Question about Refrigerators
Whining noise from freezer
I get an intermediate high pitched whining or humming noise from the freezer, its annoying so i turn fridge off and on and it goes away can ya tell me what this is?? Refrigerator has a continuous whining noise coming from behind the icemaker
    Sergeant:
    Champion:
  • 311 Answers
Fan motor is bad and needs to be replaced.
Posted on Nov 28, 2008
Whining noise on 2002 chevy tracker, comes and goes
Could be your alternator or a bad idler pulley. Is the transmission good? It may be the tranny or your differential whining.
Feb 18, 2013 | 2002 Chevrolet Tracker
Lg bd670 makes high pitch whining noise
It is the top of the dvd players "clutch" plastic wheel. There are gray rubber snubbers in a captured plastic wheel that disintegrates. Covered under warranty, but part number MKC 66030401 from electronics repair company such as Andrews Electronics at $19+sh. It is a very simple fix, remove cover,3 screws on back, lift off and 4 screws hold dvd on main frame. Carefully remove ears and lift off top of dvd, replace with new part. Good luck.
Dec 21, 2012 | LG BD670 Bluray 3D Player
Constant high pitched whining noise. Increases
you could be low on transmission fluid check that and make sure it registering properly on the dipstick.
Oct 20, 2009 | 2003 Toyota Sienna
High pitched sound from fan
were is the fan making the noise if it in the freezer and making noise check for frost eany frost you may have defrost problem if it is in the refrigerator change fan if is the condenser fan change
Apr 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
RCA F32650 production May 2003. Was working fine. Turned it on the next day, got no picture and a high pitched whining noise.  Please let me know what I should do to fix it.
If it weren't for the high pitch whining noise. I would say it probably is an internal fuse inside the chasis. It is rated at 1.5 to 2.0 amps. With the whining noise it sounds like a trouble shooting bench
job. Problems occur when a electrical/electronics device is turned on and turned off. Inrush voltage,
when it is turned on, can go up to three times more than normal. This also happens at turn off. Solid state components usually fail at this time. I don't feel that this is a problem that can be fixed in the home.---BBB
Jan 25, 2009 | RCA F32650 32" TV
Whining noise from pc tower
No transistor will make such noise... The problem is not in your M/B. The problem might be due to the fan that cools your processor. So clean dust around the fan thoroughly.
Sep 28, 2008 | ASUS NCT-D (90MSV430G0UAY) Motherboard
Noisy compressor
Is a Hotpoint refrig?? Ge (who makes hotpoint) is having trouble with the freezer fan howling. Check out posts on Ge SxS PSS models. Some say its the main board, i disagree.
Dec 02, 2007 | Hotpoint HSM25GFRSA
Ge side by side - high low humming noise from freezer section
Sounds like its the evap fan motor to me. Not very easy to axcess. I have had one GE make the same noises you are describing to me. Let me know if you are going to attempt it and need more assistance
Nov 19, 2007 | Hotpoint HSS25GFP Side by Side...
High pitched whining noise from bottom of dishwasher
the arms are only turned by water coming out of them thro angled jets, they are not electrically driven. the noise will be coming from the circulating pump, probably one of the bearings. no cure except to replace
Mar 10, 2007 | Baumatic 18 in. BDW45.1 Built-in...
turn the freazer nob to zero for a second or two, the noise will stop. turn it back to your normal setting.
Emad
Oct 29, 2006 | LG LRTP1231W Top Freezer Refrigerator
Refrigerators Logo
1,153 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
