Question about Pioneer TS-D690R Coaxial Car Speaker
Speakers making loud buzzing noise
I have pioneer 6x9 and splits in my car ive nearly finished installing except when i turn the engine on you can here it buzzing through the speakers and when you put you foot on the accelerator it increases the loud buzzing noise is this straight forward is it to do with the amp??
  • 3 Answers
I have that too and ive tried everything about wiring i even hooked up a different amp and its the same thing as a last resort i am changing my alternator a lot of times it can back feed through your system making that noise
Posted on Feb 12, 2009
    Problem Solver:
  • 9 Answers
From your alternator, Make sure none of your RCA's are near a power wire, check your grounds as well.
Posted on Feb 17, 2007
How to connect 6x9 pioneer speakers
Do you mean the Factory Speaker (Conecters) If you do they will have to be changed, To the same type of connecter that is on the speaker wires that come with the 6x9"s
Dec 05, 2012 | Pioneer Ts-a6974r Car Audio 6"x9 6x9 3-way...
GE Microwave (JVM1860CD001) control board buzzes.
see this causes and fix it. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 10, 2012 | GE Microwave Ovens
I have a Pioneer Gm-x722, and i hooked it up to 2 6x9 speakers and two 6.5" speakers and I get a buzzing sound, how to I clear up the buzzing?
try grounding the shield of the rca cables and see if the buzzing goes away. if so you have a bad ground to the rcas either in the deck or the amp. grounding the rca cable shield should take care of the problem.
Mar 26, 2010 | Pioneer GM-X722 Car Audio Amplifier
Loud buzzing noise upon switching on
Do you have a wireless phone near the speakers? It will make the speakers noisy. If this is true, move the speakers away from the phone. Check other electrical devices which may be near the speakers, it may be the problem.
Jan 30, 2010 | Harman Kardon HK19.5 Computer Speakers
Is it possible to install 6x9 speakers in a 1999 isuzu rodeo??? if so where?
You could use a spacer and install them in anything.
Most audio accessory stores carry 6x9 spacers in 2"
Jan 03, 2010 | Pioneer tsa6970s 6 x 9 3W Speaker Car...
Pioneer pdplx5090, buzzing but no picture
CK your Hori output Transistor near the FBT flyback Tansfomer.
Dec 15, 2009 | Televison & Video
Where to find the enclosures for PIONEER TS-A6872R
get some MDF board and make them.or buy the 6x9 box cover front with a peice of mdf screwed down good where the speaker will go and cut out a 6x8 hole.
Oct 07, 2009 | Pioneer TS-A6872R Car Tweeter
I have a 1991 chevrolet caprice classic and
BAD GROUND. CHECK GROUND CONNECTION IN THE KICK SIDE OF THE DRIVER PLACE, UNDER CARPET YOU WILL FIND A NUT ATTACHING SEVERAL CABLES TO CHASIS, CLEAN AND RE ADJUST
Sep 18, 2009 | 1991 Chevrolet Caprice
Stero works with engine off
Some wiring may be crossed between the Ignition wire and the 12V battery wire. Check the wires behind the head unit. The head unit could also be going. Hope this helps!
Aug 03, 2008 | Pioneer DEH-1600 CD Player
Pioneer TS-D690R Coaxial Car Speaker Logo
518 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
