Question about APC BACK-UPS NS (BN1250LCD) UPS System
Error message flashing F01 on APC BACK-UPS NS (BN1250)
  • 19 Answers
SOURCE: APC Back-UPS ES 500: green light flashes&continuous warning tone
On this unit, the likely culprit is the battery and that it needs to be replaced.
With that, you may want to think about the pros and cons of replacement versus buying an entirely new unit.
This unit is a relatively low end ups and the surge supression uses MOVs that wear out with repeated absorption of energetic spikes. That's why the better (and higher cost) UPSs and surge suppressors don't use them. They're not really that good anyway due to their relatively high transient impedance. The better equipment uses a "transorb" -- basically a back-to-back high voltage zener diode optimized for low breakover impedance and high instantaneous power capability. Unless the transient exceeds the design parameters of the circuit, these do not wear out and do not degrade. That being said, I will assume that you would likely replace this unit with a similar one.
The flashing may not be the battery at all and may be the charging circuitry, thus your new battery may not live very long (half the life that you would expect.
Many batteries out there are refurbs and have issues as all used parts do.
If you contact APC, they will likely give you a 35% discount on purchasing a new product.
The difference in price in the battery replacement vs. ups replacement at this level may only be a few dollars more.
I promise that I am not a UPS salesman, I just deal with many on a daily basis; therefore I am giving my two cents to try to thelp you avoid problems a year from now.
Posted on Dec 30, 2009
Testimonial: "Outstanding answer with right amount of detail. I swapped battery with identical APC UPS that I have and vfd that battery was cause of warning tone."
  • 8 Answers
SOURCE: apc ups flashes red light to replace battery, but battery is new
i think by replacing the battery has not been the solution to the problem
u need to check the battery charging voltage when turned ON with main electricity, if no voltage present from charger, there is no question of battery getting charged and also once the battery is down with charge it may not re charge hence the indicator and alarm.
recomended to nearest service centre
Posted on Sep 13, 2008
jvpacoin
  • 91 Answers
SOURCE: Overload light in APC RS 800 UPS
it seems that the inverter circuit of your UPS is dying. the solution here is you have to open up the UPS and check the inverter circuit. to make easier, check the power mosfet if its leaking.
Posted on Aug 14, 2009
Geekman
  • 32281 Answers
SOURCE: APC BR1500LCD Fault F01
This is a printout of the fault codes
System Fault indicator is on and all other
front panel indicators are flashing.
Internal UPS fault. One of nine Internal UPS Fault Messages is displayed:
F01 - On-Battery Overload F06 - Relay Welding
F02 - On-Battery Output Short F07 - Temperature
F03 - On-Battery XCap Overload F08 - Fan Fault
F04 - Clamp Short F09 - Internal Fault
F05 - Charger Fault
Posted on Nov 23, 2009
  • 356 Answers
SOURCE: All battery charge lights flash simultaneously.
THIS seems the be the answer to your question. Hope this helps
Posted on Apr 29, 2010
Problem with a APC Back-UPS BR800I with AVR The
Hi Petkov,
It seems that Schneider / APC has a remedy for this on their forum:
http://forums.apc.com/message/35667
Reply or call if you need more assistance with this -- 407.380.9200
Oct 08, 2013 | Computers & Internet
APC SmartUPS X (SMX1000)- "AVR Relay Weld" error message
I had this exact problem after a major power out: Fault, call support: AVR Relay weld.
I fixed it by resetting the UPS: Remove battery connect at rear of UPS (it is marked, just unplug the bat connect tab). Plug the UPS back in, and then turn on. Let it power up... it will tell you it needs a battery. Next, power it down and unplug. Plug the batter connect back in (see rear). Plug in the UPS.. power up. Presto.. it is reset. If it is NOT reset, there may be a real 'relay weld'.
May 13, 2013 | Computers & Internet
APC Smart-UPS 1500RM (sua1500rm) UPS System - charge lights flashing after changed battery
For APC smart-ups models, you need to do a UPS calibration after you change the battery. You need to change the UPS parameters to removed the flashing lights on the front panel of the UPS, usually you need to change the 0 parameter to its default state to remove the flashing lights.
Mar 16, 2012 | APC Smart-UPS 1500RM (sua1500rm) UPS...
Smart apc ups error with all indicator flashing .
APC Smart-UPS 1500VA has an error. All it's pannel lights blinking. what is the best possible solution to this?
Jun 14, 2010 | APC Smart-UPS 1500VA Shipboard...
F05 - Charger Fault
Nov 23, 2009 | APC BR1500LCD UPS System
APC Smart-UPS 1000VA UPS System calibation problem
If battery charge indicator is flashing it should be UPS calibration issue, If all the LED indicator is light up in the front panel and UPS still can go online on battery mode you just need to replace the board on the front panel and the light will just back to normal state.
Apr 25, 2009 | APC Smart-UPS 1000VA UPS System
Desk top APC UPS ES750 not communicating
Here is an answer I got from APC when one of my client got the same problem as you did:
The error message would pop up if the link between the computer and the UPS is weak. I cannot rule out a problem with the cable or the UPS. In order to confirm the same please try the following steps which might help :
1) Ensure that the USB cable is properly connected to the USB port of the computer.
2) If the PC was powered on before the UPS, communication will not be achieved until you disconnect and reconnect the USB cable to the host. In this case, you need to disconnect and reconnect the USB cable to establish communication.
3) Some other software is polling your USB port for another device, thus causing the UPS software to temporarily lose communication with your UPS. If this is the case, you would need to shut down that application.
4) If you have any other USB devices connected to the PC, disconnect them and then try plugging in the cable.
If the issue persists, please visit the following link which lists few troubleshooting steps :
http://nam-en.apc.com/cgi-bin/nam_en.cfg/php/enduser/std_adp.php?p_sid=oXhRFGEh&p_lva=&p_faqid=2923
Dec 13, 2007 | APC Back-UPS ES 725 Broadband (BE725BB-TU)...
APC communication error message
Try going to the properties of the driver and select do not check or check every X mintues.
Try this thanks J
APC BACK-UPS NS (BN1250LCD) UPS System Logo
9,048 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Alun Cox
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
