Back to:
Tags:
LG DLE2532W Electric Dryer
Clothes Hot but damp, water out of vent (by 2 users)
posted by haps on Jan 09, 2007
Hi
I had the same problem as a previous owner where the clothes were hot but damp after a load in the dryer. As such I am troubleshooting the issue, I've disconnected vent line behind the dry and there is warm air coming out of the dry. However there was also a fair amount of water that spilt out. I am not sure what this means?
Any suggestions?
Thanks
Drowning
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by ariesgirl29, posted on Mar 26, 2008
I was hoping for an answer to this because that is exactly what happened to me! I disconnected the back hose and there was water coming out but it's not a combo, it's just a dryer. I have no idea what it means and am not sure if I call a dryer repair person or a duct something or other... <clueless>
Best Solution
posted on Apr 09, 2007
Helpful (85)
safeonbase
Rank:Master Master
Rating: 82%, 28 votes
Is this a combo washer/dryer in 1 unit? water shoud not come out if it is just a dryer. Your air coming out of the back vent hose should be hot. If your clothes comes out of your WASHER damp (more than normal) then your washer is not spin drying good enough. (worn belt, clogged drainage system).
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Clothes Hot but damp, water out of vent:
I don't want to Accept this solution
Can you Help with these Dryers problems?
Dryers
when i hit the control buttn or any other buttn nothing...
Dryers
We took our F &amp; P ED56 off the wall to paint the...
Dryers
gas dryer tumbles with no heat.
My LG Dryer is making a "hard" noise when I...
How do I get to the fuse and the thermostat. Is there a...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
