Question about Lands Phones
How to register a 2nd handset
I bought a second handset for my Uniden 2080 cordless phone in Israel. I cannot seem to locate the user manual in English online. I read that I should look it by the bar code but the only identification # I see is 200S0007749 and UUZZ01615HZ(1). My original Uniden Omega 2080 cordless phone has an answering machine. I also cannot seem to register the second hansdset. Is it base 2 that I should choose in registration?
Please help.
Thanks.
  • DudiShrage Dec 12, 2008
    I have the identical problem with a Uniden Phone in Israel and the distributor gives no clear instructions in Hebrew (Eurocom Ltc) and you can't even find the Eurocom Uniden web site.
    Bad service for a good product!!!!!
  • Anonymous Apr 12, 2009
    I had 2 phones and know the third one I got says searching and i cant get a signal
5 Suggested Answers
  • 230 Answers
SOURCE: I need to download a users manual for an Omega
http://www.retrevo.com/samples/Uniden-Telephone-manuals.html
Listed as Uniden DECT2080 I guess thats the same unit
Posted on May 08, 2009
SOURCE: uniden 2080
I have same problem
Posted on Nov 19, 2009
KingDWS
  • 1606 Answers
SOURCE: I have a new Uniden cordless phone. The handsets
You can downlaod the manual from uniden in pdf form.
http://www.uniden.com/products/productdetail.cfm?product=DECT1580-4
the -4 or -5 refers to how many handsets you set. The 1580 is the actual model number.
To register I think all you do is place them on the master pad once then on their own charger stations. On some models they come all done so you just plug them in charge them up and use them.
Posted on Mar 23, 2010
  • 102366 Answers
SOURCE: uniden omega 2000 & 200 (my model : OMEGA 2080)
http://uniden.com/index/manuals_results.cfm
Posted on Jul 22, 2010
How do i turn off the silent mode on a uniden phone, ive held down the # sign and nothings happening
Silent Mode
You can silence the ringers on the base and all handsets for a specific period of time; the answering system answers any incoming calls without playing anything through the speaker.
With the phone in standby, press and hold # on any handset. The phone prompts you to select the number of hours (1 - 9 or Always On) that you want it to stay in silent mode.
To confirm, press # or just wait about 5 seconds. The phone turns on the answering system and displays Silent Mode On on each handset.After the selected number of hours, the phone automatically exits silent mode. To exit silent mode manually, press and hold # again.
If the phone is in silent mode and you turn off the answering system, the phone exits silent mode.
Multihandset Features To use the features in this section, you need at least 2 handsets.
Your base supports a total of 12 cordless handsets: the one that came with the base and up to 11 DCX160 accessory handsets.You must register accessory handsets to the base before using them. (Handsets that came packaged with the base are already registered.)Handsets that aren't registered display a Not Registered message. For registration instructions, see p. 18, or see the accessory handset manual.If a handset was ever registered to a base, you must reset it before it can register to a new base; see p. 18, or see the accessory handset manual.Conference Calling
When an outside call comes in, two handsets can join in a conference call with the outside caller.
To join a call that's already in progress, just press Talk/flash or SpeSpeSpeaker.To leave the conference call, hang up normally; the other handset remains connected to the call.
Aug 18, 2011 | Uniden DECT 2080-5 Quint Phone
HOW DO U CONNECT THE HANDSET TO THE BASE.ALREADY TRIED THE REGISTER BUTTON,DID NOT WORK.IT CAME WITH NO DIRECTIONS,WE BOUGHT AT A FLE MARKET FOR 5 DOLLARS.
Are you sure of the model number? The D1680 should register the handset when you put it on the base for 30 seconds. (You should see Handset Registering followed by Registration Complete.) Then press Talk/Flash to check for dial tone. On this model if the registration fails, charge the battery (or replace the battery and then charge that). Then repeat the registration.
The manual for the Uniden D1680 is available here: http://news.uniden.com/pdf/D1680om.pdf .
For other Uniden phones, like the DEC1060, you need to navigate through the handset menus to find the Handset Registration command. Then press and hold the Register Handset (Find Handset) key on the base for 3+ secondsThen the base and handset will synch. (Low batteries could interfere with the process.)
For the D3288, you access the base menu for Register Accy and then press and hold # on the handset for 30+ seconds. (You will see Registering followed by Registration Complete.)
Additional Uniden cordless phone manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl .
I hope this helps.
(with a flea market phone, my first suggestion is to try a new battery for the handset. They only have a given number of recharge cycles and you do not know the history. However, sometimes the chargers do fail and a new battery will not work. In that case, the phone should be replaced. It isn't worth the cost of out-of-warranty repairs.)
Jul 01, 2011 | Uniden D1680 Cordless Phone
Uniden 2080
I have same problem
Nov 16, 2009 | Lands Phones
Will not register
Hold the power key & the * together for 5-10 seconds. De-register handset/base. Off ya go
Jul 03, 2009 | Uniden DECT 6.0 Cordless Telephone...
Uniden TCX905 cCordess phone Handsets # 3 and 4
If the handsets are not currently registered to any base, the SYSTEM RESET menu won't appear.
If the TCX905 handsets in question are actually expansion handsets from another Uniden Phone System, they are not true TCX905 handsets. To verify, remove the battery cover and battery, then look at the inside label. If it lists the model of a TRU9xxx phone system, your handsets are NOT TCX905.
Uniden unfortunately has programmed the expansion handsets from SINGLE LINE TRU9xxx phone systems to NOT REGISTER against the TRU9466. (Those same handsets register fine against predecessor model TRU8866 though).
Jun 14, 2009 | Uniden 5.8GHz Dual Cordless Phone
Uniden omega 2000 & 200 (my model : OMEGA 2080)
May 31, 2009 | Uniden Cordless Phone
Model tc25951ee3-a GE 5.8 cordless 2nd hand set states unavailable and have lost the manual for this phone. Can someone help me to solve this problem? thanks !
Try this.
Please the 2nd handset on the main base cradle for 20 seconds to re-register.
This should solve the problem.
vision05
Mar 12, 2009 | Uniden Cordless Phone
Need English documentation for Uniden Sireus 5080 phone & 0500 handsets
Here is the solution I found.
I also bought this equipment and also didn't find anything suitable in the internet, BUT a phonecall to the suplier EUROCOM brought the solution.
I called their service nr. 03-9029000 and got the English user manual as a PDF doc. by email.
Yssachar
Oct 28, 2008 | Uniden Cordless Phone
Register 2nd phone
Place handset on main base station for 20 seconds.
Sep 11, 2007 | Uniden Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
