Question about Apple Powermac G4 Quicksilver Logic System Board 820-1342-b 630t-3827 630-3828
Powermac screen developed fine black grid and won't operate properly
I have an Apple Powermac G4 Quicksilver Logic System. The screen suddenly developed a grid of fine black lines across it. When I tried to go to various sites it would ghost the sites and sort of wave colours, etc. I plugged it in to another feed and the screen was fine. It was suggested it was the video card. How do I find where this is? Any suggestions?
    Top Expert:
  • 5,051 Answers
Isolate the problem to see if it's the screen or video card by connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without a problem then your original screen is bad and your video card is good. If the Borrowed monitor displays the same problems as your original then your video card inside the computer is bad.
Posted on May 30, 2012
SOURCE:
I have a powermac G4. When I turn it on it chimes but there is no display and a red light on the motherboard. Checked the power supply - all voltages are good. Bad motherboard or video card?
There is one red LED on the Power Mac G4 QuickSilver logic board. It indicates that there is power to the board and does not imply a fault condition.
Do you hear mechanical activity from the drive? It is possible the machine is running fine except for the display or graphics card. Try another display. If you have another Mac, you can also try starting the machine in target disk mode by holding down the T key at boot (your machine was built in 2001, so it should have this feature) and see if you can access the internal drive from another machine. This should eliminate the motherboard as the culprit.
May 16, 2010 | Apple Power Mac G4 Desktop
I want to reboot my powermac g4. i have the startup disk i dont kno wat to type at the black screen
All you should have to do is put in disk and powermac should start from it, if not then replace the pram battery and try again. The battery is on the motherboard and can be bought at any radioshack.
May 01, 2010 | Apple Power Mac G4 Desktop
Powermac g4 shut down
OK it's a G4 iMac.
Burning smells coming from macs often indicate a failure in the power supply module. That said, the G4 iMac (in my experience) has been the most reliable iMac ever and power module failures are very rare.
Your best option is to find a Mac repair centre near you and take in in for a quote. But be warned - it will cost. For some reason known only to Apple power supply modules are expensive (but not as expensive as the equivalent volume of HP ink) and replacing them is not as easy as on many of the other computers.
If it is the power supply, you will not be able to switch it on again. Your data on the HD should be safe (unless the smell was coming from that - - I've had it happen!). So when you get to the workshop and you've had your quote, if you decide not to go ahead with the repair, ask the workshop to remove your HD and put it into an external case so that you can plug it in to another Mac and continue using it.
Let us know what the outcome is.
Oct 07, 2009 | Quicksilver Power Mac G4 (Quicksilver)
The power button is only working periodically
On these PowerMac G4 desktops, the powerbutton works when you press hard and long on it.
If this continue even doing so, I would recommend to take the Mac for repair.
Jun 25, 2009 | Quicksilver Power Mac G4 (Quicksilver)
Mac g4 heatsink
try adding pci slot fans to keep it cool. You can find them on ebay and places newegg.com or any other computer place
Aug 18, 2008 | Quicksilver PowerMac G4 FW800 Heatsink...
Powermac g4 will not turn
this is a common problem with G4 Quicksilver. Your power-supply is defect and has to be replaced. I have 4 G4s in my lab with the same symptom: a short flash of the power-button light, sometimes it turns on, but mostly the machine is dead.
Richard
May 07, 2008 | Apple Power Supply 344 Watt PowerMac G4...
Apple Powermac G4 Quicksilver Logic System Board 820-1342-b 630t-3827 630-3828 Logo
153 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
tylerbell49
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
