Question about HP Compaq Presario v3000z Notebook
Laptop startup problem
Yes I tried this. I also reseated the memory modules.
looks like it's the hardware problem.
  • 4 more comments
  • Anonymous Dec 01, 2008
    Compaq Presario V3000 doesn't start, I don't know if it is a HW or software problem!
  • saurabhh Dec 01, 2008
    Same problem.
  • abd_musawir Dec 11, 2008
    I have the same problem too. :(
    Cannot startup. Need to turn on and off several times and if I'm reaaally lucky, the laptop will startup.
  • Muisyo Dec 30, 2008
    Once i power on the laptop,all lights seem to be o.k but it doesn't load neither start-up nor operating system.What might be the cause for this?
    Alex
  • derekmorgan Dec 31, 2008
    Same stuff, lights but no screen or response
  • Muisyo Dec 31, 2008
    The harddrive is o.k,DIMMS o.k,processor o.k.Please assist.
    Muisyo
    Scholar:
  • 188 Answers
There are several possibilities here. Hardware like the hard disk drive or operating system problems and hopefully that's all it is. I'm assuming all are running XP with all the upgrades. The F8 key while booting XP will give you the option of starting in the SAFE MODE. In this environment open your web browser and go to TOOLS, INTERNET OPTIONS, DELETE. Ignore all warnings and delete all files and delete all cookies. Reboot.
On reboot see if XP will boot normally. If not reboot ad enter the safe mode again. Either way go to 'start' 'all programs' 'accessories' 'defrag' and run 'defrag'. reboot and hope all is well. If you are able to get through these processes and there are still problems along the way it would seem that there is either a hard drive problem or a corruption of the XP operating system. Your computer willl need expert hands on advice.
Posted on Dec 16, 2008
On startup, the computer keeps saying it needs a startup repair, but will not move past that screen. It just goes back to the startup repair screen.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty. Although it would be very rare for the sata lead to be faulty. Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
or it could be a virus or malware
Hope this helps.
Jan 20, 2013 | Acer Aspire One D257 Netbook
Startup repairV2
Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable
Hope this helps.
Dec 13, 2012 | eMachines D6205777 COMPATIBLE LAPTOP LCD...
I recieved a message from DELL laptop latitude c600, saying memory read/write failure. What is the problem?
You can try the memory diagnostic test or hard drive diagnostic at the startup..to do this when you see the dell logo when you turn on the computer press ctrl d
Aug 23, 2011 | Dell Computers & Internet
I have a dell inspiron 1750 laptop... when i turn it on it say "Memory write\read failure at 0C034000, read 03EC00EC expecting 03E03EC To resolve issue, try to reseat the memory. Decreaing...
1. First thing to try (least expensive) is to REMOVE the memory stick or sticks and RESEAT them back into their respective slots. Boot up the laptop and check for results.
2. If this does NOT work, remove them again, clean the copper ends with CLEAN pencil eraser.
RESEAT them and check results.
3. Purchase replacement memory sticks/modules.
NOTE: Turn-off your laptop AND unplug A/C adapter. Be careful removing these modules. Touch each module at the corners.
Please advise of results.
Apr 04, 2011 | Dell Inspiron 1750 Laptop
Toshiba laptop beeps 3 times on startup
hi tom2590
usually 3 short beeps is an indication that you have a bad memory module. try reseating the memory module and see if the laptop would run. also if you have 2 ram modules try removing the other one to test. hope this helps
let me know
janc30
Feb 11, 2011 | Toshiba Satellite A75-S229 Notebook
When i turn on my computer hp dv2000 i only hear 1 long beep followed by 2 short beeps..but theres no display.
Common solutions for issues that cause blinking LEDs or beep tones
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. Some HP Notebook PCs come with one stick of memory but have two memory slots. The problem could be that the stick of memory or one of the memory slots has a bad connection.
The memory module compartment on most notebooks is located on the bottom of the case. The exact position varies by model. However, on some models, the memory compartment is under the keyboard. See your User Guide for the exact location of memory modules on your notebook.
NOTE: Removing and reseating memory modules requires the use of tools and the partial disassembly of the computer. If you do not feel comfortable doing this work yourself, take the computer to an authorized retailer for technical service.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors. To reseat the memory module, take the memory module out of the memory slot and then put it back into the slot to get a better connection so that the computer can recognize the memory.
