Question about HP OfficeJet 7310 All-In-One InkJet Printer
Hp Officejet 7310 All-in-one carriage
Where can I get a replacement ink cartridge carriage ?
  • 181 Answers
If the issue is with the carriage chute your printer has an extended warranty and will be replaced by hp if you call in. Please read this document and look at the photos in Step 1.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&rule=22243&product=391182
If not then this is not a user replaceable product and you are looking at paying to have it serviced by hp or replacing the unit altogether.
Posted on Jan 29, 2009
Where is the carrriage located on my hp 7310 officejet printer?
The carriage is the unit that holds your ink cartridges, usually parked on the right side. When you have carriage stall or carriage jam you usually need to clean the clear plastic strip that runs across behind the carriage assembly, and make sure there are no scraps stopping the travel of the carriage.
Dec 24, 2009 | HP OfficeJet 7310 All-In-One InkJet...
My 7310 indicates a carriage jam. I've cleared all paper and verified no loose paper, dust etc is present and it still reads carriage jam. What should I do?
Inside your printer the ink cartridges ride in the carriage. If you look closely, there is a plastic strip just behind the carriage with closely spaced little lines on it. If the strip gets dirty with dust or ink, you may get that error. Gently clean the entire strip with a rag moistened with water. be sure the entire strip is clean. Move the carriage back and forth to get at all of it. Then see if that doesn't work.
Nov 27, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Ink cart error
Is there a metal wire (clip) hooked on black plastic in the ink carriage? If not, these are notorious for breaking the small plastic hook....when broken, the cartridge is not held in proper postion so printer won't recognize that the ink cartridge is installed......no replacement parts are available for this series of printers.
Jun 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I changed my color cartridge #97 on my HP officejet 7310
Remove the color cartridge. Make sure the contacts in the print carriage are clean. Chek to ensure the contacts on the cartridge are clean. Reinsert cartridge.
Mar 20, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I need a parts diagram for an HP Officejet 7310
Here's a direct link to your model on HP's "part surfer". You should be able to find what you're looking for:
http://partsurfer.hp.com/cgi-bin/spi/main?sel_flg=modinfo&model=OJ_7300_SERIES
*please rate me :)
Mar 15, 2009 | HP Officejet 7310 All-In-One Printer
Carriage Jam
If you can get the covers off. push down on piece that is blocking the cartridges. Otherwise, it is uneconomical to repair.
Jan 15, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
65 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
