Question about Toshiba 50H81 50" Rear Projection Television
Toshiba 50h13 picture shakes/ horizontal issue but OSD is good
I have already replaced the IC chip TA1360N and that did not fix the problem. What is the next step?
  • missionelect Dec 02, 2008
    Ok, I got this tv fixed now. Through a variety of different sites and through the help of the live chat at fixya I discovered that there are several caps on the board PD0637 that are damaged in some way even though they test ok and are not bulged. They are very small. For the sake of covering my bases I went ahead and replaced all of the 10uf 16v caps on this board. There are 11 in all. Appearently this is a very common issue with that board and I probably didnt need to replace the TA1360N but its in there now so Im not going to fuss with it and it only cost me 8.95 anyway. Also as a note I also wanted to let anyone know that has the same problem that the caps that are bad are surface mount aluminum but I used feed through caps that are 10uf/16v and just bent the leads to the side and soldered them to the surface. You also have to be very careful when removing the old caps that you do not accidently pull off the solder pads also. If you do you have to put them back on and make sure and reconnect the solder trail connected to that pad or find where that pad is supposed to connect to and solder the lead from the new cap directly to the board on that solder trail. Worked ok for me. I had a local circuit board shop do it for me after I started pulling the pads off accidently and they charged me like 50.00 including the caps. Totally worth it. Thanks for all your help.
  • Toshiba Master
  • 19,396 Answers
Did you test Q510 before replacing it?
Posted on Nov 26, 2008
  • Ginko
    Ginko Nov 26, 2008
    TA1360N is not a capacitor, is the signal and synch processor IC .
    Other contributor should not comment, if they do not know what they are talking about.
    Thanks
    When you have deflection problems on this set, it is usually the TA1360N , or the capacitors on the deflection circuit, always on hyperboard.
    If it is a vertical deflection problem you get up and down tremble and if it is horizontal deflectioni you get picture shaking from side to side.
    There are several 2.2 caps that you should check, but probably you did this already.
    Try changing ppicture format, usually when it is the TA1360N you get shaking intensity changing when you pass for example from PAL to NTSC to composite etc.
    Test all the caps on the hyperboard , on the service manual you find a troubleshooting diagram that tells you what components to test and in what order, when you have a deflection problem with shakey picture.
    If you have the service manual perform also a convergence setup procedure, just in case.
  • 146 Answers
^ Like he said above the capacitor is blow... If you still have it under warranty I would return it for a replacement.
Basically what a capacitor does is it starts off with full current but it slowly charges up voltage so what i'm guessing what happened is you had too much voltage going through your t.v and it fired it..
but best bet is returning where you bought if warranty is still intact.
  • Toshiba Master
  • 4,806 Answers
Have located the sevice site, if you get no joy with an expert post back
regards
    Sergeant:
  • 291 Answers
Check out any other capacitor blown or bulged up near to the ic chip .
Location of convergence chips in Toshiba 57H81.
hello if you can use a soldering iron you shouldn't have any problems but you will need to test the resistor in front of the ic and the capacitors at either end of the ic ! the ic usually located to the right hand side of the tv behind the tuner board connected to metal frame called a heatsink 2 big black chip good luck
regards
shaun
Mar 27, 2010 | Toshiba 57H81 57" Rear Projection...
My picture shacks vary fast from side to side toshiba 42H83
You could have a bad color wheel or there is a Factory Service Bulletin from Toshiba that says: Remove the MVUP14 Hyper Module from the TV chassis, remove
the top shield and replace the 10uf, 16v capacitors using Part Number
24619040 as shown in Figure 1. It’s recommended that all of the
capacitors identified in Figure 1 be replaced. (Note: These capacitors are
low impedance surface mounted aluminum electrolytic capacitors. Care
should be taken to avoid damaging the PCB while replacing these
capacitors.) You should call a good TV Tech to do this repair.
Aug 02, 2009 | Toshiba 50H13 50" Rear Projection...
Toshiba 50H13 blurry picture with white line on right side
replace all the surface mounted electrolytic capacitors on the hyper module. also called the scan converter module. this is a common trouble. what a nasty job. good luck.
Jun 23, 2009 | Toshiba 50H13 50" Rear Projection...
TOSHIBA 36A50 HORIZONTAL LINE WHEN TV IS TURNED ON
If flexing the board will "fix" the problem, then the most likely issue is poor solder connections on that board. Look for any connections that appear grainy or have rings and resolder them. The IC involved here is the vertical IC which will be a small flat IC attached to a heatsink. It may be marked LA7837 or something similar and have about 9-11 pins.
Try the resoldering and update this with your results.
Dan
Mar 03, 2009 | Toshiba 36A50 36" TV
Toshiba 42h81
STK392-110 's = replace with Toshiba or Sanyo quality only..
What was the location & value of the resistor ?
An IC, if shorted internally,can prevent the tv from powering up..
Re-check soldered in 5 amp micro fuses F850,851,852,etc
Fix it ! ..............................T.
Aug 28, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba 50h13 image trembling
something is not in tolerance in the deflection circuits if it is an up and down tremble its vertical deflection related and if its shakey from side to side its horizontal deflection. You will most likely need a skilled tech for this type of repair.
Apr 06, 2008 | Toshiba 50H13 50" Rear Projection...
Does not power on
You can get a service manual by going to this link and entering your model number. http://www.servicemanuals.net/
You should check the horizontal output transistor and low voltage regulators first. Unless you have some experience in basic troubleshooting, you should be warned that you can still get shocked even after the television is unplugged.
Jan 05, 2008 | Toshiba 50H13 50" Rear Projection...
Two vertical lines one at 1/3 screen the other at 2/3's of screen
I have not fixed it yet. But I have identified the chip that is causing the problem. If you have a service manual scan it and post it please, so I can show you the chip.
Aug 04, 2007 | Toshiba 57H81 57" Rear Projection...
Only see a slice of picture + bright horizontal band
you could do three of these change flyback change yoke change cap that couple the horizontal transistor.good luck
Apr 27, 2007 | Toshiba 27A33 27" TV
Toshiba 50H81 50" Rear Projection Television Logo
354 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
