Question about Hotpoint RB757 Electric Kitchen Range
Hotpoint RB757 DOOR LOCKED CANT OPEN NO MANUAL PLEASE HELP
I CAME HOME FROM WORK LAST NITE AND MY AUNT HAD TRIED TO SELF CLEAN THE OVEN WHEN I WENT TO OPEN IT, IT WAS LOCKED AND NOW IT WONT OPEN AT ALL. NO MANUAL IS AVAILABLE PLEASE HELP ITS THANKSGIVING EVE!!!
    Sergeant:
    Champion:
  • 291 Answers
Act like your going to self clean and start from beginning and set it to self clean ,,, after you hear it lock down and start to go in clean the cancel it out and it will open / have a good thanksgiving
Posted on Nov 26, 2008
My self cleaning oven will not lock, so I am assuming it is broken. My oven needs to be cleaned. Since you can not use an oven cleaner on it, what can I use to clean it?
HELLO,
Please carefully apply the below instruction to clean up your range
self cleaning solution
  • 1 Remove oven racks and soak them in soapy water
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on food.
  • Fast Cleaning method
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently. 6 Dry with a soft cloth
  • hope this solution help?
    thank you.
    Sep 20, 2010 | Hotpoint RB757 Electric Kitchen Range
    Please tell me the procedure for using a self cleaning oven? I have no manual.
    on most modern ovens there is a button for cleaning and some have a lever on the front door you have to move from left to right to lock the door first. If you do not have a lever yours more than likely is an auto lock door. You push the oven clean button and set time by pushing the up button on the temperature this will automatically turn it on for a minimum amount of time usually 2 hours and if you keep scrolling up it will go up to 6 hours. Once you start the cleaning mode it has to run its course and the oven will not unlock until the oven cools down to a safe temperature. have a nice day
    Aug 13, 2010 | Hotpoint RB757 Electric Kitchen Range
    Oven will not come on to cook, it will come on in cleaning mode
    I've seen this problem on my own oven. If yours, like mine, has a door that has a locking mechanism, the catch is most likely stuck in the locked position. The door still closes and the lever still moves (though it may be very stiff).
    Take off the screws around the locking plate, manually push the catch to the open position, spray the catch VERY, VERY lightly with WD-40 and dry it thoroughly. Close the oven door and try the lever again.
    At this point, it should move freely and your oven should be able to switch between LOCKED/Self-Clean Mode and UNLOCKED/Cook Mode. If it does still get stuck, you'll just has to a) try lubricating the catch a bit more or b) keep a screwdriver handy! ;)
    Aug 05, 2009 | Hotpoint RB757 Electric Kitchen Range
    GE Hotpoint electric stove
    If you ran a self cleaning cycle and now the door won't open you may just need to wait a while. The door locks to avoid anyone from opening it as the over heats up to around 700 or more degrees to burn anything off. Sometimes what will happen however is that the heat will get to intense and cause the door lock mechanism to jamb. If the door doesn't open for you after a good few hours or so you can try unplugging the oven for a while to try and reset it. If not though you will have to go through the front panel and go down to manually unlock the door. Let me know if you have any other questions and let me know if this was helpful. Keep me updated on the outcome too if you wouldn't mind. Good luck and glad I could help.
    Jan 22, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
    Locking door wont open
    the self cleaning lock is stuck and I can't open the oven, how do I fix this
    Jan 19, 2009 | Hotpoint RB757 Electric Kitchen Range
    Oven door locked
    if the oven cooled down and door still wont open unplug oven for 15minutes and see if that helps ive seen in many cases were the door had to be destroyed to gain access to the oven
    Dec 30, 2007 | Hotpoint SY21 Style Line Gas Single Oven
    Self cleaning oven
    it sounds like a micro switch is stuck they are located behind lower back panel
    Nov 21, 2007 | Hotpoint RB757 Electric Kitchen Range
    Hotpoint self-cleaning oven
      I believe they make an oven cleaner for self clean ovens.  Don't try regular oven cleaner.  Ruins finish.
    Oct 24, 2007 | Hotpoint RB757 Electric Kitchen Range
    Oven problem
    door won't open after self-cleaning
    Oct 15, 2007 | Hotpoint RB757 Electric Kitchen Range
    Hotpoint RB757 Electric Kitchen Range Logo
    211 people viewed this question
    Top Hotpoint Kitchen Ranges Experts
    Sal De
    Justin Duby
    Justin Duby
    Ismael Rodriguez...
    Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
