Question about Haier HSB03 Compact Refrigerator
After my mini fridge was left open over night, it doesnt get cold anymore....
I cleaned off the coils in the back and wiped off all dust on everything, but it still doesnt work. The freezer part builds alittle bit of ice only in a certain area, but the rest of the refrigerator is not cold at all. I even tried turning the dial all the way up but it still stays the same. Please i need help bad!
  • 237 Answers
Being left open can let lots of moisture in that can freeze up the air circulation paths. First thing is to leave it off and unplugged for a couple days to melt any hidden ice build up from being open all night. Then start it up like normal and see if it works properly. If not then repost and we'll go from there.
Posted on Jan 09, 2007
Freezer not freezing. meltdown?
clean the accumulated dust from under the fridge. The fridge doesnt get cold enough, the freezer gets too cold, it needs air to pass through, grab the dust, or vacuum so that air can pass across the coils
Jul 07, 2014 | GE Profile PSI23NCR Side by Side...
Mini fridge doesn't get cold anymore
Is the unit running? If so then,
by shutting the unit down for a long period may have exposed a pinhole leak of refrigerant at an external brazing point. or you may have caused an issue in cleaning it This is something that would require a licensed technician to resolve.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 15, 2017 | Emerson Refrigerators
The fridge seems to be working from the outside until you open the doors and its not cold anymore,there seems to be a little frost at the back of the freezer side but all food has defrosted.
Check the coils in the rear of the unit. They must be clean or dust will act as insulation, the freon won't be able to transform into gas & do its job of taking warm air out of fridge. Inspect area around fridge, there should be at least 2" on sides & enough space on top so hot air from coils can escape. Maybe compressor is not working properly. If unit is over 5 years old, overheating the coils will ruin the compressor.
Louie almond
Mar 27, 2011 | Refrigerators
I have a Whirlpool ED5FHGXNQ00 side by side.for a while it started to show signs of warming up in the fridge side.i noticed the dust built up underneath on the coils and cleaned it.i left it of*** night to...
I have a Whirlpool ED5FHGXNQ00 side by side.for a while it started to show signs of warming up in the fridge side.i noticed the dust built up underneath on the coils and cleaned it.i left it of*** night to defrost.have not plugged it back in yet.but in the freezer behind the panel there was ice build up to the right of the evaporator fan on the plastic scroll.i cleaned that upturned it on and noticed that there was very little air coming through the top air scoop vent in the fridge side.when I open the freezer door it allows more air though(probably to compensate).anyway I read alot on this issue and some say it's the defrost timer boardsome thermostat.the compressor stays pretty hotbut the freezer works fine.please help.
Jul 07, 2010 | Refrigerators
I have a Kitchenaid KSCS20QFAL01 refrigerator. The freezer side gets cold but the refigerator side does not. The difuser has been replaced but did not solve the problem. It was working fine until the...
clean all the dust off the coils on the back of the fridge and all the dust out from underneath the fridge. This was the cause of my fridge not cooling and it worked and cost me to have somebody come out to blow all the dust out from underneath. Give it a try
Jul 24, 2010 | KitchenAid Refrigerators
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
Coils freeze up in freezer and fridge gets warm
You have to completly thaw out the the freezer and dry off all moisture with paper towels then turn back on be sure to wipe the rubber seals down so no moisture is pulled out of the air between the seals of the door and cabnet.
Oct 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Air conditioner is freezing/icing up inside
needs to be taken apart and clenaned
Jun 21, 2009 | Heating & Cooling
Contents does not turn cold
The contents does not get cold even when the fridge runs in my Frigidaire FRTS5A
You could have a bad thermostat or the refrigerator could be low on Freon, make sure you clean off the exposed coils on the back of the fridge and underneath to free it from dust and dirt – use some type of a blower for underneath and the coils you can vacuum off or wipe off the coils, if not call a service tech to have a look @ the refrigerator – it might have a bad compressor
Apr 09, 2008 | Frigidaire FRT18FS5A
Haier HSB03 Compact Refrigerator Logo
1,850 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
