Question about Nintendo NES Console
I replaced the 72 pin connector in my Nintendo Nes and now I just get a grey screen? what can bee the problem? Cecilia
You may have damaged something on the board during the process. I suggest going over what you did, making sure the 72 pin connector is seated properly so the connection can be made cleanly, and if all else fails snag another one on ebay and try again...
Posted on Dec 04, 2008
I have 2 Nintendo NES systems. One I thought didn't work and needed the 72 pin piece changed, but when I turned it on the other day, it sort of worked. The people in the games came up with letters and...
Secret trick: take NES cartridge, press cartridge down and waggle the cartridge inside the NES and then hold the NES down and shove the cartridge onto the pins. An alternate solution is to take a Q tip, dip it in rubbing alcohol and clean out all the dust inside your game.
Mar 23, 2015 | Nintendo NES Console
Solid yellow screen that is not flashing. I replaced my 72 pin connector and made my nes region free (4th pin from the left on the nintendo chip). I can play Super Mario/Duck Hunt but every other...
Well I think that the capacitors might be broken then and need to be replaced. Or try cleaning the gamepacks out with qutips and rubbing alcohal.
Sep 21, 2011 | Nintendo NES Console
The red light flashes on my NES and on the TV screen, it keeps on changing colors. Do you know whats wrong?
The NES is touchy like that, sadly-- your problem isn't uncommon. My NES, and the NES of nearly every friend I have who still owns one, plays this little trick on them from time to time. Here's what we do:
1. Turn off the NES console.
2. Blow into bottom of the game, near the chip that connects to the NES.
3. Wipe away any excess dust from the game itself.
4. Blow into the console of the NES.
5. Wipe away any excess dust.
6. Re-insert the game and try again.
If this doesn't work, try placing the game in more delicately, or with more force. It's just a matter of trial and error, and sometimes it will work faster than others. Hope this helped!
Mar 12, 2011 | Nintendo NES Console
My Nintendo NES just keeps flashing on and off and the screen is flashing yellow. i opened the console up dusted out with compressed air. then i tried to fix the connectors on the 72 bit loader by pushing...
Rather than try to bend the pins back into place, you may have more success replacing them with a new 72 pin connector. You can find several merchants online that sell them.
Mar 07, 2011 | Nintendo NES Console
I have changed the pin connector on my nes, it does not flash anymore but now i get a blank screen can someone help me?
First try connecting through the av ports on the side of the console rather than the RF port on the rear of the unit.
If that doesn't work then your problem is likely a loose connection inside, go back in and reassemble.
I have had this issue with several consoles; these two solutions usually take care of it, though in rare cases a defective 72 pin connector was at fault even though it was brand new.
Good luck.
Mar 31, 2010 | Nintendo NES Console
Grey screen on nes?
This video should help you:
Mar 13, 2010 | Nintendo NES Console
White dotted lines on screen of NES
Clean your games too once you replace the 72 pin connector or you're just dirtying it up again. Not to mention the games has enough crud to keep them from working correctly.
Mar 28, 2008 | Nintendo NES Console
Nintendo NES Repair
It's as simple as unscrewing the console by removing all the screws from the bottom. Once inside take off the metal piece over the area where the game is inserted. Once under there you can remove the two screws that hold the 72 pin connector in and pull it out and slip a new one in. Put it back together in reverse.
Mar 26, 2008 | Nintendo NES Console
How to fix my nintendo (NES) without replacing anything
Yes, this is a 72 pin connector problem. The connector has become dirty or oxidized and needs replacing or cleaning. Problem can usually be solved by buying a NES console Pin cleaner which inserts like a game. The "Eliminator" is one which works great wet or dry to eliminate this problem.
Oct 09, 2007 | Nintendo NES Console
Nintendo NES Console Logo
320 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
