Home | Standard Registar | SD650 Color Copier | I have a Konica 7030
Standard Registar SD650 Color Copier
Problem for Standard Registar SD650 Color Copier
By christchu722 on Nov 26, 2008
I have a Konica 7030 photocopier. f-26-1 code came up what does this mean
we had just changed the toner cartridge
pls adv
Solution #1
posted on Nov 26, 2008
Not Rated)
fer_nan_14
Rank: Guru
Rating: 86%, 43 votes
F 26 IS RELATED ON DEVELOPER UNIT. TRY TO CALIBRATE THE DEVELOPER USING 47 MODE SUB 25,AND LET THE MACHINE RUN FOR 10 MINUTES
Was this helpful?
Yes
No
Popular Solutions for Standard Registar SD650 Color
Questions and Unsolved Problems for Standard Registar SD650 Color
Do you recommend Standard Registar SD650 Color Copier?
Answer
Answer
my canon np6035 copier will make copies just fine but has trouble getting the ''copy'' from the... (More)
Answer
I am trying to set up the printer remotely and would like to do it via web browser . Can I set up... (More)
Answer
what is the cause of the stripes left by my scanner?When I scan to my web site, there are no... (More)
Answer
My cannon mp190 misfeeds and flashes E 2 on the LED what can I do?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Standard Registar SD650 Color...:
Top Copier Experts
Rank: Guru Guru
Solutions: 721
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
