Question about Refrigerators
The top freezer temperture varies from freezing to 40 plus?
Any ideas what part is a problem??it is a jenn air JRT 199A
    Problem Solver:
  • 10 Answers
Sounds like you could either have a defrost termanation switch or defrost timer or the motor under the fridge hanging or stopped up.
Posted on Nov 26, 2008
My freezer says 20 and the temp is 40. The back is ice. The cooler says 36 and it is 40. Any ideas?
First of all you will need to defrost the refrigerator.
Once the ice is cone the air flow will improve and freeze the freezer and cool the fridge.
You will need to check that the inside fan motor is running
you will need to check if the defrost cycle is working too
Mar 30, 2011 | GE Profile Arctica Stainless Steel Top...
Jenn aire refrigerator not completely freezing ice cubes
Increase the inside coldness by rotating the termostat switch nob to a higher number position.
Oct 03, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
JFC2087HRP Jenn-Air freezer creaking noise.
Most of the time this happen when the refrigerator has been hooked up to the water, and than you unhooked it!!, the water that is in the hose makes that sound when it's pushed by the air in the hose. that's a typical problem when you unhooked the water.
May 13, 2010 | Jenn-Air JFC2087HRP Side by Side...
Amana bottom freezer-
Your model does not have an auto damper so the most likely cause is the themostat is out of calibration or the control vent from freezer is open all the way. Try adjusting to warmer temps and see if compressor will run less. If the only action the thermostat will do is turn off then for sure the thermostat. If the compressor continues to run at warmer tempertures the thermostat wil need replaced. If the dammper vent is stuck open or broken will allow the colder heavy air to settle to bottom section. Sea Breeze
Mar 12, 2010 | Maytag MTB2456G Top Freezer Refrigerator
Jenn-Air Jrsd 249t top is warm... bottom freezing
Uncertain as to whether this is a "freezer at top or bottom" model? Make certain that temperature control settings are approximately at the one-half way for both the freezer and fresh food compartments. If freezer at bottom, you may have a defrost component issue (defrost thermostat or heater). If so, contact an appliance service company.
Feb 10, 2010 | Refrigerators
I have a jenn air JCD2389GES. Every day I'm getting puddles of water underneath the the unit. Our ice maker is turned off (broken for the third time)but the water line is still open to dispense water. We...
The condensate drain may not be draining into the pan under the fridge or it may have a leak or could even be not connected to the condensate pan in the evaporator.
Another possibility is that your condenser might be dirty or plugged causing the suction line going to the compressor to freeze up and then thaw leaving puddles under the fridge. Clean the condenser (the coil under or behind the fridge) and it should stop.
Over stocking the freezer will cause this as well. If you cover the air return in the freezer the evaporator will freeze up and the suction line will freeze back to the compressor.
Jul 09, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn Air Freezer Works, Refrigerator Does Not Cool
check the damper which provides air flow to the fresh food side
Jun 07, 2009 | Jenn-Air JSD2789GES Side by Side...
Top Freezer temperture warm, not freezing food
clicking noise is probably compressor relay operating and compressor not starting. probably compressdor faulty
Nov 14, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Jenn-Air WW30430W Oven
the doors pops when i open the doors on top and bottom
Sep 13, 2008 | Jenn-Air JJW8530C Expressions Collection...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
