Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
50" plasma monitor goes black
I am in need of technical advice. I have a Pansonic plasma monitor, model TH50PHD7UY, which is slightly less than 2 years old. Im am on a dish with a Tivo box, and a DVD player is connected. Up until about thee months ago everything was working well. And then one evening, after the set had been on for 3 or 4 hours, the screen went black and a notation "NO SIGNAL" appeared in the upper right corner. The next night after playing for 2 or 3 hours it happen again. And over the last few monhs is has gotten down to about one hour before it shuts itself off. I checked it with DVD player so as be sure the problem was not the Tivo. Any ideas as to what is causing this problem and how it can be fixed would be greatly appreciated.ultimate audia and video 949-474-1626
4 Suggested Answers
  • 8 Answers
SOURCE: Need help troubleshooting sudden "no signal" error
This is an issue with IC 803 on the Z board. This is a 3.3 V regulator that supplies this voltage to the slot card cage. Most input boards use this voltage EXCEPT the component board which is why it keeps playing along whike the DVI, HDMI, or composite signals will cut out after warm-up.
This is a surface mount multi-pin IC and is a bit tricky to replace.
The entire board is PN# TNPA3198xx with suffix determined by what model 7 series plasma you have.
This was a problem from around Nov. 2004 to Mar. 2005
T Wiz
Posted on Mar 25, 2008
  • 814 Answers
SOURCE: screen goes black after 1-2 hours
You need to have your television tuner tested for faulty components. Your problem is caused by the components in you tuner overheating and losing functionality. The tuner need to be thoroughly test and repaired. You can reach Panasonic customer support at this telephone number. 1-888-843-9788. They should be able to tell you what the problem is and where to take it for repair. I hope this information helps you with your problem.
Posted on May 22, 2009
SOURCE: Techwood 42inch plasma
black line probl;em with this model is caused by dry joints on the resistors that are attached to the individual ribbon cables. a fairly easy fault to repair. but it means undoing all the screws and resoldering the resistors. once the back of the tv is off, locate the offending resistors and resolder them,Take the two screws that hold the ribbon cable assembly and gently lift out the ribbon cable. just use a hot enough soldering iron (mains or portable gas) and watch the solder 'flow' attach the ribbon cable. if you're careful, you can test to see if the fault has been repaired prior top replacing the cover. (make sure there's no pets or children nearby and be very carfeul as there's live mains within reach. once you're happy the fault has been repaired, put the cover back on. Its worth resoldering all the resistors just to save the fauklt reoccaring anywhere else. dominic :-)
Posted on Dec 02, 2010
Sir I hava a plasma television Pansonic TH-42PV70M and the display cracked during transport. Any solution to repair. The pansonic agent in India,s Engineer comment is not possible to repair because 90%...
The tech from India is fairly correct. Newer TV's (LCD, LED, Plasma) have most of their cost in the screen. In fact most companies will straight up replace a broken panel TV rather than fix it because its more cost effective. I would advise you do the same and get a new TV. Sorry for the bad news!
Jul 19, 2011 | Televison & Video
We Have a plasma 42 in panasonic tv that is less than 2 years old. It suddenly popped and now longer works Do you have any advice on how to troubleshoot?
i would contact panasonic and complain that you bought an expensive electric device that should have lasted longer than two years. You might be suprised at how accomodating they can be. Just quote consumer rights to them and dont take no for an answer
Mar 31, 2011 | Televison & Video
Hi, I bought a lg plasma tv model 55LD520, and now my dish network remote won't work unless I'm literally 2 inches from the reciever. What can I do? Please help
I had the same issue with the 55LD520 and my Dish 722 receiver.
Check out this link for some suggestions:
http://www.satelliteguys.us/dish-network-technical-discussions/193510-ir-remote-1-722-receiver.html
Putting black tape over the receiver IR sensor seems to be working for me.
Sep 05, 2010 | DISH Network IR Remote Control
My TV is less than two years old and out of
this tv needs a new ysus board and maybe the ysus buffer board as well..
type in buffer board for your model of tv in ebay and ysus,, theres a guy there who does them 64.99 & 12 £ postage u muct send your old one in,,for repair / replacement,,
6871QYH053B this is the ysus model u need..
all the best lee..
Apr 28, 2010 | LG 42PX5D 42 in. Plasma HDTV
5 year old plasma that looses half the picture
Hello. I recommend that you forget the repair for two reasons. 1. Pricey. 2. You still have a 5 year old set with no warranty. In the last five years, the tv technology has come so far. The HD is fabulous. The new sets cost less to operate and they are so much better than they were five years ago. Joe
Mar 24, 2010 | Philips 42PF9630A 42 in. Plasma Television
I have a Fujitsu 42'' PDS4221 - 10 years old - shuts itself off
See Fixya tips and tricks:-
'Fujitsu Plasma 42" random shutdown - continuous flashing red'
While the model of your set is slightly different, the checks described generally still apply, as it is very similar.
Nov 18, 2009 | Cars & Trucks
Side by side Samsung TV's need remote control solution
If possible turn one off and tune the other. Then turn the other off and tune it. Then turn on the other. That is your only option at this point.
Feb 16, 2009 | Samsung PN50A650 49.96 in. Plasma HDTV
Compaq FP 7317 LCD monitor flickering
try with change the resolution .it will littl ebit help out . othewise show it service personnel. bye
Oct 01, 2007 | Compaq FP 7317 17" LCD Monitor
Daewoo 42 Plasma - Model DT4280NH
I have a samsung 42 in plasma television which is three years old, it has a blue flickering light to the right of the television, sometimes can see some at the top in the middle, hope you can help with this problem, is it repairable.
Sep 02, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
