Question about Mitsubishi VS-50604 50" Rear Projection Television
50604 tv is trying to program channels how do i stop it ?
My son unplugged our tv and when I plugged it back in it started to program the channels,(tv guide +) the remote broke and we have a universal now. do I need the original remote to stop the programming or can this be done using the buttons onthe tv? I have turned the tv off for 24 hours to let the tv guide + do it's thing but it just keeps going thru the channels.
  • 4,806 Answers
Have a look here for your replacement mitsubishi remote:
http://www.electronicadventure.us/mitsubishi.htm
regards
Posted on Nov 26, 2008
How long does a TV have to be unpluged before it clears the programed channels?
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
May 08, 2017 | Panasonic PV-DF2035 20 in. TV/VCR/DVD...
Toshiba tv 40rv525u has started to change channels
My TV 40RV525U changing channels, menus itself for few months ( I use antenna).
my son tried to stop the channel scrolling by enter weird number into the channel to stop it scrolling such as 555, 777..
later, it turn on off by itself and unable to hold on a channel
I call Toshiba customer service and they ask money $25 for troubleshooting but I denied since I do not want to waste money and time.
Now, I found how to fix it myself.
In my case, something was wrong with the signal comes from the button control on the left side of the TV.
What I did
unplug the power cord.
Remove back cover.
Look into the motherboard ( biggest green at the center).
First, I disconnect a connector on the motherboard come from the IR board that receive the wireless signal control ( meaning the remote is disable).
I turn on the TV, press on Menu button on the TV side. Menu is still scrolling.
I turn off TV, disconnect power cord and connect the IR connector back to the motherboard.
I then disconnect the nearby connector that comes from the side control buttons.
Turn on the TV by remote, press menu button on the remote to check. The menu stays.
DONE.
I use electric tape to seal off the connector and let it hanging there.
Close the TV back panel
I have been watching TV for 3 nights without menus/channels scrolling.
NO AVAILABLE red message when watching DVD is no longer existed.
Hope this help someone else.
Jan 20, 2012 | Toshiba 40RV525U 40 in. LCD TV
Just bought tv and can't figure out how to run channel auto scan??? we did do it but where is this button to fininsh the process???Having major problems programming the tv
the programming should be automatic...it will seek the channels and put the active stations into memory.
when it is done searching it will come back to a channel...this can take up to 30 to do because there are several TV broadcast bands it has to look through now.
as a last resort, unplug it (power) wait a few seconds , then plug it back in and start all over (reboot)
Apr 12, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
My son pressed something and now some channels aren't working how do I reset the tv?? So I can get the channels back, example channel 4 isn't coming on!
First you could try pulling out the plug to the tv from the wall outlet and leave it out for ten minutes or so and then plug it back in and turn the tv back on(if you havn't done that already). this might reset the tv to when you first got it. you might have to adjust anything you have done to the tv. for example; fixing the color, tint, contrast etc.
The next thing you could try is, "auto channel programing". This searches for all tv stations that work.
Dec 01, 2010 | Televison & Video
Reset code for channel access
What's the model on the TV? Can try to look for the manual online. Might be worth a shot to try a capacitive discharge (unplug power, try to turn tv on a couple of times while power is unplugged, plug back in and try again). That may reset it.
Can also try going in the menus and rescanning for channels.
Apr 06, 2009 | Philips Televison & Video
Power button won't turn on tv it is just blinking
Try changing inputs. If no luck, unplug the tv, wait a minute then plug it back in. It should work ok then.
Apr 05, 2009 | RCA L40HD33D 40 in. LCD HDTV
RCA P52929 changes channel non stop
try unplugging it from the electric wall outlet for an hour then plug back in, this should reset your tv back to factory default, you will have to adjust your setings if you changed them
Jan 25, 2009 | RCA P52929 52" Rear Projection Television
I have no idea how to get channels to tune in.
In order to get a picture of what is going on you must understand what is happening. The cable box converts all channels to channel three or four depending on what it was intitially set on. That means that you have only one channel coming into the tv. So you cannot program the set. You just have to put the TV on Channel 3 or 4 and leave that alone. Do not try to program the TV. Then change the channels on the cable box. The hitch is that there are several ways to hook a cable box to your set. One is with the RF connector, which is the screw on one, into either Antenna A or B. and the other is through the AV cables which are yellow, red and white. Yellow for video, red for right audio and white for left audio. If your box is hooked to the AV input then you must use the INPUT button on the tv to select the proper AV input. On that set there are several.
Sep 19, 2008 | Mitsubishi VS-50604 50" Rear Projection...
Can't change channels!!!!
take the batteries out of the remote...now check if you can change channels manually on the big screen. if so the remote is stuck on one signal that channel u said. get a new remote. if still same trouble on big screen look hard at the buttons and make sure none are jammed. also try to get to your setup menu and auto-program the channels it should search everything and then try changing channels. new stuff alot times plugs come loose, goes back to the factory workers...not pushing them tight have a tech check that at your home.
Aug 18, 2007 | Samsung PCJ522R 52" Rear Projection...
Televison & Video Logo
102 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
