Question about Sony Cyber-shot DSC-W55 Digital Camera
Lens won't come out
My camera is less than a year old. When I turn it on, the lens will not come out and it is making some strange noises.
  • mjash1961 Nov 27, 2008
    thank you for your help
  • Sony Master
  • 586 Answers
   Actueally the zoom motor start malfunctioning.In this case you have to replace complete lense assymble.And for this you have to contact any SONY SERVICE CENTRE nearby to you where you can find the said lens assy.
 Thanks for using fixya.
Posted on Nov 26, 2008
Camera won't stay on making funny noise lens won'tpop out
your lens is stuck up,making camera hesitate to turn on. may be dirt sticked on it. have it cleaned carefully and retry. regards
Sep 30, 2011 | Kodak EasyShare Z650 Digital Camera
I have a D5000 camera w/ kit lens VR 55-200, less than a year old. Recently and only occasionally what is happening is when I press the shutter release button, the lens won't focus, it won't move...
Your camera is still under the one year Nikon warranty. Call Nikon's repair depot at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday. They will verify your warranty and assist you in returning it for repair.
Jun 08, 2011 | Nikon D5000 Digital Camera
I have a Casio Exilim EX-Z33 and i dropped it a while ago and it continued to work (kind of, the images were a bit blurry). i took a picture five minutes ago and then turned it off. the lens went in but...
Sounds like the focus motor came loose - you need to take it apart and repair the gear that drives the lens assembly for focusing. The noise you're hearing is the motor trying to focus but since the lens cannot focus it continues to run and signals an error.
Feb 03, 2011 | Cameras
Hi when i switch the camera on the shutter comes out ,a strange clicking noise and the shutter goes back in ,it is only 4mths old .
Hi there its a problem of your camera lens guide pin. Which is operate your lens for focusing. Thats pin is damaged & thats why shutter comes out ,a strange clicking noise and the shutter goes back in . Thanks.
Mar 25, 2010 | Kodak EasyShare M420 Digital Camera
This lens is less then a year old and when I snap
Check the aperature setting and make sure it's set to the red mark. It could also be that the contacts on the lens or the camera need to be cleaned. Alcohol is the best since it won't leave a residue, but a clean pencil eraser will also work.
Dec 30, 2009 | Nikon Normal AF Nikkor 50mm f/1.4D...
Lens makes grinding noise
yes dust in mechanism or broken gear but ti not easy
Oct 12, 2009 | Panasonic Lumix DMC-FZ5 Digital Camera
WHAT DOES IT MEAN WHEN THE SCREEN IS BLACK AND SAYS E18 AND MAKES A VERY STRANGE NOISE AND i CAN'T TAKE A PICTURE.USUALLY IF I TURN IT ON AND OFF SEVERAL TIMES THIS WILL GO AWAY
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Sep 29, 2009 | Canon PowerShot A95 Digital Camera
FE-280 Lens Blurry Photos and no zoom turns off
You have a bad lens. Unless the camera is in warranty the cost of repairing the lens is higher than the value of your camera. The strange noise you hear is the lens motor trying to move the lens. One solution is to blow compressed air around the lens. Sometimes dust and dirt may jam the lens.
Jul 02, 2009 | Olympus FE-280 Digital Camera
Olympus FE-230 - When I turn on the camera, the lens comes out goes back in them comes out again. Then I have a blurry image on the screen. I can hear the gears turning to extend the lens. This camera is...
Hey fl_dolphin,
This is most likely caused by something obstructing the movement of the lens. You could try blowing compressed air in to the side of the lens to try and dislodge whatever is stuck in the lens. This could also be caused by a problem with the lens mechanism. If this is the case most digital cameras come with a 1 year manufacturers warranty and I would have the camera looked at by an authorized service technician. If the camera is less than a year old the repair would likely be at no cost to you. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 09, 2008 | Cameras
Nikon Coolpix S10 Problem: Lens Error The camera is less than a year old and "Lens Error" has suddenly appeared on the LCD screen. The camera makes a vibrating noise when it turns on then...
You can take pictures ( without VR function ) by starting your camera from play button then switch to photo !
Lens error appear after a shock . VR mechanism have piezo actuators glued with epoxy resin together with an carbon fiber stick . After a shock applied this epoxy broke so no vibration from piezo is transmitted to slider . It is possible to repair ( cheap , only epoxy and izopropilic alcohol needed ) but skills are necessary
(i am not an english speaker so ....)
Jun 28, 2008 | Cameras
Sony Cyber-shot  DSC-W55 Digital Camera Logo
48 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
