Question about Indesit WA 125 Front Load Washer
Indesit W93 washing machine
Well i put a load in half way through its cycle the program dial is just continously clicking .cant restart a program cant open to get the clothes out . cant drain it cant spin it how can i get the clothes out ?
  • 1 more comment
  • komarac Mar 18, 2008
    When I turn on the machine it doesn t starts just turns around first button with programs until the program I put when i switch it on. Where is the problem?
  • UIOP Mar 28, 2008
    When you set the larger dial (with the power button light on) ther is a humming sound but nothing happens - even when you move the dial to another setting
    INDESIT W93 FRONT LOADER
  • Anonymous Sep 16, 2008
    the program knob keeps spinnig and clicking what can this be and can it be fixed cheap
What side are the wires on the heater left 4 negative or right
Posted on Mar 11, 2008
I have same problem and have had a srvice engineer change almost everything on my machine with no success....
Posted on Jan 09, 2007
We have W124, it allmost completed renewed inside. Thanks 3 years warranty and new service engineer, motor was changed and then all problems disappeared.
Posted on May 01, 2007
Indesit w93 washing machine
take out the plug first
did you try to change a program if not check all the wires on the board at the rear bottom left hand side are on
Jun 30, 2014 | Indesit Washing Machines
Indesit washing machine wie167 the word door came flashing up, the cycle has stuck and the door wont open
Ok the machine needs to be drained. Then switch the machine on again. The door should open.
Oct 06, 2012 | Indesit Door Handle Kit for W123, W133,...
Indesit w123. motor burnt out?
If your seeing flashes from behind the dial I'm thinking that the timer needs to be changed. Even with the motor shorted out, it still wouldn't cause that effect to happen.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 17, 2012 | Indesit Door Handle Kit for W123, W133,...
Indesit w93 is not rinsing,
this is most likley to be the programer brain its gone fulty on you,, its not a cheep part to get fixed sorry
Oct 26, 2009 | Washing Machines
Washing machine will not drain
TAKE THE HOSE OFF ON THE BACK {DISCHARGE HOSE} IF THE WATER FLOWS OUT IT IS THE PUMP MOTOR IF IT DOESN'T THERE IS SOMETHING BLOCKING THE OUTLET, SMALL CLOTHING ITEM
May 29, 2009 | Indesit W 123 Front Load Washer
Indesit W93, the light flashes but does not work
On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Mar 29, 2009 | Indesit W 123 Front Load Washer
Indesit w1 13 reset
If your washer has some black spots on timer dial then set your dial pointer to one of these spots to reset programme.
Then try it again, if it still does the same thing, then you probably have a faulty control module.
Expensive!!!!!
Nov 06, 2008 | Indesit WA 115 Front Load Washer
Indesit washing Machine W93
Pump or hoses still blocked,Or pump has had it,Can supply new pump by post if req.
Sep 18, 2008 | Indesit W 123 Front Load Washer
Indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Feb 26, 2008 | Indesit W 123 Front Load Washer
Indesit WA 125 Front Load Washer Logo
543 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
