Have a lg42pc1da plasma tv,need to know were to get and what size bolts are needed for back of tv to attach to wall bracket
  • 4,806 Answers
If you have the manual, it will tell you exactly what size and diameter bolts you need
regards
Posted on Nov 26, 2008
Cannot attach tv mount to tv to hang on wall
Measure the back of tv where the bolts go. then look for Bracket to Fit.
Dec 04, 2013 | HP PL4272N 42 in. HDTV Plasma Television
Need 4 screws for phillips 42pf9946-12 plasma tv to fit wall bracket
Best way to be sure is call Philips customer service with the model number to get the thread type and length of these--no two sets are the same here---usually most will be available at local hardware stores if Phillips does not sell them(that would be a bit more pricey and take time).
Jun 15, 2012 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
Can a sony bravia kdl-w40a12u be put on a wall thanks
You need to use GOOD WALL BRACKETS which can hold the weight of the TV.
Also the mounting on the wall must be firm with good foundation tower bolts.
please check on the links below for some tips and ideas on wall brackets.:
TV Wall brackets: http://www.regencyproducts.co.uk/
http://www.espares.co.uk/parts/tv-and-audio/lcd/plasma-brackets/p/1459
Jul 28, 2011 | Sony KDL-W40A12U 40 in. LCD Television
HI , I'm looking for the size of the mounting bolts that would be required to mount a 32 inch Sony LCD TV.
If you are talking about the mounting screws that go into the back of the television to mount a VESA sized wall bracket, then it's most likely 5mm screws. The length of the screws could differ, depending on the bracket you are attaching, but usually 12mm or 16mm can be used. just make sure that the screws are long enough to thread into the TV completely, but not too long, or they may damage internal components.
If you are talking about the Lag screws needed to mount the bracket to the wall, then use 3/8" width lag screws 2 1/2" to 3 1/2" long, depending on how deep you have to go before hitting the wood stud.
Apr 03, 2011 | Televison & Video
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Dec 19, 2010 | Toshiba REGZA 46RV530U LCD TV
Sony bolt size
They could be either 6,7mm machine thread. You can judge by the thickness of the wall plate and the depth into the set on what length to get. Most are no longer the 1/2 in.
Nov 13, 2009 | Televison & Video
I have a Samsung LE26. I bought a wall bracket for tvs with vesa fittings. Although the holes on the backplate are in the correct place, they holes in the back of the TV are a different diameter to any...
There is no such bolt size as 4.5mm, if you look in to an imperial size bolt instead you will find that the imperial size converts back to 4mm or 5mm (M4 or M5 and nothing in the middle).
Samsung can not advise on the correct bolt for your tv model as they do not have the specification for this, this is a factory error - no other Samsung model hase this problem.
You can use PTFE tape, wrap this around the M4 bolt to give it .5mm, PTFE tape is used by plumbers to make screw threads water tight when using compression fittings.You can buy PTFE tape from any DIY store.
I have a samsung LE model, 32", I bought a TV wall bracket from an excellent website called http://www.mountright.com , they supplied with a UMount TV bracket which came with all the correct bolts for my Samsung TV.
Sep 13, 2009 | Televison & Video
What size bolts hold the wall mount bracket to the tv
The bolts that hold the wall mount bracket to the TV vary in size depending on the manufacturer of the tv you have.
The best thing to do is to purchase a wall mount bracket specifically made for your TV.
It may be possible that your owners manual will list the size of the bolts you will need.
Aug 23, 2009 | Televison & Video
What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
What size bolts for mounting bracket??
I don't know the size but, I can bet it will be a metric bolt.
Apr 17, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
