Question about GE Spacemaker JVM1640SJ Microwave Oven
Gear that rurns turntable very noisey
I've taken turntable out, and still noisey.
  • 456 Answers
It may be the fan/fan cover assembly or it may also be the magnatron, after a while of use, before faulting the plates inside dislodge and can rattle around while in use.
Posted on Nov 27, 2008
I cleaned the inside and now the turntable turns very slowly and makes a terrible noise. Any solutions on how to fix this.
Posted on Dec 28, 2008
The turntable stopped on my sears microwave. how do i fix it?
This problem is very common.
The turntable motor is defect or its gear mechanism worn out.
You'll need to have the turntable motor unit replaced.
May 10, 2014 | Microwave Ovens
Turntable not rotating
Most likely the gear is stripped. Pull up the turntable and then run it. Watch the wheel and see if it is spinning without the turntable.
Jan 23, 2013 | Hotpoint RVM1635 Microwave Oven
I need a glass turntable for my MWM925BSD-B Gourmetwave microwave.
I have a glass turntable if you need one. You can contact me at 306-285-7944
Jun 07, 2012 | Microwave Ovens
Light and fan stay on and turntable no longer work
Not sure if your model has a belt driven turntable or gear driven. The cause of your problem is most likely a worn or loose drive gear or a drive belt which is worn or has come off.
Best have this checked at your local repair shop.
Best wishes,
Graemevm
Jan 24, 2010 | GE Profile Spacemaker Over-the-Range...
Turntable has stopped turning
Remove the turntable plate from the oven. Put a cup of water inside the oven, away from the turntable drive gear. Turn the oven on and look through the door to see if the drive gear is turning. If not, then the motor is probably defective and needs to be replaced.
Nov 15, 2009 | Sharp R-303CW Convection / Microwave Oven
The turntable comes off it's track and sparks. The sparks have taken off the black paint on the inside of the door. How can I touch up the spot of the door? I rent and I can't afford to replace the thing!
Sounds like you haven’t correctly centered the ring assembly under your glass platter. Remove the glass platter, now place the plastic ring with tiny wheels in the center and move it around by hand. You will be able to tell instantly if it’s centered correctly. Now place the platter on the center hub gear.
To replace the coating on the microwave glass visit these web sites. www.partselect.com or www.applianceaid.com and enter your model number then scroll down to your part. Click to enlarge and you will be able to view the entire diagram for exact assembly. If you found any of these suggestions helpful, please rate my solution. D. Lange
May 01, 2009 | Daewoo KOR-63D5 Convection/Microwave Oven
Turntable makes grinding noise and barely turns
Unplug unit and take bottom off of it with the screws that go around the outer edge. The turnatanble motor has 2 screws and is removabe from the bottom underneath.
Sep 24, 2017 | GE JES1851 Microwave Oven
Light, turntable and fan don't work
Possibly the light bulb has blown, which has blown on a track on the board which has taken out the turntable motor and the fan. Also, there could be a problem with the door switch.
Mar 27, 2009 | Panasonic Microwave Ovens
Revolving plate no longer rotates . All else works, it continu;es to cook, but we need to move the items of food from time to time
Remove the plate, and check if the square shaped gear that normally spins the turntable is rotating.
If it is rotating, then replace the turntable gear.
If it is not rotating that means that the motor that spins the microwave turntable does not rotate, and must be replaced.
Mar 01, 2009 | Amana Radarange Microwave Oven
Noisey turntable
try pulling on the plastic drive and inspect it you just pull up on it to remove it
Jan 30, 2008 | GE JVM1440 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
321 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
