Question about Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier
I touched two speaker wires together and amp will not respond
I touched tow speaker wires together and of course the amp stopped. then i tried it about three hours later and the amp worked but i had to plug in the wires and once the wires touched the amp the amp cut out ... so do i have a fried amp or is it just resetting itself?
    Problem Solver:
  • 8 Answers
That is a very nice amp . Try not to touch (short) those wires together. But yes, the amp has protection and is shutting off to protect it.
Posted on Nov 27, 2008
2000 jeep grand cherokee with infinity system right side speakers all stopped working but all speakers on left side still work could it be a amp problem?
If you haven't already checked the balance on your steep do that if its ok then take right hand wires off off amp & concert them to right side if they work it's the amp if not you have a short in wiring on right side of car pull door cards off then make sure no wires are bare or touching together or earthing on body
Oct 29, 2016 | Jeep Cars & Trucks
Amp 230v 50hz I have blown 3 Amps so far in less than 6 mos.
As long as you are not connecting say an 8ohm amp to 4ohm speakers and the speakers are in good condition, the problem is almost certain to do with the speaker wiring. It could be that the connections are being touched together, perhaps by someone (a child) or a pet messing or moving the speakers or wiring, or some old or bad wiring. Any touching of the cable wires, will blow the amp!
Mar 13, 2014 | Bose Audio Players & Recorders
Why have the speakers stopped working on my stereo. they were working fine until i had to brake sharply then thet all went off together. the stereo is only a month old & is still connected at rear...
Hello.. I am sorry to hear you are having a problem. If you have had your speakers changed out recently, it could be that one of the speaker wires or terminals are touching a metal part of the car. What happens is the aftermarket stereo detects this problem and it shuts down all of the outputs to keep from burning up. So all of your speakers going out is a good thing because your stereo protection is working as it should. You can cut all of the speaker wires loose behind the radio and hook them back up one at a time and when the radio cuts off, that will be the bad line. I am assuming of course that you dont have them hooked to an aftermarket amplifier. Even if you have not changed your speakers, it is still a protection circuit that will detect a bad speaker as well. Sudden jolts, braking, etc. can cause a bad speaker to fault. Hope this helped!! Good luck with your venture!
20 year car audio/video installer
Bay manager
Mar 14, 2011 | Car Audio & Video
The SONY STR DE595 goes into "protect" mode upon turning it on.I recut all speaker wires & vacuumed the receiver ...unplugged,differenet outlets...etc.Any advice?
The protect thing is to do with an overload. It's more than likely that something in the main amp section has failed (perhaps a transistor on the big heat sink). The cause often speaker wiring touching together. You should look carefully at the this section for damage or burning. If you have a ohm meter you can test the transistors. If you place the probes on the terminals of each transistor and you get a responce like you had touch the probes together, you have located the source of the overload.
Sep 04, 2010 | Sony STR-DE595 5-Channel Amplifier
Overheating and shutting off
Most commonly there could be a place where wires are touching from + and minus, check all wiring to the speakers. Extra speakers would create too much load, disconnect all the speakers. Check the wires and speakers by hooking one speaker at a time back up. Of course you must turn the receiver off every time you make any changes there. Add one speaker at a time.
If it's overheating it will shut off because its likely that you are asking for more then the amp can deliver. It's protecting itself. Try turning it down and gradually increasing the volume until you find the level below shutdown. If that fixes it that's all it can deliver.
Mar 30, 2010 | Pioneer VSX-D711 Receiver
Kenwood dnx7100 in protect mode
Your receiver is detecting a problem in the speaker wiring and is going into protection mode. If the receiver shuts off due to volume level, this can be caused by a poor connection, damaged speaker, insufficient gauge wire, or connecting multiple speakers to one speaker output. The connections at the receiver and speaker should be clean with the ends of the wire twisted tightly, preventing any strands from missing the terminal. Connecting two sets of wires together to add distance should be done with terminals and insulated to prevent the wires from touching each other. If using thin wire, replace completely with heavier gauge wire; do not add to the existing length. Be careful not to push the speaker wires in too far, this will cause the speaker terminals to grip the insulation and not the conductor. The speakers being used must have an impedance within the range listed next to the receiver’s speaker outputs, normally between 6? - 16?. The impedance of your speaker should be listed behind the speaker itself.
If problems continue, disconnect the speaker wires from behind the receiver and power the receiver on. The receiver will shut off quickly if there is an internal short and would need to be serviced if this happens. If it stays on, try connecting the speakers one at a time. Replace any speaker that causes the receiver to shut off.
Thanks.
Jun 24, 2009 | Kenwood DNX7100 Car Video Player
It shuts off right after I turn it on.
Hi....
It's usually a component failure in the power amp section.
There are good tech shops in Cailfornia
Mar 24, 2009 | Denon AVR-1508 Receiver
I own a 2001 Dodge Stratus RT coupe. The stereo does not work in it. We traced the problem to the amp. We rewired the speakers together bypassing the amp and the stereo worked, but after awhile, the stereo...
Now replace the factory radio with any after market one, run the speaker wires to the location of factory amp and connect wires to all speakers.
Aug 24, 2008 | Car Audio & Video
No sound
if you had the speaker wires shorted for a while and boosted your audio waioting for a sound then your audio power amp must be busted. If this model comes with a protection fuse, then it usually blows the fuse and just replace it otherwise if it's a type that doesn't use then only reason why no sound is busted power output amp.
Mar 17, 2008 | Samsung TXK3276 TV
Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier Logo
365 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
