I'm trying to burn an audio CD, I just bought a new pack of blank CD's the same exact ones that I've always used. I'm trying to burn through Musicmatch Jukebox-which I've also always used, but the CD's don't seem to be registering in the drive at all-Musicmatch tells me to "Insert a blank disc into drive"
    Novelist:
  • 183 Answers
Click on Start ==> RUN ==> Type REGEDIT ==> Click OK.
A registry Editor Window will Open. then follow the Path given in Picture. Once you delete Upper and Lower filter restart your computer and then Try to Burn Cd. you will be able to Burn CD.
Posted on Nov 27, 2008
Getting a C 13 70 disc is dirty message only for DVDs that I'e burned recently. I bought a new pack of blank DVDs, the same kind I've always used, but every movie I burn on these new ones, they...
Hello, welcome to Fixya!
Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.
The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Nov 03, 2011 | Sony DVP-SR200P DVD Player
When I try to play a CD I get an "err" message. Using store-bought CD's, not ones that have been copied. I have the Emerson PD6559BL portable CD player Love this CD player so I hope you...
Extract from your cd player manual:
"This CD player can play normal CDs p/us CD Recordable (CD-R)
and CD Rewriteable (CD-RW) discs. However the playability of CD-RIRW discs
may be affected by the type of software that was used in 'ripping' the tracks from
the original discs and 'burning' the tracks onto the blank media. Playability may
a/so be affected by the quality and condition of the blank media you use for
recording. 100% compatibility cannot be guaranteed, this is nof an indication of
any problems with your player."
So try to burn the disc with another software or buy different CD-r.
You also want to make sure that you Burned the tracks as audio files and not MP3 file, because your player can not read MP3s.
Hope this helps.
May 27, 2011 | Audio Players & Recorders
Mp3 files will not burn
No imation brand is known for problems but maxell usually work great i suggest cleaning the cd burner try compressed air can spray out the cd burner with the door open you may have dust on the laser lens...
Feb 05, 2010 | Maxell CD-R 80 Minute 700MB Media...
I have just brought a new pack of blank CD's, i am
Its a common problem with CDs. Check that your CD drive can PLAY CDs. If so either the CD drives optical head is dirty or your CD pack are low quality. CDs damage real easy. Try putting another CD, another brand or you must use CD doctor-something like that. Did that help
Mar 10, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
Procuring the blank audio cds in india for GF 350.
Does this GF 350 turntable use any special CD's ?. please intimate the name and address of the dealer whom whom you purchased this as I also intend to buy this turntable.
Nov 22, 2008 | Teac GF-350 CD Shelf System
Error message E-8302
It sounds like you might have problems with your CDs. If you are burning CDs on your computer to play in the CDJ, you need to remember that it will only play audio (wav), or MP3 files. Also, blank data CDs are cheaper that buying audio / music CDs. When you burn your CDs to play back on the CDJ, you have to be sure to burn them as wav or mp3. AAC, MP4, OGG and the other formats will not work in the player. When you burn the CD, ALWAYS burn at a slower speed than what the computer will automatically burn at. You will have to manually set the speed yourself.
Personally- when i burn my tracks CDs for my CD book, I use trusted name brand blank data CDs such as Memorex, Sony, TDK, Fuji, Imation. I burn them as AUDIO ONLY. To avoid any reading mistakes that could happen with any given CD player, i NEVER burn track CDs as mp3. When i burn the CD, i set the writing speed to 24x, 30x, or 32x. I recommend that you DO NOT burn your CDs at any speed faster than 32x. From my experience, that is the fastest and safest burning speed. If you do these things, and you still have problems with the E-83 02 code, then it will only have to be the kind of CDs your using to burn, or your CD burner in your computer. Notice how i didn't mention Maxell CDs up top. 3 months ago, i bought 2 spindles of Maxell data blanks on sale for $9.99 each. I was happy i got them that cheap, but the CDs themselves were no good. Recording everything the way i do, they had popping noises and scratching sounds through-out the disc. I gave the spindles to my neighbor. He was happy to get blank CDs free. I WILL NOT say that Maxell makes a bad product: I still record on cassettes and Maxells are one of my top 3 choices for blank chrome tapes. But the discs i bought were just a bad batch. Maxell is still a trusted name for blank tapes with us older DJs that started out with recording on tapes before the CD format became way cheaper and affordable.
Try burning your discs as audio only, and burn them at 24x, 30x, or 32x ONLY. Buy better brand name data CDs, and you should have no problems. If you use my method as an example, and you still have problems, then you need to get a new CD burner for your computer. They are always cheaper at Staples or Office Depot. Hope **** works out for you : D
Nov 08, 2008 | Pioneer CDJ-800 Turntable
Error message
Sep 17, 2008 | Pioneer CDJ-800 Turntable
Cd burn
Either the drive is bad or your using the wrong type of blank dvds.Try using DVD-R or DVD-RW for betters chances of success.Sometimes some of the new DVDs are bad.Make sure you try a couple different ones even from a new pack of DVDs.
Jul 22, 2008 | Toshiba Satellite A105-S2716 Notebook
NEC 3540A stopped reading blank DVD+DL
Hi JonPM
Burning a dual layer disk requires a functionality of the drive that is not used in the burning of normal disks. But before we consider that the drive may have a mechanical problem, lets clean out all your temporary garbage. Click on this link and download Cleanup 4.5.2 (http://majorgeeks.com/CleanUp_d4895.html
Instal and run the program. Once it has finished, reboot your computer and give burning onto the DL disk another try. Let me know what happens.
-C
Jun 20, 2008 | NEC ND-3540A DVD RW Dual Layer Burner
Computers & Internet Logo
75 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
