Question about HP DesignJet 500ps InkJet Printer
THE SCREEN OF MY HP DESIGNJET 500 DOESNT WORK
Hi, my plotter doesn´t work, it si connected to the energy but the screen does not go on, no message no nothing, bit the green light of the power button is on. Can somebody help me?
    Problem Solver:
  • 8 Answers
I would suggest taking out all the consumables. Printheads, media and cartridges. Unplug for upwards of 20 seconds before plugging it back in but leaving the consumables out.
Try turning on the plotter. If it appears working properly, load all consumables one by one, cartridges first, then printheads, then media. Attempt to print a test page if it works.
Or try a different outlet. Maybe the one your using has a problem and doesnt produce enough electricity.
Posted on Dec 17, 2008
Why is the front panel screen HP DesignJet 4020ps plotter show a blank screen with a blinking green light?
According to the manual, a blinking green power light indicates that the unit is transition between off and on.
Dec 30, 2014 | HP DesignJet 4020PS InkJet Plotter Printer
Ds light green,dim green, amber then off when power is turned on
Sounds like you need to send it in for repair. I had sent my console to VideoGame911.com and they repaired mine at a great cost and got it back at the end of the week. Give them a try, they are cheaper than a manufacturer. Good luck!
May 04, 2013 | Nintendo DS Lite
I have a Kenmore elite dishwasher. The Pots and Pans red light is flashing and the Heated Dry light is solid red. Nothing I do will change that. I've tried pushing any combination of buttons and ...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 19, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
The receiver doesn´t work. When i switch on,
the solution: Fount of energy broken and 50€ less in the pocket...lolo
Aug 14, 2009 | Philips E-Box FTR9965 DTV Receiver
SI-TEX chart plotter, cleaned screen w/ windex. made it cloudy
washed sceen with a mild cloth and clean warm water. It still has a little haze however w/ the plotter turned on it is almost impossible to notice the haze
Feb 11, 2009 | SI-TEX ColorMax 6 GPS Receiver
I bought a C80 Raymarine Plotter this has a NMEA pigtail with Brown, Screen, Yellow, Green And White wires I haave also bought a RS 125 Receiver this has a pigtail lead with Red , Green, Yellow, Brown and...
If you have a Raymarine pilot it makes sence to wire it all up to Seatalk. Wire as follows Red to red , silver to silver, yellow to yellow, brown(on rs125) to silver on seatalk buss Green (on rs125) to red on seatalk buss.The above is for the conection between RS125 and C80.
To hook the pilot to system you just need to hook the seatalk lines (red, yellow,silver) from the pilot to the conection with the RS125 and the seatalk cable to the C80.(Color for color).The sea talk connection for your pilot can be picked up from you course computer they are labeld and colored on the unit.
If you are not running a course computer as in the case with the older wheel and tiller pilots you will need to take a sea talk cable and cut it. Once it is cut you will see the red yellow and silver wires and you can tap into there . Remember to connect the cable back together were you cut it. Hope this helps
Dec 15, 2008 | Raymarine C80 GPS Receiver
Wiring of seatalk instruments
OK, you are confused. Seatalk is a bus system, using 3 wires , (power +, power-, and Data.) red, bare and yellow repectively. So Red and Bare are 12V and ground. Since the 125 shows a green light, it is getting power and outputting data. but is it seatalk?? to make a 125 Seatalk, you must hook red and green together to 12 V, so check that first. if green is grounded or not connected, that is the problem (or one of them)
Next divide system to its' simplest terms, so hook the GPS straight to the display ST60, and see if it works red to rd, yell to yell and bare to bare (sometimes black) One by one hook the others into the chain until they all work or failed device takes down Seatalk network. If you are missing 12V on a seatalk leg, check 5A fuse in course computer. If you have a pilot, you have a course computer, unless it is ST4000 wheel pilot, and then the brain is the display (course computer is built in to ST4000 display)
Sep 01, 2008 | Raymarine RL70CRC GPS Receiver
Black screen
how can u fix this black screen? the green power light is on, shows vista for a bit then turns black and stays black. any solutions or do i have to send it back?
Apr 03, 2008 | Microsoft HannsG HU171D 17" LCD Monitor
450c Plotter apparently dead
Check the cable connections, and the cable connector inside the plotter. Make sure your cables are good.
Dec 29, 2007 | HP DesignJet 450c InkJet Printer
HP DesignJet 500ps InkJet Printer Logo
132 people viewed this question
Ben Johnson
