Pool & Spa Logo
jim anasta Posted on May 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I remove impellor from a/o smith 7-181327-03 pool pump
Screw on type rusted
Anonymous
Level 2:
Scholar:
  • Expert 111 Answers
  • Posted on May 29, 2012
Anonymous
Expert
Level 2:
Scholar:
Answers
111
Questions
0
Helped
69409
Points
122
If the impeller is fused onto the shaft by rust or mineral build up the chance you will be able to remove it with out destroying it are slim. You're likely going to need a new impeller and shaft seal kit, so I'd suggest getting them before your try to remove the old impeller.
First you must remove the water/plumbing and the strainer basket assembly or pump faceplate if applicable to gain access to the impeller.
Step two, on the backside of the motor (opposite side of impeller) you will find the back end of the motor shaft. This end of the motor shaft has a slot in it so that you can insert a large flat screw driver. This will help you to hold the shaft while you try and unscrew the impeller. fyi your pump might have a plastic housing on the back of the motor which you should remove to get to the back of the shaft. This is best way to remove the impeller but its likely to be a struggle if there is rust on the shaft. Good Luck
4 Related Answers
Pete
  • 106 Answers
  • Posted on Feb 24, 2010
SOURCE: removing pool pump impellor
Separate pump and motor. Remove diffuser. Remove back cover from motor. Motor shaft has either a slot for a screwdriver or a flat area for a wrench. Hold shaft and unscrew impeller.
john224
John Prohaska
  • 1378 Answers
  • Posted on Jan 18, 2010
SOURCE: I have a AO Smith Century Centurin Swimming Pool
A.O.Smith USQ1152.
MOTORWIZJ
Jay Finke
  • 1397 Answers
  • Posted on Aug 23, 2010
SOURCE: where to find replacement parts for AO smith pool pump motors
TRY YOUR LOCAL POOL PUMP MOTOR REPAIR GUY... NEW ARE HARD TO FIND AND CRAZZZY $$$ HE WILL HAVE GOOD USED PARTS CHEAP . IT'S THE GREEN THING TO DO. FIX -REPAIR.. GOOD FOR YOU, I'M PROUD OF YOU.. GOOD LUCK AND VOTE FOR ME...JAY
macdirk
Derek
  • 116 Answers
  • Posted on Oct 03, 2010
SOURCE: Pump seal is leaking water. I removed the screws
This is from one of my previous posts, may be some extra steps, but should cover what you need... Turn off the electric first. Now split the pump in two by removing the large clamp or 4-6 bolts holding the two halves together. (not the 4 bolts holding the motor to seal plate, but the the bolts holding the seal plate to the seal plate housing). Once you remove the clamp or bolts, the motor with seal plate, diffuser, and Impeller can all be pulled back away from the pump. Then disconnect the electrical from the motor and you can pull the motor with the seal plate, and impeller all the way out and work on it. To get to the impeller, you need to remove the diffuser (plastic housing that goes around the impeller) usually by a series of 3 to 6 small screws. To remove the impeller you need to lock the motor and unscrew impeller. Depending on the motor, you remove a cap in the middle of the tail piece and hold with a wrench, or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under the thermal overload switch, or removing the capacitor for even easier access. Once you've locked the shaft, you can just unscrew impeller. If the impeller has a bolt or screw in the middle remove that first. this screw will be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you unbolt the motor from the seal plate, pull the seal plate away from motor (this removes half the seal), and then pop the other half of the seal from the seal plate. Make sure to replace the shaft seal, and use a tiny bit of pool lube on the rubber parts when installing, but keep the white ceramic, and black graphite surfaces 100% free of any dirt, grease, etc while working with them. Installation is pretty much just the reverse. Install half the seal into the seal plate. Install the seal plate onto motor and bolt into place. Install other half of seal onto shaft. Screw impeller onto shaft and install screw (if one was there to start with) in center of impeller (reverse thread). install diffuser over impeller make sure it is centered and doesn't rub the impeller hub. Install new diffuser and valute o-rings. Hookup wiring before re-attaching to rest of pump. Clamp or bolt back together. Pour plenty of water into pot to prime and flip the motor on for a sec or two. Pour some more water. Install pot lid. You should be good to go. Keep in mind there are many different pumps and some variations to the above instructions, but the above should cover most situations. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Can my shaft spin and not my impellor. how can i check
the impeller is usually screw onto the shaft or the shaft has a D (flatspot on one side to lock impeller) so no, the shaft cannot spin without the impeller moving unless the shaft is snapped or impeller is totally stripped (ive never seen either)
if the pump is running but not pushing water, take the wet end off and make sure there is no debris (leaves, worms etc) caught in the impeller fins. you will be amazed at how much that will reduce the performance of a pump
How to remove impeller
i think they screw on and the screw only locks it in place
TDA200 Recirculating pump how to replace impellor
There are a number of screws on the pump housing opposite the motor that can be removed to open the pump and expose the impeller. Some pumps have a screw into the center of the shaft that helps keep the impeller from spinning off the shaft. It often is a left handed screw. Once any center screw is removed the cover on the other end of the pump should be removed to expose the end of the motor shaft. This end of the shaft should be held solid with a wrench while the impellor is unscrewed. These threads are usually right handed. The process can be reversed with a new impeller. I hope this helps.
Aug 13, 2011 • Pool & Spa
How do I remove the pule off the pump? My pump shuts off, I replaced the capacitor and it still shuts off. I figure that I need a new pump but I cannot even remove the pule. ;-) Thank you in advance...