The memory module compartment on most notebooks is located on the bottom of the case, however, on some models, the memory compartment is under the keyboard. See your User Guide for the exact location of memory modules on your notebook.
Use the following steps to remove and reseat the memory modules:
Step 1 - Remove the electrical power
To remove all power from the computer and prevent accidental damage to the electronic components, do the following:Turn off the computer by pressing and holding down the Power button for about 30 seconds. Unplug the AC adaptor from the notebook.Slide and hold the battery release latch to the unlock position.Use your finger to lift the battery up and out.
Step 2 - Remove the memory module
Remove the memory module cover on the bottom of the notebook.1 - Loosen the compartment's retention screws2 - Lift up and remove the memory compartment coverRemove the memory modules from the memory slots.1 - Pull the retention clips away from sides of the memory module2 - Gently pull the module out of the memory module slotCAUTION: To prevent damage to the memory module, grasp the memory module by the side edges. Do not touch the metal contacts.
Reseat the memory module by holding module at a 45-degree angle, and pressing it firmly into the memory slot until it is seated.1 - Align the notched edge of the module with the tab in the slot.2 - Firmly press the module into the slot. 3 - Pivot top edge of memory module downward until retention clips snap into place.After reseating the memory module, replace the cover over the memory compartment before restarting the computer.1 - Align the cover tabs2 - Tighten the memory compartment cover screws
Step 3 - Replace the electrical power
When troubleshooting problems, use only the AC power to perform the tests. After the problem is resolved, you can turn off the computer and insert the battery into the notebook. Plus the connection from the AC adapter into the notebook, and then connect the AC adapter to a working power supply.Perform any tests to verify the computer can startup and run in the Windows operating system.With the computer turned off, push the battery into the base enclosure until the retention clips click into position.
If the computer can access part of the memory, it may be possible to access the BIOS Setup Utility display and perform a memory self test to identify other memory issues. If the computer cannot boot to the BIOS Utility, try removing and reseating the memory and the hard drive, and then repeat the following steps to perform the memory self test.
1.Plug the AC adapter into the computer.
1.Turn off the computer.
1.Press the Power button to start the computer and repeatedly press the f10 key to enter the BIOS Setup menu.
1.In the BIOS Setup Utility, use the Right Arrow or Left Arrow keys to navigate through the menu selection to locate the Diagnostics .
1.Use the Down Arrow or Up Arrow keys to select Memory Test .
1.Press Enter , and then Yes to perform memory test.
1.After test completes, press f10 key to Save and Exit , and then press Enter key to Exit Saving Changes? .
If the test fails, one or more of the memory modules may not be seated properly. Check for and reseat loose memory modules.
What to do when the computer starts into Windows normally
After you have completed the troubleshooting process and your computer has booted normally into the Windows operating system, you should:Run HP Assistant to update HP software and drivers. Run Windows Update to update operating system and software.Run anti-virus program to remove any virus.
Aug 13, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
My laptop will not turn on. It charged all night
The problem might be with the static charges on the motherboard, LCD screen, RAM or with the Hard Disk. Try the followings.
1. Remove Static Charges:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
Still same, remove and reseat the RAM and Hard Disk. Check the below link for service manual.
http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
Refer to page 52 of 134 (Memory Module)
NOTE: If you have more than one memory module, you should test them individually to determine if one or both of them are faulty. Insert each module separately, then turn on the notebook to determine if the inserted module is working. Once you have determined which memory module is faulty, you can replace the faulty module and reseat the working module.
Refer to Page 49 of 134 (Hard Disk)
If still the same, you need to contact HP for hardware repair.
Jul 28, 2010 | Compaq Presario CQ60-220US PC Laptop
On power up it beeps 3 to 4 times and won't boot up
Open up the chassis, remove the DDR memory modules, clean out the dust bunnies
thoroughly with compressed air, and reseat the memory modules one at a time,
attempting to power on the system with each added module. Always unplug the
computer from the wall current when adding or removing hardware.
The 3 beep at startup is a fetal memory error code this may be due to either bad memory module or corruption of BIOS.
Let me know the result after performing the steps I will be glad to assist you further
May 14, 2010 | Dell Inspiron 530 Desktop Computer...
