Hi: my cd drive door dosen't open when I push the button. Can I do anything from the outside of the computer? Thanks...Tom
    Scholar:
  • 70 Answers
If there's a small round hole on the front than grab a pin wich is long enough (at least around 5cm shold do it) and fits in it, push it inside till the drive opens.
If there's no hole than you unfortunately need to dismentle the hole drive.
Regards
Imre
Posted on Nov 26, 2008
My acer x1700 cd drive wont open.. i can hear it attempt to open. i do not have an emergency bottom or push out hole. please help many thanks
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you continue having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Oct 23, 2012 | Acer Computers & Internet
I lost my cd/dvd drive in late January. I haven't been able to get it back yet and I've tried everything. It dosen't show up in device manager, and I don't have the two registry entries. I...
Hi beachkid400,
"First, click to open the Computer Properties,
Do this, by clicking on the computer if on your "Desktop."
Or you can click on the "Start Button, in the (right pane)!
Select to open the "Computer."
Check to see if there's a DVD RW Drive (D:)?
Next, check in the "Device with Removable Storage area."
If the area is (Blank)?
Go to and select All Programs, after clicking on the Start Button.
Scroll to find the Media Disk Player.
You made need to (Setup) your "Player."
Open the Player and select to "Setup / Install.
Follow all the instructions, click on the Apply and OK buttons, when finished.
Lastly, "Restart the computer."
"Rating the solution for its helpfulness is appreciated, thanks."
Oct 01, 2011 | HP Computers & Internet
I placed a cd on my cd holder and the cd fell off inside the processor. How can I get the cd out?
Use paper clip and stick it through a small just outside the cd drive (should be next to the cd button where you press to eject the cd out). Stick paper clip through this small hole until the cd door open and gently take cd disc out. Good luck
Apr 09, 2011 | Computers & Internet
CD "door" will not open.
Push a paper clip inside the hole in front off the drive to open it manually
Apr 05, 2010 | IBM NetVista PC Desktop
Cant get my cd drawer to open i push the button and it wont open try pushing button and pry at the same time and nothing happens have emachine T3508
with your computer power turned off, use a straight mini-kabob pin (or sturdy paper clip) to manually let out the DVD drive tray. There is a little hole under the drive tray door that accepts this kind of tool device. Another option is to massage the door while trying to eject the DVD drive tray. This method requires your computer to be turned on and by selecting the proper drive (E:) from the My Computer in Start Menu, you then "Eject" and can push in on the door and on the corners, enabling the DVD drive tray to open.
Feb 02, 2010 | Computers & Internet
Cd jammed in top drive
On almost every CD/DVD drive there is a small hole next to the eject button. Take a fine needle (be careful) and with a cork on the other end to save you from hurting yourself - push the needle into the hole until the cd drawer opens. Do this with the machine swithced off. Then remove the cd.
I hope this helps you.
Aug 11, 2009 | E-Machines emachines (emachinees) CD-ROM...
My CD Drive Is Not Opening & Not Showing To The My Computer =(
if when you push the button its led flash but not opening, turn off your computer and open its door by a needle enter and push it in the ole in center of its panel under the door. whon the door open a little use your hand and open it. if the this not solve the problem there is a hardware problem :( But if the drive dosent work at all (even the led light) maybe it's the power, then open th case left door and check th power cable... I hope this helps...
Nov 02, 2008 | Sony (CDU5212) Internal 52x CD-ROM Drive
CD Rom
Well...first lets make sure the drive still can physically open.
http://i36.photobucket.com/albums/e40/freddyhard/CD13.jpg
There in the picture will show you where the manual eject button is. Use a paperclip and push the button in the hole. Once the drive is open enough for you to pull the tray, go ahead and pull it as far as it will come out. It will stop, and it shouldn't come all they way unattached from the rest of the unit.
Go ahead and take any cd or dvds that was in the drive out and turn your computer back on.
Once into windows, push the regular eject button and the drive should close the door itself. Let it sit for a second or two, and try hitting the eject button again. 9 times out of 10, that usually fixes my drives.
Hope this helps!
Jan 15, 2008 | Memorex 32023252 Internal 52x CD-ROM Drive
Cd-rom/dvd-rom door won't open
Hi!This is not a big problem...All you have do is take a pin, needle or something and just insert it into the small hole near your cd-rom drive..try this repeatedly while pressing the eject button..If it doesn't work you will have to unscrew the two screws on the right of your keyboard..doing this will give you the access to the cd tray and you can remove the cd and put it back together..
Nov 13, 2007 | Averatec 3200 Notebook
Cdr tray/door won't open
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Aug 09, 2007 | Philips CDR785 3-Disc CD Recorder
Computers & Internet Logo
David Payne
David Payne