Ok the type of pump is helpful , but here is how most all impellers come off, there MIGHT be a screw in the center of the impeller IT SCREWS OFF TO THE RIGHT ! the impeller turns off to the left.. assuming a PULE is the impeller ?..Jay the pool pump motor repair guy in longwood FLORIDA .. remember to vote for your favorite FIXYA guy ..thanks J ;-)
PS I would suggest you search, look in your area for your local pool pump repair guy and have him do the repair, if you break somthing parts can sometimes be hard or impossible to find !
1helpful
Removing pool pump impellor from motor shaft
Middle arm isn't washing, need to check for debris.
How to remove the access panels....
There are many different styles of dishwashers built today. One of these should point you in the correct area's to look for the screws that hold the access panels on the dishwasher. Remember, remove power first.
The most common configuration of the access panels used today...
This is the newer "over sized" door, looks like a one panel front, but there still is small access panels on the very bottom....
Some Asko Dishwashers....
2 Torx # 20 screws hold the toe plate on. Once toe plate is off, 2 Torx screw hold the lower panel on and the 2 brackets the hold the toe plate on have a springy locking tab, press the tab away from the bracket and the brackets will pull straight out. The service panel has 4 or 6 Torx screws holding it on, 2 are pointing up in the corners.
Motor and pump assembly screw and impellor help....
One of the most common question that I get on a dishwasher repair is "how does that motor and pump impellor screw come out?"
Inside many dishwasher pump assemblies is a screw that goes through the upper impellor and screws directly into the motor shaft. Since the motor shaft and screw are made of metal...you guessed it...they can / will rust. The screw can rust and become very tight and difficult to remove!! These screws are normally a right ( regular ) hand thread, socket or nut driver can be used to remove the screw. One hard thing to do is to hold the impellor still so the screw can be removed, they often just turn together. The impellor may be jammed with a screwdriver to hold it still so the screw can be removed...sometimes the impellor can be help still by placing a rag on it and hold tight with your hand, the rag will help prevent a sharp edge on the impellor from cutting your fingers. The odd time that screw is too rusted into place, soaking a little rust buster or 3in1 oil on it over night may help loosen it. Sometimes trying to tighten the screw a little at first will help break it free. There are some tool that can be purchased to help hold the impellor stillso the screw can be removed, these are only for a few models and pump assembly styles.
Anymore questions ask.
3helpful
The pump only hums when plugged in. Any suggestions?
It sounds like the impellor is locked. Take this part off and then see if the pump is turning but before you do, some of them have a big screw driver slot in the shaft. If it does, turn it to see if you can free the impellor. I have done this many times and they will continue to work for years after. They just get stuck from rust, etc. and also being frozen a little. Hope this helps.
Dishwasher makes a high pitch whine when it runs
instead of motor check out the motor impeller that can make the high pitched noise if rusted or cracked. ------------- Motor and pump assembly screw and impellor help....
Inside many dishwasher pump assemblies is a screw that goes through the upper impellor and screws directly into the motor shaft. Since the motor shaft and screw are made of metal...you guessed it...they can / will rust. The screw can rust and become very tight and difficult to remove!! These screws are normally a right ( regular ) hand thread, socket or nut driver can be used to remove the screw. One hard thing to do is to hold the impellor still so the screw can be removed, they often just turn together. The impellor may be jammed with a screwdriver to hold it still so the screw can be removed...sometimes the impellor can be help still by placing a rag on it and hold tight with your hand, the rag will help prevent a sharp edge on the impellor from cutting your fingers. The odd time that screw is too rusted into place, soaking a little rust buster or 3in1 oil on it over night may help loosen it. Sometimes trying to tighten the screw a little at first will help break it free. There are some tool ( see below ) that can be purchased to help hold the impellor still so the screw can be removed, these are only for a few models and pump assembly styles.
WLP seal tool helps center and install the pump seal
Frigidaire seal - impellor remover and install tool
Once the screw is removed, the next obstacle is the impellor can also get stuck onto the motor shaft. Many times I have to break off the old impellor. A sharp blow straight down with a hammer and flat screwdriver will often crack the plastic impellor...careful not to damage the pump body! If the motor shaft has indeed rusted, clean it up really good with sand cloth.
Removal and installation of diffuser and impeller kit
All jucuzzi pumps are some of the most difficult to repair.Pump front should seperate from body(volute) of pump by means of screws, or some kind of band. Diffuser should have ss screws, or
be held in plsce by notches or both. Impellor spins counter clockwise to come off. Can only remove impellor with impellor wrench, or very strong hand. Rear of motor must be held in place with normally a 7-16 wrench, allen head wrench or screwdriver. Depends on manufacturer of motor. Then impellor can be removed!
Should replace shaft seal under impellor. Can seperate body of pump from motor by turning four outer bolts on back of motor. Must mark rear cover of motor so lines up exact for reassebly. Ussually 1/4 inch socket wrench.Seal can be pushed out from back to front with the corrrect size socket and a very light hammer.
Try to factory Jacuzzi seal, they are better than aftermarket.
Coat rubber on seal with light silicone, and press back into place without touching or marring seal face. Best way is use other half of seal (spring piece) to gently but firmly reseat seal. Examine body from rear to make sure seal seats. Reassemble as taken apart, or just take to a qualified service tech at a well established pool/spa place. Kirk
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
