Cannot locate transmission filter or instructions to replace
ok, here's the deal. there are 2 types of transmissions one with an external oil filter( kinda looks like the oil filter for the engine) and then there is the other type of transmission that was produced later on the 4 cylinder engines that doesnt have a removable filter. it does have a screen that is not servicable, it can only be replaced during the rebuild of the transmission. this design is supposed to be "back flushed" to remove all debris. Most good transmission shops have this type of system that pressureizes the system and does this.
If your gonna do this on your own, what you will need to do is buy 4-5 quarts of transmission fluid, drain the oil from the pan on the front of the engine, reinstall it, add the fluid, drive for 30 min, and then repeat the process.
Is your truck an automatic or stick shift?
Are you sure this is not ATF, that hole is the weep hole for the rear main seal and the input seal on the rans.
