Question about Logitech Harmony 659 LCD Remote Control
Safe mode display show safe mode, what do I do to unlock?
  • 50 Answers
Safe Mode is a diagnostic tool in the Remote used for troubleshooting purposes. If the words "Safe Mode" or "Safe Mode Requested" appear on the remote, complete the following steps:
1. Ensure the Remote is in "Safe Mode Requested" by taking out the batteries, and disconnecting the remote from the USB cable.
2. Hold down the Off button and plug the remote into the USB.
3. Continue holding down the Off button for another 10 seconds. The remote should then display the words "Safe Mode Requested".
4. With the unit in "Safe Mode Requested", re-install the firmware by clicking Support on your home page.
5. Click Firmware in the Downloads section and follow the online instructions to upgrade the firmware.
6. Once the firmware upgrade is complete, click Update My Remote.
7. Insert new batteries into the remote.
NOTE: Ensure the new batteries are all the same brand.
Posted on May 19, 2009
I push in the wrong radio code 3x on my 2001 audi now its stuck on safe mode and wont let me in to push in the right code
First of all you should exit from safe mode. Then turn ON the radio and let it turned ON for at least one hour, in order to exit from safe mode.
IMPORTANT NOTE:
You must have the security anti-theft code for your VW radio from the car manufacturer, or from a VW dealer!
You can find the radio code at: http://www.radio-code.co.uk/
The sequence of a 2001 Audi Concert radio programming is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
For example: we have the security code "5079". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready for use!
Audi Delta CC Radio
Please perform the following procedures while the car is parked. Otherwise you risk getting into an accident while your attention is not focused on the driving. Entering anti-theft code The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
  1. Turn on radio. The radio display shows "SAFE".
  2. Press the FM1/2 and DX buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  3. Use Preset buttons 1 ... 4 to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1.
  4. Once the code shown on the display is correct, press the FM1/2 and DX buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
  5. The radio should unlock and be usable shortly afterwards.
  6. If an incorrect code is entered, the word "SAFE" appears, first flashing and then continuously. You can repeat the above steps to unlock the radio once more, the number of attempts will be shown in the display. If an incorrect code is entered again, you radio will be locked for about one hour. After one hour - the radio must stay on and the key must remain in the ignition lock - if the display goes out, the you can repeat the above procedure to unlock again. The cycle - two attempts, one hour lock-up - still applies.
Oct 27, 2011 | 2001 Audi A6
My car audio has gone into safe mode need codes to unlock it. vauxhall corsa sxi
Hi.
There is no code to unlock safe mode. Safe mode means that a fault has been detected and the unit goes in this mode (kind of forced stand by) to prevent further damage.
Disconnect battery ground cable and check the wiring at the back of the unit, a contact in the connectors or a short on wiring is common cause for safe mode.
When you disconnect the battery ensure that you have the anti theft code if needed. Anti-theft is different from safe mode. In that case you get Code on display, not Safe or the triangle sign.
Regards.
Ginko.
May 31, 2010 | Car Audio & Video
Unlock procedure for vw/audi
audi gamma cc type
1e2fb0f.jpg The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
  2. Press the FM1 and AM buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  4. Once the code shown on the display is correct, press the FM1 and AM buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
  7. If you lose your radio code, contact your Audi dealer.
audi delta
Mar 29, 2010 | 1997 Audi A4
I have dell laptop.Cursor is showing. caplock on
No display? but you have an mouse cursor showing? So you must have an display and it is locking on startup of the OS. Do you have an bootable cd? If not lets try to start it up in safe mode..
1: power down system
2: on power up hit the F8 key keep taping it till you get display saying startup in safe mode.
3: start up in safe mode no network.
4: if it starts up to an desktop then its an driver or software which you have installed causing normal startup to stop.
If it doesn't start in safe mode we will have to boot to an OS CD.
Let me know how these first steps go..
Feb 23, 2010 | Fujitsu Siemens Lifebook C2230 Notebook
How Do I Get My Radio Out OF Safe Mode? Anyone?
Hi.
The radio goes in safe mode when the battery gets disconnected, or if for some reason the radio lost power connection.
To get the radio out of safe mode you will need the anti theft code.
This is available with car documentation, in first page of the in car entertainment booklet, or on first page of the car booklet (not the car manual).
Once you have got the code, do the following:
  1. Hold down both the AM/FM and the SCAN button at the same time, until the display shows "1000".
  2. Use the buttons 1,2,3,4 to change each of the digits until you get displayed the same code as printed on documentation (ensure that it is the right one).
  3. On some radio (programmable models), the default code is "1111" or "1234".
  4. Press and hold the AM/FM and SCAN buttons again until the radio is starting.
  5. If you fail twice the code, the radio will lock up in safe mode, and you won't be able to enter the code again.
  6. If the radio is locked, or if the code is lost, the unlock can be done at the nearest car dealer, usually for a small fee, or for free.
Regards.
Feb 07, 2010 | 2001 Audi A6
I bought an Audi A3 secondhand with audi chorus Blaupunkt-WERKE GMBH 7648 245 380 SERIEL NO AUZ1Z2X678588 ,the radio is on a safe mode please help me with the code and the method to enter the code
You must retrieve the code that comes with the Audi's radio unit. To change to safe mode:
  2. Press the P.Scan and RBDS buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  4. Once the code shown on the display is correct, press the P.Scan and RBDS buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
Sep 12, 2009 | Car Audio & Video
I brought my son a 1997 Audi, and the radio is in safe mode, can anyonr help me get the code?
Jun 22, 2009 | 2002 Audi A6
My LCD shows display in safe mode but no display in Normal boot.!
Its the problem with your display resolution. In Safe mode set it to 1280x800 and restart..
Apr 19, 2009 | Samsung SyncMaster 152 B 15" LCD Monitor
I have a 1999 Audi A6.
Mar 02, 2009 | 1999 Audi A6
Can't play or record anything, or even turn the machine on.
I can help unlock your digilogic dvdvcr2 from safe mode.
The steps are written out here.
I hope that helps.
Dec 29, 2008 | Televison & Video
Logitech Harmony 659 LCD Remote Control Logo
804 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
syspro
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
