Question about Sanyo PLV 70 Multimedia Projector
Horizontal lines traveling up screen
I have had the plv-70 for about 2 yrs. It recently developed a problem where horizontal lines slowly move up the image. Nothing in the Sanyo troubleshooter about such a problem.
Sounds like a ground loop on the video signal. Try using a ground lift on your computer and or your projector.
Posted on Dec 05, 2008
SOURCE:
My Z1275 has developed intermittent horizontal lines on the view screen when the camera is moved, and on images some times. Get good images if I use tripod and shutter delay. Looks like loose connecti
When having bright lights on a dark background, you can have horizontal lines. That is supposed to be normal. but the camera should give good pictures in bright light. Try setting the camera in automatic. most of the time it is the green camera loge on the mail dial.
Jul 21, 2014 | Kodak EasyShare Cameras
Dark horizontal line traveling across the screen vertically
on tube tvs bestto go on main bord look for hairline craks on soldering ok redo them nice it will light up happend to mine also older model thx nick
Feb 06, 2008 | Sony FD Trinitron KD-34XBR960 34" TV
My tv has thin black horizontal lines on screen while showing picture. this is not caused by cable since it happens while using ps2 or dvd player. I recently moved, but it was working fine after the...
that could be a sign of a bad panel. my experience is that these panels are more expensive than the tv itself, but might be worth looking into since I've heard about prices coming down
Mar 27, 2010 | Philips 42FD9954 42 in. Plasma HDTV
Loogking for digital zoom procedure
move the projector back until the image fills the screen.
Aug 20, 2009 | Sanyo PLV 70 Multimedia Projector
Picture becomes fuzzy and lined, clears with a sharp rap on the top of case.
probably a bad connection on the circuit board inside that heats up over time. the tap on the top probably moves the connection just enough To make it good for short time.
Feb 02, 2018 | Hitachi 60UX54B/55K 60" Rear Projection...
Black horizontal line across the middle of the plasma TV screen
It could be a defective Y-Buffer board, or a defective Plasma panel.
Oct 25, 2017 | Pioneer PDP-425CMX 42 in. Plasma...
Line on the Picture Screen
panel t-con parts n/a will most likley be replaced.
Nov 03, 2008 | Protron PLTV-32 Television
Video flickering
Horizontal lines are either caused by the main logic board, a dammaged screen or by the main x and y drivers. Hard to determine which one it is, but somthing is getting hot which is causing the problem. My guess is the main logic board.
Apr 03, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Black horizontal lines
Sounds as if you have a bad capacitor in the horizontal deflection or video circuitry. You can spot a bad capacitor in circuit with a ESR meter.Hope this helps.
Jan 16, 2008 | Mitsubishi TS-5545 55" Rear Projection...
Sanyo PLV 70 Multimedia Projector Logo
604 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
k24674
Rob Hill
Rob Hill
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
