My mp3 player won't turn on with out a charger but some times it works for short time periods
Sounds to me like the battery is done... Depending on what make/model your battery is, you may be able to change it or have it changes by somebody.
Either that or there's a problem with either the charger or the connection so the player doesn't get charged properly.
Posted on Nov 26, 2008
I Have a Slick Mp3 PLayer 4gb I put it on the charger and it turns on but when I take it off it doesnt come on
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 06, 2013 | Audio Players & Recorders
Just bought this mp3 player and it will not turn on unless its plugged into the computer/charger.. No music and never been used till I opened it. Please Help!!!
The new player needs to be charged overnight for the player will work on the battery. You may need to do this a few times after the battery runs down.
Dec 14, 2012 | Hyun Won MobiBlu DAH-1500i (1 Gb MP3...
My battery for my mp3 won't last long
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 16, 2012 | Coby Audio Players & Recorders
Battery will not hold charge
If the rechargable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 14, 2012 | Sony Nwz-w262 Water Resistant Mp3 Player...
I just bought the eclipse cld and it won't turn on after charging for hours
Sep 30, 2012 | Eclipse Audio Players & Recorders
The charger works but it does not full my battery it always says that low battery though i charge it for an hour..
Try charging it up overnight.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 30, 2012 | Creative Labs Zen Micro MP3 Player
My zune 4g red will turn on and work when plugged into the charger, but as soon as I unplug it from the charger it goes off and I cannot do anything with it. I haven't tried to restore it, not sure...
Ifthe rechargeable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 29, 2011 | Audio Players & Recorders
How to turn it on
to turn on the Nextar MA933A MP3 Player, press the play button for a short period of time. to turn it off, hold the play button for several seconds. if the device will not turn on, make sure it is fully charged
Jan 15, 2011 | Nextar MA933A MP3 Player
Mp3 player shows that battery is dead even though its charged and the screen only works if i hold the on off switch the whole time
try inserting the charger to a different socket until it works. if not you might be having problem with the charger. not the mp3 player and if you already triedto change the charger you might be having problem with the battery of your mp3 player ok send me a message for more concerns.
May 04, 2009 | SanDisk Sansa m240 MP3 Player
Short Play Time with MP3 Player
Try to re-format it. on player go to settings, then advanced then format. select format, say yes and it should reboot. if that doesn't work you need to upgrade the firmware. got to iriveramerica.com, support, ultra portabale support and download firmware updater software.
Oct 04, 2006 | iRiver T10 MP3 Player
32 people viewed this question
 Grubhead
Grubhead
