Question about Ovens
Burners work but oven doesn't heat.
It glows orange when I turn it on but there is no clicking when knob is turned on and no heat at all.
    Sergeant:
    Champion:
  • 291 Answers
It should glow almost white not orange / ign is bad
Posted on Nov 26, 2008
What is a glow bar ignitor
Next to the burner in the oven sits a ceramic igniter. When you turn the oven it glows orange which ignites the flame. It stays on even if the oven is at temperature and the flame if off. There are 2 wires going to it and its connectors are in a part of the oven away from the heat and flame. They do burn out. There is no reset. You have to replace it.
Oct 30, 2017 | Ovens
My oven will not turn on while the rest of the stove is working fine. Does it have anything to do with the dials and clock
When you turn the oven on is there an orange glow in the burner area? If not the igniter has become inoperative. If you do see the glow then the gas valve for the burner is defective.
Aug 21, 2014 | Ovens
GAS OVEN WILL NOT GET HOT
see this instructions and fix it. God bless you
  1. eHow
  2. Home & Garden
  3. Home Appliances
  4. Other Home Appliances
  5. How to Troubleshoot a Gas Range Oven That Won't Heat
By Kefa Olang, eHow Contributor
Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
Other People Are Reading
Things You'll Need
  • Toothpick
  • Paperclip
Instructions
    • 1
      Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
    • 2
      Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
    • 3
      Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
    • 4
      Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
    • 5
      Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
Jul 18, 2013 | Ovens
Gas burners on top of stove work but broiler & oven do not heat up.
Hello'
Does your model have an electronic ignition? If so open broiler drawer ,turn on oven and look for bright orange glow. May take a few seconds.If it glows but no or poor flame .replace oven igniter.If no glow at all , check for voltage at igniter when switched on to see if it may be oven thermostat . Get a tech to test if not sure.All easy to fix.
Hope this helps
Aug 16, 2011 | Ovens
My oven works fine it just doesn't heat-up. I can hear ignition clicking but no fire from burners. A technican told me to purge the union above gas to get rid of air in the line. Thanks Louis
Personally I wouldn't describe an oven that doesn't heat up as working fine. You shouldn't have any air in your gas line unless this is the first time firing the oven, in either case the air in the gas line would work its way out eventually and the oven would light on its own.
Check to see if your ignitor is glowing before you hear the clicking, if the ignitor isn't glowing it needs to be replaced and is fairly easy to do so. If your ignitor is glowing you should check to make sure you are getting gas to the burner. The only way I would recommend checking this is with your nose, do you smell gas when the gas valve clicks? If you do then something is wrong with the burner, either dirty or the exhaust is too strong, or even gas pressure too low. If you don't smell any gas that doesn't necessarily mean no gas is coming out, at this point you should call a authorized service provider to take it over from here.
Nov 03, 2010 | Baxter BXA2G Stainless Steel Gas Single...
My Kenmore gas oven does not light.
Remove the oven Racks. Remove the oven base plate. Turn the oven on. You can then see the oven ignitor next to the oven burner. If the oven ignitor does not glow a bright orange,replace it. About a $90 part.
Oct 05, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven no lite
Hi, Remove the bottom panel in the oven and turn it on to heat. Look and see if the ignitor glows. You can test it at the connector to see if it is getting 120V. If it is getting voltage and not glowing, the ignitor is bad. The most common problem is the ignitor.
It can glow and still not open the gas valve.
I hope this helps you.
Please let me know if I can assist you further.
Vic
Jun 05, 2009 | Ovens
GE XL44 oven not working, but the broiler is...???
CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
Jan 28, 2009 | GE JGRP17 Gas Single Oven
Oven does not light
Try this:  . See if the ignitor is in the direct path of the gas. If not move it slightly to be closer to that path. Maybe something his it and it is out of position. Gas + Glow(together) = Fire The other possibility is that somethng in in the path of the gas leading to the glow coil.
Dec 21, 2008 | Tappan 30IN ELEC IGNa Oven
Ovens Logo
63 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
