Question about Sony Betacam SP Small Videocassette 30 Minutes Digital Betacam SP Tape
Betacam Sp Error Code
I have a tape stuck in my betacam sp bvw-75.
the error code is ERRO-09 TH/UNTH MOTOR TIME OUT.
how do i get my tape out.
Thanks
Rae
  • ratsbane Jan 03, 2009
    The tape doesn't get stuck (you can still eject) but our PVW-2650 is giving "Error - 09 TH/UNTH MOTOR TIME OUT."
    I interpret this to mean that the tape threading mechanism isn't working properly. It seems to be not threading the tape rather than not un-threading.
  • 10,594 Answers
It seems mechanical problem and you need to apart unit.
I would advice you to get Maintenance Manual of BVW-75 before to open unit and get help from mechanical exploded section.
Below is picture of Maintenance Manual and part of mechanical exploded view...
It is high end broadcast model and needs care in maintenance.
Good Luck.
Posted on Nov 26, 2008
It sounds like you may have blown your threading belt. Pull the lid off and have a look at the small threading motor at the back left side when viewing from the front. there is a geay assembly associated with it that drives the threading ring. If that belt is off or loose you will get the error 09 message. Good luck
Posted on Jan 07, 2009
How to eject an HDCAM tape stuck in as BVW75 Beta deck.
I don't know what this error code means but I have managed to remove tapes which stuck in a VCR and cannot be ejected. Whether you do this is purely up to you, but it's usually possible to remove the casing (carefully!) so that you can get to the tape-handling section. Then it's a matter of gentle probing & trial and error to get the machine to release its hold on the tape. Look for a series of mechanically linked parts which are driven by motor but activated by a microswitch tripped by action of inserting the tape. Just don't strain the linkages and if you remove anything make a note of where it came from.
Apr 28, 2015 | Televison & Video
Sony bvw 75 beta sp deck error 90
not worth it as it indicates mechanism problem related to power circuit in the unit--not to mention no parts are available for this unit.
Apr 02, 2012 | Televison & Video
Error02-694 Sony Betacam Deck UVW-1800
UVW-1800 error 02-694 indicates a problem with one or both reel motors. check the cables going to both motors; have seen failures related to these cables.
Jul 21, 2009 | Sony Betacam SP Small Videocassette 30...
Beatcam SP error message
BVW-75 error 09 is "threading motor time out". Look for something obstructing the travel of the threading ring inside the deck (the ring which pulls the tape around the video head).
May 02, 2009 | Sony Betacam SP Small Videocassette 30...
Sony UVW-1800 Error Code
I just found this post on another site :
tsvservice- 29th Jun 2007 14:0109-221 is "failure to complete threading within the specified time". in plain talk, the mechanism in the deck that threads the tape around the heads is not working. this could be a bad motor, bad gear, or even a bad tape.
Feb 15, 2009 | Fuji M321SP Betacam Tape
The machine is a SONY VIDEO CASSETTE RECORDER UVR 1400 AR
uvw-1400 error 02-803 is "tape tension error when threading". possible bad threading motor or threading mechanism.
Feb 11, 2009 | Sony Betacam SP Small Videocassette 30...
Tape End Sensor Error - UVW1800
these error codes point to possible problems with one or both reel motors.
Dec 11, 2008 | Sony Betacam SP Small Videocassette 30...
I have a Sony UVW 1800 Beta SP deck. This morning, after completing a dub, I rewound the tape. The machine made a sound, the tape stopped and became stuck in the machine. I received an error code 02-803. I...
check your tape deck unit throughly check for any physical damage of REWIND/FORWARD Gears.and FLY Wheel.
and dis locateion of some lever positions.
defnitly you get solved
Nov 13, 2008 | Sony Betacam SP Small Videocassette 30...
Error code 02-694
The probem as told on another site (sorry, can't remember to give proper credit) is that the pinch roller is not making contact with the capstan. THis is exacly what happened to my 1800 after sitting for a long time with no use. THe solution was to manually excersize the lever going to the solenoid to unstick the mechanism. Then, voila, pinch roller pinches, tape moves, UVW1800 happy again.
Apr 13, 2008 | Sony Betacam SP Small Videocassette 30...
Electronics - Others Logo
2,706 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
