Question about Electrolux Central Vacuum
Electrolux Central Vac - very hot where tube attaches to handle
A few weeks ago I noticed intermittant power when runnig the vac. Today the area got very hot where the handle and wand connect. I have the type of tube to clean carpeting, with the two wires that connect to the wand. Thanks! Should I send out for repair or replace?
  • 58 Answers
Yes definatly take it to a shop and have it looked at. if its not worth repairing they will let you know.
Posted on Sep 01, 2009
  • 706 Answers
Hello randpmarion,
Because you said you had intermittent power and the area where the wire is got very hot, there is a high probability that you have a poor electrical connection inside the handle. Left unrepaired, it could pose an electrical hazard or fire hazard to you. If you unplug it and can disassemble the arm, look for evidence of carbon or arc damage near where you felt the high temp but I would not use it as is until it is repaired or replaced,
Regards
Rick
Posted on Nov 26, 2008
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
Lack of suction at power unit
Check that the Handle has a slider to adjust air flow, Electrolux Vac's arent really designed for carpet cleaning, check hose for breaks or cuts and everything is secure, while its on run your hands all over the hose and vac to locate any air flow that should not be.
Let me know.
Nov 15, 2007 | Electrolux Centralux Vacuum
Electrolux 1590 not turning on
TRY JUMPING THE CENTRAL VAC INLET WIRES AT WALL! IF COMES ON SOMETHING IS MISSING ON HOSE TO WALL CONNECTION. MOST HAVE A METAL RING TO ACTIVATE THE INLET DOOR WHEN HOSE IS CONNECTED.
Dec 12, 2009 | Electrolux Vacuums
Central Vac will not turn on.
These problems are nearly exclusively caused by a bad circut board and replacing it is the fix. Bad boards can cause many different effects so its nearly impossible to be sure. The 9v signal wire is not enough to short out an entire unit so it is unlikely the hose. If it is a direct connect system and you are pulling power from the 110 somehow that would cause main unit problems but that is unlikely at best. Sounds like a failed board to me.
Best of Luck
Jun 04, 2009 | Easy Flo EF1400 Central System Vacuum
Metal hanger stuck in central vac hose
there should be a pin push it in then pull out power head then try to pull out hanger
Feb 08, 2009 | Electrolux Central Vacuum
I need a new hose for my Electrolux central vac
Do you need a new powerhead too or only the hose? If you need a new powerhead than I would recommend looking at the Imperium Pro Elite Attachment set. It is an excellent quality powerhead and hose. If you only need a new hose than you will need to contact the Aerus because they will be probably be the only company who can sell you a hose that wil be compatible with your powerhead. Their website is http://www.aerusonline.com/products/
Jan 21, 2009 | Electrolux Central Vacuum
Burned out
Hello. I also have a blog about vacuum cleaner. You can look over here. Hope it helps everyone. Vacuum Cleaner Reviews Archives Vacuum Review
Feb 26, 2017 | Euro-Pro HEPA Shark EP238 Bagged Canister...
I have a one year old Beam central vac. It has supervalves. The handle (connected to the hose stopped turning on the unit. The handle still powers the brush but no longer turns on the suction?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566201
Generic problem for all Vacuums
I have a one year
posted by jon89 on May 02, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Beam Central Vac may have more than a one year factory warranty and it sounds to me that you may have a bad relay switch the Central Vac, if you do it should be covered under the factory warranty. Otherwise, you may have a bad supervalves or a wire came loose, if the hose switch turns on the power nozzle then it may be a bad supervalve or a bad relay and to contact the installer or the manufacturer of Beam. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.beamvac.com/usa/ Owner Support
Customer Service 1-800-369-2326 Phone #
Email: beam.dir-support@beamvac.com
Technical Support: beam.tech-info@beasmvac.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Vacuums Logo
120 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
