.com/forums/panasonic/6754-panasonic-fp-7718-maint-counter-reset.html
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 31, 2010 | Pitney Bowes C180 Copier
C180 says E2 and printer tray light blinks
E2 means paper miss feed press resum button the go to print
Oct 30, 2009 | Pitney Bowes C180 Copier
I have a pitney bowes C180 that won't copy. The
the little wrench means it has shut down because it has exceeded the maintenance count, probably for the cleaner web in the fusing unit. Call service at 1 800 243 5556
My pitney bowes c180 copier after turning on it started to work but after a while E 340 displays on the top board what will i do to fix it?
There is a sensor by the drum that checks the image on the drum. If the sensor is dirty, or the image on the drum is too dark, it causes this code. 18002435556 for service.
May 11, 2009 | Pitney Bowes C180 Copier
Pitney Bowes Model 9016 Error code E3 01
E3-01 is the toner bottle rotation. for some reason it is not rotating. Take out the toner bottle and be sure it is in coreectly, that the labels are not loose and preventing it from turning.
Jan 19, 2009 | Pitney Bowes C180 Copier
Pitney Bowes Copier - C180 - Error E3
Sorry it took so long. Your copier probably is similar to a Toshiba E series. The error code is paper jammed in the bypass section.
Use this link as a lookup to the error codes
Use 4501 under Toshiba to find the error codes.
Aug 26, 2008 | Pitney Bowes C180 Copier
PITNEY BOWES C180 COPIER
Contact OCE to find a dealer in your area. There the ones handling service on Pitney Bowes copiers.
Jul 29, 2008 | Pitney Bowes C180 Copier
Service Manual
A good place to find one is on copytechnet.com. I checked some of the service manual websites and nothing was comming up with that model number. It could be because Pitney Bowes spun it off into Imagistics and now it's called Oce. Usually the copiers are made by Ricoh. Someone on there would know where to get the service manual under the Ricoh model number as well.
Jul 10, 2008 | Pitney Bowes C180 Copier
Pitney bowes c180
Try making a copy in Photo mode and see if it makes a difference
Nov 18, 2007 | Sharp AL 1631 Copier
126 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Adorjani Laszlo
Marvin
Marvin
john h
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
