Question about Magnum 257 CB Radio
Magnum 257 it will not transmit on lsb or usb it will on am and f
Magnum 257 radio it transmits on am and fm but it will not transmit on lsb or usb transmit bars do not show up on the display on the radio. please help me.
  • 1 more comment
  • fredp757 Jan 13, 2009
    Same problem here, repair man said he couldn't fix it, instable circuitry, AM/FM is fine, but BLU, unless you blow in the mic doesn't output any power...
    Will get it back, but it's almost useless without the SSB now...
  • fredp757 May 11, 2010
    Hi All,
    Don't know how Wecur4 managed it since, on my side, I had some feedback from Magnum Europe in Holland. The symptom we experience is due to the fact that the mic pin6 that has voltage has been grounded, and some component consequently burned, I passed it over to the repair man, but no news so far, will keep the post updated.
    BR,
    Fred.
  • Anonymous Mar 23, 2014
    Bad static and squealing on transmit
With SSB you have to put audio on the carrier you cant just key the microphone and expect it to output a signal unless you talk into the microphone at the same time this is how SSB works.
So if you talk and the meter starts to move then its ok, if you talk or whistle and nothing moves then the circuit on the SSB side of the unit is faulty.
Posted on Feb 07, 2009
Been a long time since my first post, but it's been moving all over the place.
First to the French Magnum certified repairman, confirmed the instability issue, not able to fix it. Then I had to send it to Holland to Avera, which is the European rep. for Magnum. Unable to repair too, so they're proposed me an exchange... a long way to get a working set.
Now new worry, audio peps not always there, depending upon temp. (radio's in the car), the mic either works correctly, or it 's difficult to get some power out of it ...thinking about trying another mike, will update the post once done,
73 to all
Fred 14 FAT 138
Posted on Apr 09, 2010
    Novelist:
    Champion:
  • 211 Answers
YOu need to check the finals on the sidebad side. Sounds like they are probably bad.
I hope this has helped.
Ed Meshechek ( Radio Man )
NC Electronics
PO Box 1696
414 6th St
Mills, Wyoming
82644
307-266-4675
wyoed1@aol.com
Posted on Dec 03, 2008
No transmit on usb.only recive but all works on am and lsb.1stGen.pres.whst
the transmitter section of the radio needs to be aligned you need to look for a cb shop its nothing you can fix on your own
Mar 28, 2014 | Radio Communications
Usb audio
need to put it on an oscillascope and frequency counter and have it aligned. even taking to a shop should be less than $45 to have it fully done.
Mar 21, 2014 | Magnum Radio Communications
NEED TO WIRE LESON MICROPHONE TO MAGNUM 257
Notice the black mic plug has the numbers it is solder by numbers. Used rosin core silver solder radio shack sells it.
Mic Wiring
Stock
1-Shield (ground)
2-Yellow (audio)
3-Red (transmit)
4-White (receive)
Astatic
1-Shield & Blue
2-White
3-Red
4-Black
Yellow NC
Turner Roadking 56
1-Shield & Red
2-White
3-Blue
4-Black
Yellow NC
Sadelta the is a BASE mic
1-Shield
2-White
3-Brown
4-Green
Oct 02, 2011 | Magnum 257 CB Radio
Magnum 257: if I push the microphone button for emission , TX appear on the screen in the top right but does not appear the bar signal on the bottom therefore not be heard.If I stop and turn on the radio...
Hi livi, my name is John. Welcome to FixYa. If you have a MIC GAIN, turn it to MAX. If no avail, try a different mic. Are you saying you have no receive, turn the RF GAIN to MAX and the SQUELCH all the way to the left. Let me know. Thanks for choosing FixYa.....John
Dec 07, 2010 | Magnum 257 CB Radio
Diesel #8-32 echo power mics
cobra 4 pin is pin1= shield, pin2= mic audio (usually the shield is wrapped around the mic audio wire).pin 3= transmit or push to talk usually red or white whichever isnt wrapped with the shield, and pin4 = receive or speaker complete
5 pin cobra=1-Audio 2- Shield 3-Receive 4-Switching Wire 5-Transmit, you can jump pins 4 and two
Dec 21, 2008 | Magnum 257 CB Radio
Magnum 257 No Audio Being Transmitted
Hello.I have a similar situation on a Magnum 257 HP operating on SSB (AM and FM works fine). If i Transmit it works fine, but when i release the Mic button (after TX), in the bottom side were the RX level should be, it appear somth like a signal level 3 to 5 (constant and continous), but i can't get any reception at all. Only if i turn the TX power level to MAXand i transmit, then it goes back to reception, but not every time. Somtime after TX i need to push the mic button 2-3 times to make it recive somthing, but this wors only if the power level is over 60-70% an i repeat, only on SSB.Can i get some help with this issue?
May 10, 2008 | Magnum 257 CB Radio
Operator/instruction manual
ghilger, First off, has your radio been converted to open up all the other channels(including CB)?? That has to be done first, or it's locked in the ham freq's. I think the factory manual is pretty well detailed, but i've been around radios my whole life. The mode button does the changing from am/fm/usb/lsb.Here's from the manual;
MODE: Operating Mode. Press the MODE control to select the operating mode. The operating mode is indicated on the liquid crystal display: am, fm, usb, or lsb.
* See, there is 2 different functions for each button. One set of functions are by just pushing the buttons, the other set of functions are obtained by pushing the function button first. The function button is activated by pushing in on the clarifier knob.
*Here is for saving of freq's;
Memory Save. To save in memory a specific
frequency and operating mode, select the desired mode and rotate the FREQUENCY control to the desired frequency. Press the FUNC button, and then press the M.SAVE button. S will appear on the LCD next to the frequency. While S is displayed, immediately press any of the memory channel buttons (1 - 5). The mode and frequency is now saved into memory. If the S indicator disappears before you press the memory channel button,
the information will not be saved and the process
must be repeated.
M.LOAD: Memory(Recall). To recall, any of the saved memory channels press the M.LOAD
button. L will appear on the LCD for several seconds. While the letter is displayed press the desired memory channel button (1 - 5). The programmed mode and frequency will be displayed.,
If you have any more questions about the radio, repost them here and I'll try to walk you thru them. The radio is a very good ssb rig, especially set up with a power mic. Hope this helps,, Mechanic
Feb 03, 2008 | Magnum 257 CB Radio
Radio Communications Logo
374 people viewed this question
Top Magnum Radio Communications Experts
Jim Goldsmith
Jim Goldsmith
James Walker
James Walker
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