My laptop monitor is not woking
When you plug the DC power adapter and press on the power button, the laptop starts making normal noises, the LEDs work properly but noting appears on the screen. The laptop will not start.
First of all, take a closer look at the LCD screen. Look at the screen under bright light. It’s possible that the image is still on the screen but it’s very faint.
If there is no image on the laptop LCD screen, test the laptop with an external monitor. Connect an external monitor to the VGA port on your laptop and turn the laptop on. You can toggle video output between the internal LCD screen and external monitor by pressing Fn and F4 keys simultaneously on HP laptops, Fn and F5 keys on Toshiba laptops, Fn and F7 keys on IBM laptops. Other laptops may use different key combinations.
Let’s say the external monitor works fine but the internal LCD screen has no image at all. If that’s the case, your problem could be related to the LCD screen or the video cable. Also, make sure the video cable makes good connection with the motherboard and the LCD screen. Try reconnecting, reseating the cable.
In my case, both internal and external monitors were absolutely dead. Neither of them had image. That means the problem is not related to the LCD screen or the video cable. From my experience I know that this problem could be related to the laptop memory.
Try reseating the memory module, maybe it’s not making good connection with the memory slot. Try cleaning contacts on the memory module with pen eraser. Try moving the memory module into another slot. Try replacing the memory module with another known good module, it’s possible that your original module is dead.
If you have two memory modules installed you can try removing them one by one, it’s possible that one of the modules is bad. Try installing different memory modules into different memory slots.
In my case reseating, swapping the memory module didn’t help. I was pretty confident that my problem is not memory related and I moved on.
Try removing battery, hard drive and DVD drive and turning on the laptop without these components.
Also, try turning on the laptop with an external monitor when the video cable is unplugged from the motherboard. If the laptop start with video on the external monitor, apparently there is something wrong with the laptop display panel.
Finally, disassemble the laptop and removed the motherboard.
1. Motherboard. Like on most laptops, in my case the video card is integrated into the motherboard
2. CPU with heatsink and cooling fan.
3. Known good memory module.
4. The power button board witch you need to turn on the system.
5. Working DC power adapter.
Still cannot get any video on the external monitor. The system turns on, the cooling fan starts spinning but there is no video.
At this point I’m 95% sure that the motherboard is dead. CPU failures are not very common, so it must be bad motherboard.
Oct 16, 2009 | Computers & Internet
Continuous Beep-Beep-Beep.. When I turn on T3304 E Machine
there is a faulty hardware in your PC. here the beep error code this might help to locate the faulty hardware in your pc, and which help you to isolate the problem.
1 Short beep - System is operating normally.
1 Long beep - Memory refresh circuitry has failed which indicates a problem with the motherboard. Try
reseating the memory DIMM or SIMM modules. Make sure if you have added memory that it is rated at the correct speed for the system.
1 Long 2 Short beeps - The video adapter has failed, or the video memory is having a read/write
failure. Try reseating the video card. If the video card is a PCI video card, try moving it to another slot.
1 Long 3 Short beeps - The system does not detect a monitor. Verify that the monitor cable is properly attached to the video card or the onboard video and to the monitor (if the monitor has a detachable cable). If possible, try another monitor on the system to verify that the video adapter is operating properly.
2 or 3 beeps - There is a problem with the system’s memory. Reseat the memory DIMM or SIMM modules.
4 beeps - This indicates a non-functional timer. This indicates a problem with the motherboard.
5 beeps - This indicates a CPU (Central Processing Unit or processor) failure. Try reseating the processor.
6 beeps - This indicates a keyboard controller failure. Try reseating the keyboard connector.
7 beeps - Another indication of a processor problem. Reseat the processor.
8 beeps - This indicates a video memory read/write failure. Reseat the video card (if any) and memory DIMM or SIMM modules.
9 or 10 beeps - This indicates a ROM (Read-Only Memory) checksum error or shutdown register failure. This indicates a defective BIOS chip(s). Reseat the BIOS chips.
11 beeps - Indicates an error in the cache memory. If the system has a Pentium class processor, reseat the processor. If the system has a cache memory module, try reseating it. These beep codes will vary depending on the system
hope this would help.
Nov 30, 2008 | E-Machines eMachines Desktop PC
HP Compaq Presario v3000z Notebook Logo
53 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
