Question about Dryers
I have a Hampton Bay or Hunter?? Ceiling fan that is Remote Control. It all of the sudden started acting strange--ie. The light started going from Dim to Bright and none of the functions on the remote control would work any longer, the only way to get it to stop doing this was to turn it off at the wall switch, after turning it off at the wall switch it would not come back on and the light would not work. I checked the battery in the Remote, it was good. So I purchased a new remote controller to install in the fan and now cannot get the canopy off at the ceiling to get to the remote for replacement. Any Ideas???
  • charlie1950 Dec 13, 2008
    I have the same problem. I have a Hunter Fan. The light flashes on and off but the fan will not work. I replaced the battery in the remote but that did not help.
  • Anonymous Jan 05, 2009
    I had the same problem and it turns out the remote control was being pressed in a drawer. If you hold down the light button it will cause the light to dim and get bright again and the only way to stop it is if you turn it off at the switch because then the remote no longer works.
    Problem Solver:
  • 6 Answers
The canopy should turn either left or right to remove. I'm sure you've tried this, but if the fan's been there awhile, it may just be a little stuck and you need to work at it.
Posted on Nov 29, 2008
Remote control B-542
Peter, Home Depot carries replacement ceiling fan remotes.
Check the attached links,remote and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Universal Hunter Ceiling Fan Remote Control Replacement Light Fan Speed...
Hampton Bay Ceiling Fan Remote Control 70830 The Home Depot
Jan 28, 2013 | Dryers
I need to replace my Hampton Bay Ceiling Fan remote control. Part # G9P2BTAUC7052T. Where do I get one?
I need to replace my hampton bay remote control part #G9P2BTAUC7052T for my ceiling fan and light.Where do I get one
Jul 11, 2011 | Universal Remote Control Hampton Bay...
How can i switch my fan to reverse? Its a Hampton
There is usually a slide switch on the side below the motor.
I don't believe any of them reverse from the remote control.
Nov 26, 2009 | Hunter 52" Ceiling Fan With Light And...
LIGHT AND FAN ARE NOT WORKING. HAMPTON BAY LIGHT IS NOT WORKING
Could be a loose wire up inside the fan. I would be very careful in its use. Might I suggest getting an electrician in to resolve this issue. You do not want to battle a fire over a fan light issue.
Aug 28, 2009 | Hunter Ceiling Fan Light Remote Control
Hampton Bay Redington IV ceiling fan remote won't work
the reciever is under the cover for your fan to the ceiling. Try pulling the switches on you fan then using the remote after each try. then check your wall switches,,, it could be wired to one.
Aug 16, 2009 | Hunter 28156 Cote 54' d'AzurĀ® Ceiling Fan
Dryers Logo
619 people viewed this question
Top Dryers Experts
