Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
No water or solution will come out of my Bissell when trying to clean the carpet
  • Noongkii Dec 16, 2008
    i know!! i dont know what happen well my mum bought the pro heat pro tech machine a few years ago and i dont know what we did. we've only used it a few times but didn't know how to use it properly bCUZ someone!! didn't keep the instruction booklet!! lol and now ive figuired it out i just had to press the trigger right? hmm but nothing... GRRR
    umm yeaa the post from b4 just then me and my brother opened the belt thingy and ... it was broken the belt snapped soo i guess that was why it wasn't working :P
    how stink!! >:(
    hope you found out what happened to yours. n hopefully ours will be fixed soon b4 the family come to stay at our house!!
    Problem Solver:
  • 5 Answers
Make sure there is water in the tank and that the autoload assy is not blocked. Is the pump belt still connected? There may be a blockage at the heater or finally a new pump may be needed.
Posted on Dec 14, 2008
How does water heater function on bissell pro heat 1548 carpet cleaner work
It adds heat to the fresh water as it is pumped out on the floor. It will NOT heat cold water enough to clean the carpet. You have to put hot water in the clean water container.
Jul 28, 2016 | Bissell Vacuums
How can I download Bissell Little Green Clean Machine manual?
direct
https://canada.bissell.com/support
or the first link has it, also videos
  • BISSELL LITTLE GREEN 1400 SERIES USER MANUAL Pdf ...
    www.manualslib.com > ... > Vacuum Cleaner > Little Green 1400 SERIES
    Bissell LITTLE GREEN 1400 SERIES User Manual. ... Vacuum Cleaner Bissell Little Green 1400 SERIES User ... Rcvd a used bissell little green machine w stagnant ...
  • Bissell Little Green Machine ' Walmart.ca
    www.walmart.ca > Walmart.ca > Appliances > Vacuums > Steamers
    • 4.1/5
    • 185 REVIEWS
    • $99.96
    Bissell Little Green Machine for sale at Walmart Canada. ... Powerful suction lifts stains and spots with water or any of the Bissell cleaning solutions.
  • Little Green® Portable Carpet Cleaner ' BISSELL®
    www.bissell.com > ... > Browse By Type > Carpet Cleaners > Portable
    The Little Green® portable carpet cleaner is produced with a minimum of 50 ... Coupon code for purchases on bissell.com: ... (including all accessories and manuals) ...
  • BISSELL LITTLE GREEN CLEAN MACHINE PDF - fenbook.me
    fenbook.me/get-it-free/b/bissell-little-green-clean-machine-manual.pdf · PDF file
    Get Free Read Online Ebook PDF Bissell Little Green Clean Machine at our Ebook Library. Get Bissell Little Green Clean Machine PDF file for free from our online library
  • Bissell Little Green Owners Manual ; Bissell Little Green ...
    www.youtube.com/watch?v=PpQji8obNz4
    • BY BOTHSHOOP
    • 4 MIN
    • 11K VIEWS
    2012-11-07 · Video embedded · Bissell Little Green Owners Manual ; ... Bissell Little Green Owners Manual ; Bissell Little Green Machine ... How to fix a Bissell Carpet
  • Bissell LITTLE GREEN 1400 SERIES User Manual
    May 24, 2016 | Bissell Vacuums
    I have a Bissell ProHeat 2x advance carpet cleaner . It stop sucking up water. How can I fix it?
    First check your filters. The Customer User Guide says to clean them after each use. There's two: The Water Tank Cap filter (looks like a screen) remove it, clean and reinstall, and the Flow Indicator: Turn the Flow Indicator Cap counter-clockwise and remove. Remove the rotor and under it is the filter. Remove, clean and reinstall in reverse order. If that didn't do it call Bissell Consumer Care at -1-800-237-7691 Hope that helps.
    Feb 13, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
    How do I fix the problem on my Bissell model # 7920-5 carpet and floor cleaner the water won't spray out onto the carpet
    First check your user's guide for filter cleaning. There are two filters both small that need cleaning after each use. If that didn't clear it up call Bissell Consumer Care at 1-800-237-7691
    Jul 01, 2014 | Bissell Vacuums
    Water and solution do not dispense.
    Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
    Bissell Proheat Upright Wet/Dry Vacuum Problems
    heatman101
    wrh
    Jun 30, 2010 | Bissell 8910 ProHeat Clear View Upright...
    Bissell carpet cleaner not sucking up.
    I have a Proheat 2X and had the same problem. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
    SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
    Apr 24, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
    Bissell pro heat steam carpet cleaner, not releasing water.
    That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
    Bissell 7901 Belt and Manual
    Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
    My bissell carpet shampooer won't spray out water
    The tubes inside the machine are probably clogged. Dismantle top hood and disconnect the three lines at the pump, open up entire top housing and inspect heater. Disconnect two tubes and heater and blow out with air compressor. That will spray all the junk, soap that has built up and your machine will be good as new. If you can't do this yourself, contact bissell and ask where your local repair center is
    Aug 29, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
    Bissell ProHeat 7901 will not **** up water
    heatman101
    adfa
    Nov 11, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
    Changing from carpet cleaning to hard floor cleaniang
    If you are looking to floor cleaner then don't go anywhere, Our experts helps you to clean your floor and the best thing is that you are never feeling regret after taking our services.
    Taking fast services call us anytime 3105441028.
    Commercial Floor Cleaning Services Waxing Los Angeles CleanerImage
    Apr 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
    Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
    67 people viewed this question
    Top Bissell Vacuums Experts
    Jim Thurston
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
