Question about Janome Memory Craft 9500 Computerized Sewing Machine
Janome RX18S will only run in reverse
We hadn't used the machine for a while and no matter which position the switch was in, it will only run backwards!
  • Janome Master
  • 1,388 Answers
Unplug, remove the base and locate the collar on the lower shaft that is attaced to the metal rod and reverse button.
It should move freely but is probably jammed with dust and old oil.
A spray lubricant may work best, jiggle the collar by hand to try and free it, may need several applications and some patience, I have had them on the bench for several days in rare cases, some, very few, do not come good.
Have an old rag or tissues surrounding the shaft to catch overspray, and work in a well ventilated area.
Posted on Nov 28, 2008
Sewing machine runs in reverse when turned on. Will run forward when reverse button is pressed. What's wrong?
Are you using buttons on a footswitch or on the machine? If a footswitch, check to be sure the switch's cord is not plugged in upside-down. You might have to open it up and swap wires to the switches.
Apr 03, 2015 | Janome Dreamworld Table for Sewing Machine...
Where can I find a free instruction manual for a Janome rx18s sewing maching? if in doubt,google it ,there are some form of pdf file that you can download.
Oct 01, 2014 | Sewing Machines
Lost my manual to my Janome Model RX18S
Hi lweng53...
Normally this manual will cost you $20.00 on the net...but I found it for FREE
Go to the following website and download it FREE.
Give it time to download, it takes a little while
Please take time to rate me 4 thumbs ups
Sep 13, 2011 | Janome Sewing Machines
I was just given my aunt's janome sewing machine
I would really suggest that you start with this website, there is so much really good general information on sewing, sewing machines, threading up, trouble shooting, using the right sized needle and quality thread and it is all free.
I have found a pdf file of the manual on line click on the link saying "RX18S instructions", it will take a while to load as its 17MB.
Jul 06, 2011 | Janome 4612 Sewing Machine
Janome New Home mx3123 reverse button not working
1/28/13 - I have Janome Harmony 2049 that was initially sewing forward with no reverse and then after about 12 inches of sewing would ONLY sew in reverse. After spending an hour getting the plastic housing off...I was able to locate the shaft that made the reverse. It needed lubrication and after working it in and unjamming the part from the down position, the forward and reverse now work!
Huh, right? Hope it continues to work well. It is a smooth running machine, otherwise. Good luck!
Apr 05, 2010 | New Home MX-3123 Computerized Sewing...
Try changing the needle sometimes over use causes burrs on the end of a needle and always remember to use proper needles to appropriate fabrics. Change needles frequently to avoid unnecessary wear on the feed dog teeth
Dec 12, 2009 | Janome Memory Craft 10000
The icons are out of sync.
Have a sewing machine needle handy and turn the machine off.
With your left hand, press and hold /StartStop, Up/Down and reverse while switching on the machine. The screen should display little cross hairs. Using the BLUNT end of the needle NOT THE TIP, press the exact center of the cross hairs. Continue a the cross hairs will change positions on the screen. When finished, switch machine off, wait five seconds and switch back on.
Jun 27, 2009 | Janome Memory Craft 9000 Computerized...
Machine does not speed up after pressing harder on foot pedal
Hi , one of the transistor parts was open / need to visit with technical men to open the speed up pedal to replace parts , you enter zip code near you then go .
Mar 18, 2008 | Sewing Machines
Janome Memory Craft 9500 Computerized Sewing Machine Logo
460 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
