My valiant boiler ecoTEC plus begins to come on, but then display code S. 7 comes on and it stops heating up? Do you know what I can do to fix this?
  • 27 Answers
Read what code s.7 means
Posted on Nov 26, 2008
Vaillant ecotec plus 824 problems
The Symbols should be there whenever the boiler is in use, it confirms the pump is running and the gas valve is open...i.e firing.
the pump overrun may come on after a firing to dissipate excess heat and is what it says, i.e the pump continues to run to keep the hot water moving to prevent the boiler from getting noisey. Sometimes you may see a radiator symbol which means the boiler is doing a 'heating' cycle as against hot water.
Nov 20, 2013 | Computers & Internet
My boiler is showing a f75 error code, can u please help me to fix it
F75 is the pcb not acknowledging the pumping kicking in from the sensor measuring the change in pressure.
Most likely cured by changing the sensor, its a known issue with the Ecotec plus range (I assume that's what you have as you haven't told us). user_offline.png quote.png F75 is the pcb not acknowledging the pumping kicking in from the sensor measuring the change in pressure.
Most likely cured by changing the sensor, its a known issue with the Ecotec plus range (I assume that's what you have as you haven't told us). user_offline.png quote.png F75 could be the pcb not sencing the pump coming on from the sensor measuring the change in presure.
Mar 10, 2011 | Heating & Cooling
How do I wire an S-Plan system with a Honeywell programmer to the Valiant ecoTEC plus 428 boiler.
hope this will help http://www.tlc-direct.co.uk/Technical/DataSheets/Horstmann/Pics.pdf
Jan 23, 2011 | Heating & Cooling
My valiant ecotec pro24 boiler wont heat the radiators up,i hav hot water.i just got new meter fitted 2nite+its been 10month since i last used my gas,my pressure is 1.6bar but just cant get heat from...
Have you checked automatic air bleeder on main supply line. I would make sure it is working and bleed each radiator if possible. If you haven't used heat for 10 months I would suspect a build up of air in system. I hope this helps you. Thanks
Nov 29, 2010 | Heating & Cooling
Vaillant ecotech plus f75 code not firing up
F75 is telling you that the pcb has not recognised the slight increase in pressure that is created when the pump kicks in. I hate to say this, but it is a known issue with the ecotec plus range. Usually cured by replacing the sensor (old ones orange) in the bottom left of the boiler. New versions are now black. Can also be caused by muck in the sensor due to poor flushing when the system was installed.
Feb 26, 2010 | KDS Valiant 6380iPTD-01 Notebook
Lost my user manual for the vaillant boiler ecotec plus 824 R1
try to enter here all informations and you can find the manual: http://instructions-manuals.com/search.php?cmarque=VALLIANT%20&modele=ECOTEC%20PLUS%20824
Oct 27, 2009 | KDS Valiant 6380iPTD-01 Notebook
Valliant ECOmax boiler is not giving me any hot water
My Valliant Ecotec Pro Combi Boiler (approx 4 years old) does not start up. The fault code showing is F.22. I would be grateful if you could let me know what the problem is and obv how it can be fixed. Thanks and regards, Joanne Byne
Jul 03, 2009 | KDS Valiant 6380iPTD-01 Notebook
Boiler not igniting
sorry, i think u have this in teh wrong category, it was filed under a laptop model called Valiant
Nov 23, 2008 | KDS Valiant 6380iPTD-01 Notebook
Heating & Cooling Logo
141 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
