Question about Sharp AL 1631 Copier
Won't copy spits out blank paper occasionally CH will flash
Try new toner but still doesn't work seems like it is not heating up enough, I also need a new instruction manual.
  • Sharp Master
  • 2,794 Answers
Go to www.sharpusa.com. Type in the model number in the copier section to get a new owners manual.
Is there any errror codes?
Posted on Nov 27, 2008
It just won't make a copy. New
do you mean that copy comes out blank?
If yes, this is problem with laser shutter on laser unit.
Call service!
If the copy isn't blank, please give more details about problem...
Sep 14, 2011 | Canon imageCLASS MF6530 Copier
Xerox 4150 my paper is a light shade of grey, what can it be thank you
Giacomos,
Is the paper a shade of grey with no image? or is there an image with a grey background?
If there is a image with a grey background you should try a new toner module. If that doesn't resolve the issue, clean the xerographic drum, make 10 blank copies, if the cleaning doesn't resolve the issue than install a new xerographic module.
Hope this help.
Apr 05, 2011 | Xerox WorkCentre 4150 Black and White...
I just received a Xerox 5334 copier. We moved it to our house, powered it up, and ran a test copy (just a sidebar thought...it spit out one copy and a blank paper). I left it on to go retrieve the work I...
Code U4-1 is Over heat or under heat, even if you solve this problem you mentioned that you have a copy from the machine which is Blank, the reason is that the print cartridge is dead, it is not holding charge, and even if you find a new one in a box sealed, I am 99.9 present sure that it is not going to work either, it is an old expired cartridge, basically do not waist your time and money, I serviced these machines and I know.
Mar 23, 2017 | Xerox Office Equipment & Supplies
Toshiba e 650 Copier was working and copies were fading so we
When you changed the toner did you remove the strip on the new toner to release the toner
Jun 12, 2009 | Toshiba E-STUDIO 650 Copier
Canon Copier Model C122F - error light flashing
A common mistake is that people think that the waste toner needs to be emptied and instead the toner needs to be replaced --- and vice versa. Check to make sure that the toner bottle is not empty. Also, if you made copies that took ( used ) more toner then the machine was able to replenish, the machine has not had a chance to catch up. Place a white sheet of paper on the platen glass and make blank white copies. You may only be able to get 1-2 copies at first but as the device catches up with the toner replenish you should be able to make more. The blank copies you make -- do NOT put that paper right back into the machine. Lay it flat and let it cool, this will help prevent unwanted jamming due to heat build up in the paper. IF you have good amount of new toner in the machine, gently tap the front line ( or rear line) that feeds the used toner into the waste bottle. Sometimes the waste toner will clog and back up into the machine giving false 'waste toner full' message.
Jan 04, 2009 | Canon Office Equipment & Supplies
Sharp copier al1631 , putin new toner sometimes shows CH
the drum might not be rotating due to either the drum gear is wornout or the drum drive gear on the machine main drive unitis wornout.
Nov 26, 2008 | Sharp AL 1631 Copier
The paper light is flashing
My printer is constantly getting jammed, spitting out blank sheets of paper in between every printed sheet, clicking and snapping, etc.
There are a few places to check for a jam - pull the paper drawer out and check there, take the toner cartridge out and you'll often find a sheet there that you cannot see from any other angle, open the little compartment at the back and check there and the usual paper sticking out of the output just enough to pull it out the rest of the way.
I'll be looking for a new printer this week though. I can't take the constant paper jams and sifting out the blank sheets when I'm printing 500+ statements a month.
Definitely NOT an office friendly machine!
Aug 20, 2008 | Lexmark E250dn Laser Printer
Patchy Prints
I believe that the Heat roller in the Fuser has a build up of toner on it(in some areas) and as a result is not fully fusing the toner into the paper. when you use a thick setting you are actually slowing the speed down to allow more heat to the toner. the thicker paper causes more pressure allowing the toner to fuse properly. I would say you need a new Heat roller and possibley a pressure roller. You could try running 20 copies of a blank white page. Sometimes this will help. Poor fusing can also cause a previous image to come up on the next page or repeat itself down the page. A service call is in order if this does not work.
Hope this helps
Dave T
Mar 29, 2008 | Ricoh 6513 Copier
Blank copies
Thanks Guest with Best Solultion! OMG! I have had my machine printing blank for over a month now and reading stuff and trying to find a solution. Until finally today I found this page. I read your solution and hit the front like u said for several times and nothing. Finally, after the third try WALA...IT WORKED!!! Thanks again. If anyone has this same problem try this because it really works! Eventhough this is such a strange problem for such an expensive machine.
Oct 04, 2007 | Canon imageCLASS MF6550 All-In-One Laser...
Sharp AL 1631 Copier Logo
51 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
