Question about Singer 6510 Sewing Machine
Machine will not zigzag
My machine will sew a straight stitch, but not a zigzag. The needle becomes stuck in the down position. Any solutions?
  • Singer Master
  • 665 Answers
The hook is located where your bobbin is. Remove the bobbin and place your machine in the most extreme zigzag position. Turn the wheel manually and watch the needle when it goes into the bobbin area. The hook (sharp) should pick up the upper thread. If it doesn't then you will most likely need to advance the hook slightly. If you don't know how there are good instructions that are free in the internet.
Posted on May 03, 2013
Depends on what kind of machine you have. Most of the time incorrect threading is the problem. The needle may be not be tightened in properly, or you may not have selected the correct sequence for zig-zag. Hope this helped a little.
Posted on Jan 09, 2007
Where can i get straight stich needle plate for singer 5430 or is there anything compatible?
You really do not need a straight stitch needle plate because you can sew straight or zigzag stitches with the plate that came with your machine. Biggest advantage is that you do not have to change the plate to sew. Many people forgot to change it and broke needles when sewing zigzag.
Jan 29, 2018 | Singer Sewing Machines
Bernina sewing machine
Hook don't catch thread
Possible reasons:
  • bent needle
  • needle/thread combination is not correct. When sewing, the thread should travel smoothly down the long groove on the front of the needle. (see user manual, chapter "Threads and needles")
  • stitch plate damaged
  • wrong hook timing (sewing machine needs to be taken to a BERNINA dealer for servicing)
Aug 12, 2014 | Sewing Machines
Can I go from straight stitches to zigzag stiches and back in the same seam?
Hi Susie,
I can't tell whether you mean straight stitching and then turning your work 180 degrees to stitch atop the straight stitches in zig-zag, or continuing around the corner of your straight stitched side using zig-zag. But you can do either. You can mix up straight and zig-zag stitching at will.
Just ease up to a stop, ensuring the needle is positioned down inside the work when you stop.
Lift the foot.
Adjust to your desired stitch setting.
Lower the foot.
Turn the wheel toward you manually to ensure the stitches will be placed where you want them, and
Slowly engage the power again (via foot or thigh lever).
Hope this helps.
May 14, 2014 | Singer 3116 Simple
Singer sewing machine needle moving to the side after it's in the fabric for a zigzag stitch
If you can grab the hand wheel and move it right and left, then it probably needs a plastic collar that goes next to the left upper shaft bushing.
If not then the cam timing needs to be adjusted.
Mar 13, 2014 | Kenmore 15516 Mechanical Sewing Machine
Can't do zigzag on 830
You need a repair shop - sounds like a part is worn out.
Jun 09, 2017 | Bernina Sewing Machines
My Activa 140 Sews only straight stitch,very slowly,can not change needle prosition.have had it serviced 4 times for the same problem
I am willing to bet that your sewing machine's computer battery has died. A lot of people don't realize that these machines are computers... there is a small battery in all computers it has to be replaced now and then. (I think they call it an "eprom" battery.)
Btw.. I would NOT have paid 4 times for servicing on the same problem. If they didn't' fix it the first time... they can try again... but I won't pay for nothing.
Feb 25, 2013 | Bernina Activa 140
Zigzag stitch not catching
try these suggestions and see if they help
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Oct 19, 2012 | Brother CS6000i Computerized Sewing...
The guy is right, dust kills the moving parts. try oiling the shaft that holds the needle up about 1/2 way and then run on straight stitch with no thread to work in oil, do this several times till you feel that it runs smoothly and you have a little movement side to side as this is necessary for your zig-zag. if that does not work it may be a cam or belt in the top part that needs replacing and you will need the repair to tell you that. I asked them to give me a quote before any work was done so I knew what I was up against. I love my machine so it was worth the 200.00 to get the parts replaced. It will sew anything cause it is a older model with metal rather than plastic parts. hope this helps good luck
Jun 17, 2017 | Singer 3116 Simple
Only sews a straight stitch
NEEDLE BAR HEIGHT
With the pattern selector dial set at maximum zigzag width and when the point of the rotary hook exactly meets the right side of the needle in ascending travel of the needle bar from its lowest position, at the right needle drop position, the distance between the upper edge of the needle eye and the race of the rotary hook should be 3.3 ± 0.3 mm.
You also need to look at the timing
HOOK TIMING
With the needle bar swung to the right at the maximum zigzag width, the amount of ascending travel of the needle bar from its lower position to the position where the tip of the rotary hook exactly meets the right side of the needle should be 1.7 ± 0.3 mm.
Jan 15, 2008 | Sewing Machines
Singer 6510 Sewing Machine Logo
151 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
