Question about SanDisk Sansa e250 MP3 Player
My headphone jack has one spot it works. If I bump it, i get no sound. I have to pull it out a little. Replacing the plug in costs $35.00 just for shipping. Do I have any other options?
  • 8,596 Answers
This is the only right answer i can give you - no. A common problem with all brands of mp3 players is the "sound only comes out of one headphone" issue. Requires replacing the jack or the whole player. Sorry.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
Having problem with audio, with auria tv (when unplug headphones, sound will not come back on tv)
The socket for the jack on the set has a leaf connection that when you insert the jack moves aside routing sound to head phones and cutting it off to speakers= the socket for the jack is out of position inside, either needs to be replaced or tweaked inside just a little.
Not much else can cause this if the headphones work.
May 02, 2012 | EQD Auria EQ2488F 24 LCD TV
How can I get headphones to work with my Symphonic WF203 TV?
This set doesn't have a headphone jack, nor does it have RCA audio output jacks. Without one or the other, you're out of luck connecting headphones to this TV.
I remember a product some years ago that allowed adding headphones using a small microphone placed in front of the speaker. This was hooked to a little amplifier that ran the headphones so the volume could be independently controlled. It was marketed as a way to let "hearing-impaired" family members listen to TV shows without needing to make it uncomfortably loud for others. I haven't looked, but something similar might still be available. It's cumbersome, though, and needs power, plus maybe being costly if you find one.
It's possible to add a headphone jack, but you need to know how to do electronic soldering. Find a spot on the case where you can make a hole and mount a headphone jack, then wire it to the speakers. If you want the headphones to cut off the speakers when plugged in, you need a switching jack, and the speaker wires need to be cut and connected to the correct terminals. The switch built into the jack then disconnects the speakers when the headphone plug is in. If you don't need to turn off the speakers it's a little easier. You just need to wire from the jack to the speaker terminals. I've added jacks on quite a few sets. If you don't feel up to it and don't know anyone who is, you can see if a TV shop (if there are any left in your area!) would do it. (The shop I used to work for charged about $20, including the jack, but that was over 10 years ago now.)
Good luck, and thanks for using Fixya!
Jun 12, 2011 | Symphonic WF20D4 TV
Four weeks ago I bought an iPod Touch 32GB. After listening to my iPod on an external speaker I tried using the headphone and the sound is just too low. I thought my headphone was damaged but I tried it on...
Sounds like plugging the external speakers in has damage the spot were the headphones go in. If this is under warranty that bring it to apple store.
Jan 19, 2011 | Apple iPod touch
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Audio only works with headphone on
may be a problem with the headphone jack & the unit thinks that a headphone is still in there. Try plugging in the headphones, putting slight tension on them plug in the jack and then pulling them out. Sometimes helps.
Feb 06, 2010 | Acer (54.AA806.001) Sound Card
No sound from speakers
The earplug socket in the computer is faulty, needs replacing.
What is going on is that there is a contact that the plug pushes open.
That contact for some reason is not closing when the plug is pulled out.
Jul 11, 2009 | ASUS F50SV-X1 PC Notebook
Sound Problem with Headphone
First try the headphones in a different machine, such as an mp3 player or cd player to make sure the headphones still work.
Try going to the start button, then settings and control panel. Then select "Sounds and Audio devices" Down at the bottom you should see "Speaker settings." Click the "Advanced" button and then select stereo headphones.
Then, place the headphones into the green audio jack (or the headphone jack up front if you have them), play some music, and then gently wiggle the jack to see if some of the sound makes it into the headphones. If not, try slowly pulling the headphones out of the jack while the music is plaaying. you might find that the jack has slipped a little and may play only if your connector is slightly pulled out or more firmly pushed in. If his helps, then your audio connector is loose and you should replce the sound card. If the card is on the motherboard, you can disabled it when you put a new card in.
Jul 09, 2008 | Compaq Presario 700 470024-192 Notebook
Dell Inspiron 6000 PC Audio Ports Damaged
You should have sound from the speakers at all times until headphones are plugged into the jack, the jack then overrides the speakers and allows you to listen using the headphones. If the speakers aren't working, it's because they're being overridden by the damaged jack. The only way to correct this is to replace the faulty jacks. You could get a set of external speakers, the con is they're bulky and inconvenient.
Jul 01, 2008 | Dell Inspiron 6000 Notebook
Soundcard problem on D530 SFF
Sounds like the audio return wires aren't connected. On the motherboard, there is a sound jack on the back left side of the mobo. The jacks from the front audio panel connects to it. Both the Left and Right channel have an out and an in connector. These send the signal to the headphone jack on the front panel and return the signal to the rear output jack if a headphone is not connected. Look for looe or broken wires. The other spot to check is the front headphone jack. If a headphone plug was pulled out or pulled sideways, it could break the solder joint on the PCB panel or break the shunt feeding the singal to the rear jacks. Hope this helps.
Ron
Apr 13, 2008 | HP Compaq Business d530 PC Desktop
Headphone jack issues
Although headphones jacks are convient. They are very delicate as well. It take very little pressure agaist the jack when plugged in to bend the pins inside the jack that makes the connection. Then they get temermental. Generally the only recourse is to replace the headphonejack in the unit. better left to the techs. replacing can be tricky. But just to make sure you say you have tried other units. Here is something that works once in a great while. Unplug the unit dip the headphone jack {the tip on the headphones} in rubbing alchol insert it in the jack on the unit and spin it repeat several times let alchol evaporate then stick jack back in unit an spin again. Plug unit back in and see if it is better or the same.
Aug 05, 2006 | Mach Speed Trio DA-8033 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
