Question about Sharp AL 1631 Copier
Sharp copier al1631 , putin new toner sometimes shows CH
Spits out blank paper does not run as long as it did prev. before it spits out paper
    Problem Solver:
  • 11 Answers
The drum might not be rotating due to either the drum gear is wornout or the drum drive gear on the machine main drive unitis wornout.
Posted on Nov 28, 2008
Sharp Al1631 unit won't copy; just spits out blank papers
check for empty toner... and if the laser lamp is dim or out... the laser lamp is the lamp that comes on when you copy from the glass table or through the document feeder
Dec 09, 2009 | Sharp AL 1631 Copier
My sharp copier AR-205 will not copy and the letter CH or showing up
Install the developer unit and toner cartridge properly and close the copier side covers well ie the front and the right covers.
Nov 24, 2009 | Sharp AR-M205 Copier
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
ROLLER ROTATING KNOB TURNS CONSTANTLY ON SHARP AL1631
Many copiers will do this if you have run out of toner.Copiers will turn over trying to add toner from the cartridge to the developer unit.
Nov 18, 2009 | Sharp AL 1631 Copier
Sharp al1631 copier, copys are too Dim settings don't help ?
Check the toner supply, it may be running out of toner. Check the bottle or cartridge for correct install. Turn the machine on and let it warm up, Recheck the copy quality. If it is still light run a dozen blank copies, then a test copy if it is improving the toner is depleted and need to catch up, if it isn't there may be a problem with the toner add system.
Hope this is of some help.
Ed
Apr 27, 2009 | Sharp AL 1631 Copier
Sharp AL1631- Paper will not feed through
First off I seen these problems so many many times as an sharp dealer, I think I may drop the support however, the reason why your are getting the misfeed is beacuse your paper feed tires are worn and need replacing, r u in Ct f so we can helpif not call your indepenant dealer , remember Staples will not support this machine, and tell him your paper feed tires are bad and needs replacing
the Noise could be anything let's fix one problem at a time ok.
Mar 06, 2009 | Sharp AL 1631 Copier
CH Error
CH - open cover in the paper feed area.OR - Sorter not installed properly
CH blinking - Dev unit is not properlyinstalled.
EE-EU - Low toner density in thedeveloper.
Check/ replace toner cart. Check/ reset Dev. unit. Check covers and doors to make sure all are closed properly. If you have sorter -- make sure sorter is seated properly.
Mar 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
Won't copy spits out blank paper occasionally CH will flash
Go to www.sharpusa.com. Type in the model number in the copier section to get a new owners manual.
Is there any errror codes?
Nov 26, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
97 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
