I put the egg in micro oven for five minutes with water.After,four minutes I had big sound from micro oven,the egg was burned and also oven was opened.After,I cleaned my oven and I was check ,it is working or not.But my bad time,it is not working.
This is the problem for my oven.I am waiting for your good answer.
Thankyou.
Hello Kavithaanto,
If I understand your problem correctly, it sounds as if your microwave was operating and the egg exploded after 5 minutes ( which caused the door to open), after cleaning up the mess, you tried it again and it does not work. If that is true, then there is a high probability that your microwave has a damaged Magnetron Tube, Filament Transformer or High Voltage Capacitor.. none of which are something the untrained person should attempt to repair. Since your microwave is a table top model, I recommend that you consider purchasing a new one. The cost to repair would exceed the cost to replace so it is not worth it. I am sorry that I couldn't provide a more encouraging solution.
Best Regards,
Rick
