Question about Lego Media Lego Mindstorms
The Lego NXT controller has no display
This unit has been sitting in the box since last Christmas. My son wanted to learn more about how to program it and noticed that it was on but had no display. Tried removing the batteries, etc. Pushed the tiny reset button as well. No change.
When I push the orange button it makes it's startup tone and a thin single horizontal line displays sometimes (not consistent). The other buttons make noise when depressed.
  • 6 more comments
  • oliverge Dec 27, 2008
    I used my for three months now there is no display.
  • honwai Jan 02, 2009
    I have the same problem
    But it still work without display
  • Anonymous Jan 22, 2009
    I have the same problem. It might still work, but it's pretty hard to use that way.
  • alexisrivest Feb 03, 2009
    My screen is not showing too!
    It displays random lines
  • shansstl Feb 11, 2009
    Mine has been sitting in the shelf for a while and now there is no display whatsoever. Pressing the buttons do make different sounds so I dont think it is totally out of power.
  • Anonymous Apr 15, 2009
    the buttons make sounds, but the screen always remains blank.
    we have tried reinstalling everything, to no avail.
  • Anonymous May 05, 2009
    I HAD the same problem .....
    This solution fixed it.....
    http://blogs.wsd1.org/etr/?p=495
    Great ....... THANKS
    Dave
  • George Jan 02, 2013
    I used it for 1 month.now there's no display
Instructions for repair of a Lego NXT Brick with no LCD display:
-Wayne
Posted on Apr 27, 2009
    New Friend:
Why don't you buy a new one
Posted on Jan 02, 2013
Nxt programming download
Sep 2, 2011 ... The link above will allow you to download a copy of the software for your set. ... Before you install LEGO MINDSTORMS NXT Software, please ... mindstorms.lego.com/en-US/News/ReadMore/Default.aspx?id=351333 mindstorms.lego.com/en-US/News/ReadMore/Default.aspx?id=351333
Feb 02, 2012 | Lego Media Lego Mindstorms
Will not download, 1003
You will need to download the 2.1f3 patch, from here: http://education.lego.com/en-gb/preschool-and-school/secondary-11-18/11plus-lego-mindstorms-education/downloads/
When you get there, check the check box labeled "software update/patch," and find the 2.1f3 patch.
Nov 30, 2011 | Lego Media Lego Mindstorms
My Lego Mindstorms NXT 2.0 Color Sorter Machine says "green" whenever I activate the program (when there isn't any green ball under the sensor). It also usually says "try again" when there actually is a...
If you're getting the program from the RoboCenter, double check that all off the blocks are set right. If that doesn't work, open the programming software, click Tools> Update NXT Firmware. Connect your NXT with the USB (or it might work with Bluetooth...) Then click Check and download the latest firmware (or just click download). Don't be alarmed if the display turns off and the brick makes a ticking noise.
Aug 06, 2010 | Lego Media Lego Mindstorms
Can't get Mindstorms USB connection to work.
try:
  1. changing cables
  2. switching usb ports
  3. using bluetooth
  4. changing the batteries
  5. if all above fails call lego custumer support at 1-800-838-9647
Dec 26, 2009 | Lego Media Lego Mindstorms
Port A does not work
I just posted this same question, but after a little digging, I think I have the answer. There is a notice on the Mindstorm site that shows that the side motors need to be in ports B and C to work. They give a corrected diagram as well.
Port A is apparently for additional jobs, leading me to believe that it is only for programmed movement. This makes sense as you would not want your robot to continually sort or use an arm, etc. You would want it to move only when and how programmed.
Any Mindstorms pros wnat to confirm??
Dec 25, 2009 | Lego Media Lego Mindstorms
When I used my NXT the first time it makes sounds but the display does not work.
This is a common hardware problem, not a firmware issue.
Send it back to Lego for exchange or (if you're out of warranty) try this: http://johnsjavapda.blogspot.com/2009/05/nxt-screen-death.html
Oct 20, 2009 | Lego Media Lego Mindstorms
Display blank but sounds like it is working
If it sounds like it is ticking, use your Owner's Manual for Updating the NXT Firmware.
Oct 01, 2009 | Lego Media Lego Mindstorms
How do I program a NXT lego mindstorm robot supersonic sensor?
www.tweak3d.net/forums
Check this out. There are some great pics and stuff.
Hope this helps.
Sep 22, 2009 | Lego Media Lego Mindstorms
Mindstorm nxt bluetooth
I know their are programs for this .but i dont know for which phones. is yours a pocket pc
Jan 04, 2009 | Lego Media Lego Mindstorms
Lego Media Lego Mindstorms Logo
10,007 people viewed this question
Top Lego Media Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Lego Media Toy Expert? Answer questions, earn points and help others
